Microsoft Surface Pro 8 Battery Replacement
    1. Microsoft Surface Pro 8 Battery Replacement, Before you begin: step 1, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Before you begin: step 1, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Before you begin: step 1, image 3 of 3
      • Before starting this repair, allow your Surface Pro's battery to drain below 25%. A charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your tablet.
      • If you have a keyboard attached, remove it.
      Ask FixBot
    1. Microsoft Surface Pro 8 Battery Replacement, Open the kickstand: step 2, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Open the kickstand: step 2, image 2 of 2
      • Open the kickstand to about 90 degrees.
      Ask FixBot
    1. Microsoft Surface Pro 8 Battery Replacement, Remove the SSD door: step 3, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the SSD door: step 3, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the SSD door: step 3, image 3 of 3
      • Firmly press a SIM eject tool into the small hole in the corner of the SSD door until it pops up.
      • Alternatively, you can also use a small, straightened paper clip.
      • Remove the SSD door.
      Ask FixBot
    1. Microsoft Surface Pro 8 Battery Replacement, Remove the SSD screw: step 4, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Remove the SSD screw: step 4, image 2 of 2
      • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
      • Use a Torx Plus 3IP screwdriver to remove the 2.3 mm‑long screw securing the SSD.
      Ask FixBot
    2. Microsoft Surface Pro 8 Battery Replacement, Remove SSD: step 5, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Remove SSD: step 5, image 2 of 2
      • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
      • Use your fingers to pull the SSD out of its socket at a shallow angle.
      • If you're having trouble gripping the SSD, use a spudger or your fingernail to lift it slightly.
      Ask FixBot
    1. Microsoft Surface Pro 8 Battery Replacement, Reinstall the SSD door: step 6, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Reinstall the SSD door: step 6, image 2 of 2
      • Leave the SSD removed to keep the battery disconnected.
      • Slide the SSD door back into its recess and press down on the bottom edge until it clicks into place.
      Ask FixBot
    2. Microsoft Surface Pro 8 Battery Replacement, Close the kickstand: step 7, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Close the kickstand: step 7, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Close the kickstand: step 7, image 3 of 3
      • Close the kickstand and flip your device over so the screen is facing up.
      Ask FixBot
    3. Microsoft Surface Pro 8 Battery Replacement, Adhesive information: step 8, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Adhesive information: step 8, image 2 of 2
      • Don't insert your pick more than 8 mm when separating the screen adhesive. Otherwise, you may damage your device's internals.
      • When separating the top edge adhesive, follow instructions carefully to avoid damaging the front camera.
      • To prevent inserting your pick too far, measure 8 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, tape a coin to a pick 8 mm from the tip.
      Ask FixBot
    4. Microsoft Surface Pro 8 Battery Replacement, Apply a suction handle: step 9, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Apply a suction handle: step 9, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Apply a suction handle: step 9, image 3 of 3
      • Apply a suction handle to the top right corner of the screen, near the bottom of the speaker cutout.
      Ask FixBot
    5. Microsoft Surface Pro 8 Battery Replacement, Insert an opening pick: step 10, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Insert an opening pick: step 10, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Insert an opening pick: step 10, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
      • If you're having trouble, try using an iOpener to heat the screen.
      • Insert the tip of an opening pick in the gap you just created.
      Ask FixBot
    6. Microsoft Surface Pro 8 Battery Replacement, Separate the right edge adhesive: step 11, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the right edge adhesive: step 11, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the right edge adhesive: step 11, image 3 of 3
      • Depending on the age of your device and condition of the screen adhesive, you may need to use an iOpener to heat the screen if you're having trouble separating the adhesive.
      • Slide the opening pick down the right edge and around the bottom right corner to separate the adhesive.
      Ask FixBot
    7. Microsoft Surface Pro 8 Battery Replacement, Separate the bottom edge adhesive: step 12, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the bottom edge adhesive: step 12, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the bottom edge adhesive: step 12, image 3 of 3
      • Slide the opening pick along the bottom edge and around the bottom left corner to separate the adhesive.
