Minolta Dimage Xt Flash Capacitor Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
54
All Time:
1,616
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
In the event that the flash is not working properly due to internal issues and not settings, it is possible to replace the capacitor to restore function to the flash.
Tools
    1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: step 1, image 1 of 3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: step 1, image 2 of 3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: step 1, image 3 of 3
      • Locate and remove the silver screws on each side of the camera.
      • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
      Ask FixBot
    2. Minolta Dimage Xt Flash Capacitor Replacement: step 2, image 1 of 3 Minolta Dimage Xt Flash Capacitor Replacement: step 2, image 2 of 3 Minolta Dimage Xt Flash Capacitor Replacement: step 2, image 3 of 3
      • Then, carefully pry apart the front and back outer casing away from the internal components.
      • Be aware of the ribbon wire that will disconnect when the casing is detached.
      Ask FixBot
    1. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: step 3, image 1 of 2 Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: step 3, image 2 of 2
      • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
      • On the front side of the camera, locate the flash battery holder.
      • Lift the housing and remove the battery.
      • After removing the battery, clip the wires and solder the replacement battery.
      Ask FixBot
Qqq
19 Reputation
1 Guide authored
1 Guide Comment
Its a cap not a battery :D
Eigirdas Gedgaudas - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 54
All Time: 1,616
