Motorola Moto 360 Case Locking Fastener Replacement
Views: 8.6K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
93
All Time:
8,608
Comments: 10
1 comment on steps, 9 guide comments.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Stop! Don't cook your Moto 360 and go at it with an oyster knife just to replace the battery. Just pop out these four fasteners to release the case back.
Note: the guide for removing the strap shows a watch with the back cover ripped off. Don't do it! Just remove the strap and go to the next step.
    1. Motorola Moto 360 Case Locking Fastener Replacement, Wrist Strap: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Locate the spring-loaded pin that attaches the wrist strap to the watch.
      • There is a tiny groove on the end of the pin. This is where you will place the tweezers.
      Ask FixBot
    2. Motorola Moto 360 Case Locking Fastener Replacement: step 2, image 1 of 1
      • Take care not to lose the spring-loaded pin when removing the strap.
      • Use the tweezers to compress the spring-loaded pin so the strap can be removed.
      Ask FixBot
    3. Motorola Moto 360 Case Locking Fastener Replacement: step 3, image 1 of 2 Motorola Moto 360 Case Locking Fastener Replacement: step 3, image 2 of 2
      • Pull the wristband away from the watch face.
      Ask FixBot
    1. Motorola Moto 360 Case Locking Fastener Replacement, Case Locking Fasteners: step 4, image 1 of 1
      • Locate the rectangular end of the fastener inside the wrist strap mounting pocket.
      Ask FixBot
    2. Motorola Moto 360 Case Locking Fastener Replacement: step 5, image 1 of 2 Motorola Moto 360 Case Locking Fastener Replacement: step 5, image 2 of 2
      • Push the point of the pin in behind the fastener and pry it out. There is a notch near the end of the fastener which will engage the pin. Once the end pops out, the fastener will slide out of the slot easliy. Repeat to remove all four of them.
      • That's it. Now the two halves of the watch can be easily separated by just pulling gently with your fingers.
      Ask FixBot
18 other people completed this guide.
Chris K.
661 Reputation
1 Guide authored
9 Guide Comments
I lost my fasteners... where can I buy more?
thiagopimenta - Reply Share
One misleading thing about this guide: pictures show the back cover taken off, while in fact you don't need to do this -- just take out the fasteners.
Дмитрий Трубин (Dmitry Trubin) - Reply Share
Absolutely correct, you don't need to heat or take the back off. I will say though that getting those clips out was damnably fiddly for me.
Ethan Duffy - Reply Share
ou peut acheter Case Locking Fastener Replacement pour moto360 mon bracelet tien pas
svp chez besoin case locking fastener
abellegarde - Reply Share
don't remove the back!
follow this video for removing the locking pins.
I did it, so can you!
https://www.youtube.com/watch?v=Jw3n5qbG...
davidlanchart - Reply Share
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 93
All Time: 8,608