      Ask FixBot
    8. Microsoft Surface Pro 8 Battery Replacement, Separate the left edge adhesive: step 13, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the left edge adhesive: step 13, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the left edge adhesive: step 13, image 3 of 3
      • Slide the opening pick up the left edge to separate the adhesive.
      • You may need to use a suction handle to help separate the adhesive near the left speaker cutout.
      Ask FixBot
    9. Microsoft Surface Pro 8 Battery Replacement, Separate the top edge adhesive: step 14, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the top edge adhesive: step 14, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the top edge adhesive: step 14, image 3 of 3
      • Don't slide the pick over the front facing camera. Remove the pick enough so that it can slide past the camera without touching it.
      • Slide the opening pick along the top edge to separate the adhesive.
      • You'll likely need to slide the pick around the perimeter a second time to fully separate all the screen adhesive.
      Ask FixBot
    10. Microsoft Surface Pro 8 Battery Replacement, Flip the screen over: step 15, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Flip the screen over: step 15, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Flip the screen over: step 15, image 3 of 3
      • Once the screen is fully separated, slightly lift the top edge and flip the screen so it can lay flat.
      • Be careful not to strain the screen cables.
      • During reassembly:
      • Remove all the remaining adhesive liners, carefully holding the screen above your device as necessary.
      • Flip the screen over and align the bottom edge, using the frame's lip to properly orient it.
      • Once the bottom edge is properly aligned, lay the screen onto the frame.
      • Use your fingers to press down on the entire perimeter of the screen to secure it in the frame.
      • Optionally, you can lay the device screen side down on a clean surface and stack 4–5 heavy books squarely on top of your device. Leave the books in place for at least thirty minutes. The lighter the books, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
    11. Microsoft Surface Pro 8 Battery Replacement, Remove the screen cable cover: step 16, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the screen cable cover: step 16, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the screen cable cover: step 16, image 3 of 3
      • Use an arm of your tweezers to pry up and unclip the corners of the screen cable cover (on the screen itself, not in the device).
      • Be careful not to deform the shield too much, as you'll need to reinstall it during reassembly.
      • Remove the cover.
      Ask FixBot
    12. Microsoft Surface Pro 8 Battery Replacement, Disconnect the screen: step 17, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Disconnect the screen: step 17, image 2 of 2
      Ask FixBot
    13. Microsoft Surface Pro 8 Battery Replacement, Remove the screen: step 18, image 1 of 1
      • Remove the screen.
      • Use a spudger and tweezers to scrape up and remove all the old screen adhesive from the frame. Clean up any residue with high-concentration (>90%) isopropyl alcohol and a coffee filter or lint-free cloth.
      • If you're reusing your screen, repeat the process to remove any adhesive and its residue from the underside of the screen.
      • To prevent damaging your screen, press gently and make sure nothing is under the screen while you work.
      • Before applying any screen adhesives, find their proper orientation on the frame. Use cutouts and notches in the adhesive to match each strip to its spot on the perimeter.
      • Carefully align and apply the adhesive strips to the frame—don't remove the remaining top liners on the strips.
      • Lay the screen upside down on the frame so you can reconnect its cable. The screen should be oriented so when you flip it over, the top edge of the screen is lined up with the top edge of the frame.
      Ask FixBot
    1. Microsoft Surface Pro 8 Battery Replacement, Disconnect the fan: step 19, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Disconnect the fan: step 19, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Disconnect the fan: step 19, image 3 of 3
      • There are two models of the Surface Pro 8—LTE (model 1982) and Wi‑Fi (model 1983). The photos in this guide are from model 1983. If you have a model 1982, there may be slight visual discrepancies, but the procedure will still work. The fan connector position will be slightly different.
      • Use a spudger to lift the small, hinged locking flap on the fan's ZIF connector.
      • Grip the fan cable's plastic pull tab with tweezers and slide the cable fully out of its socket.
      Ask FixBot
    2. Microsoft Surface Pro 8 Battery Replacement, Remove the fan tape: step 20, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the fan tape: step 20, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the fan tape: step 20, image 3 of 3
      • If you have a model 1982 Surface Pro, skip this step.
      • Slide the tip of a spudger under the tape on the top edge of the fan and lift to remove it.
      • Make sure you're only lifting the tape and not the twisted speaker cable underneath.
