Motorola Moto 360 O-Ring Replacement
    1. Motorola Moto 360 O-Ring Replacement, Rear Cover: step 1, image 1 of 1
      • Set the watch face down on a flat surface.
      • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
      Ask FixBot
    2. Ask FixBot
    3. Motorola Moto 360 O-Ring Replacement: step 3, image 1 of 2 Motorola Moto 360 O-Ring Replacement: step 3, image 2 of 2
      • Gently slide the blue opening pick between the rear cover and the metal casing.
      • The rear cover is extremely fragile. Be very delicate when using the opening pick.
      • Work your way entirely around the rear cover.
      • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
      Ask FixBot
    4. Motorola Moto 360 O-Ring Replacement: step 4, image 1 of 1
      • Once the adhesive has been successfully loosened, gently pull the rear cover off.
      Ask FixBot
    1. Motorola Moto 360 O-Ring Replacement, O-Ring: step 5, image 1 of 2 Motorola Moto 360 O-Ring Replacement, O-Ring: step 5, image 2 of 2
      • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
      Ask FixBot
    2. Motorola Moto 360 O-Ring Replacement: step 6, image 1 of 1
      • Pinch the green rubber O-Ring and slide it off of the watch.
      • The O-Ring is delicate and is easily severed. Use care around sharp objects.
      Ask FixBot
2 other people completed this guide.
Jake Steinorth
149 Reputation
1 Guide authored
Cal Poly, Team 17-32, Amido Winter 2015 Member of Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Members
44 Guides authored
3 Guide Comments
Where can you get your hands on a replacement o'ring?!
James S - Reply Share
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - Reply Share
i think you should not take the o ring. i was replaceing the battery without take the O ring
cahyanto emanuel nur - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 37
All Time: 3,626