      Ask FixBot
    3. Microsoft Surface Pro 8 Battery Replacement, Reassembly note: step 21, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Reassembly note: step 21, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Reassembly note: step 21, image 3 of 3
      • Check if the speaker wire got disconnected near the top edge of the fan.
      • If it did, align the connector over its socket and push down with the flat end of a spudger to reconnect it—the connector should click into place.
      Ask FixBot
    4. Microsoft Surface Pro 8 Battery Replacement, Remove the fan screws: step 22, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Remove the fan screws: step 22, image 2 of 2
      • If you have a model 1982 Surface Pro, the screw locations will be slightly different.
      • Use a Torx Plus 3IP screwdriver to remove the 12 screws securing the fan and heat sink assembly:
      • Three 3.2 mm‑long light gray screws
      • One 2.0 mm‑long dark gray screw
      • Four 2.5 mm‑long silver screws
      • Four 2.5 mm‑long silver, CPU tensions screws securing the heatsink
      • During reassembly, install these screws first. Tighten them a few turns at a time in an X pattern. For example: top left, bottom right, top right, bottom left.
      Ask FixBot
    5. Microsoft Surface Pro 8 Battery Replacement, Separate the heat sink: step 23, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the heat sink: step 23, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate the heat sink: step 23, image 3 of 3
      • Be careful during this step, as the heatsink can easily bend out of shape. Don't pry against the copper heat pipes.
      • Use a spudger to gently pry up on the heatsink along the top and bottom edges.
      • Thermal paste bonds the heat sink to the CPU. Depending on the age of your device and condition of the thermal paste, the heat sink may not separate immediately—try wiggling it to help.
      Ask FixBot
    6. Microsoft Surface Pro 8 Battery Replacement, Remove the fan and heatsink assembly: step 24, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Remove the fan and heatsink assembly: step 24, image 2 of 2
      • Use two hands to grip the fan and heatsink assembly close to the center and lift to remove it.
      Ask FixBot
    7. Microsoft Surface Pro 8 Battery Replacement, Remove the metal gasket: step 25, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Remove the metal gasket: step 25, image 2 of 2
      • Use your fingers to gently remove the metal heat sink gasket and set it aside.
      • The gasket will either be on the motherboard or on the bottom of the heat sink.
      Ask FixBot
    8. Microsoft Surface Pro 8 Battery Replacement, Replace the thermal paste and pad: step 26, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Replace the thermal paste and pad: step 26, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Replace the thermal paste and pad: step 26, image 3 of 3
      Tool used on this step:
      Silicone Thermal Pad
      $12.95
      Buy
      • During reassembly, follow this step to replace the thermal paste and pads.
      • Your device has thermal paste that needs to be replaced, as well as two thermal pads that need to be checked. They will either be on the device or their corresponding spots on the bottom of the heat sink.
      • Follow this guide to clean the processor and thermal module and apply thermal paste.
      • Make sure you apply thermal paste to both processor dies.
      • Check the condition of the two thermal pads—one is just to the left of the CPU and the other is in the bottom right corner of the device.
      • If the thermal pads are damaged:
      • Use a spudger to scrape up and remove the damaged pad(s). Clean up any residue with high-concentration (>90%) isopropyl alcohol and a coffee filter or lint-free cloth.
      • Cut the replacement thermal pads to size and put them in place.
      Ask FixBot
    1. Microsoft Surface Pro 8 Battery Replacement, Before you begin: step 27, image 1 of 1
      • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
      Ask FixBot
    1. Microsoft Surface Pro 8 Battery Replacement, Disconnect the battery: step 28, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Disconnect the battery: step 28, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Disconnect the battery: step 28, image 3 of 3
      • Use the flat end of a spudger to lift the battery connector cover until it separates.
      • Don't pry against the connector, or you may damage it.
      • It may take significant force to separate the cover.
      • Remove the connector cover.
      Ask FixBot
    2. Microsoft Surface Pro 8 Battery Replacement: step 29, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement: step 29, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    3. Microsoft Surface Pro 8 Battery Replacement, Adhesive information: step 30, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Adhesive information: step 30, image 2 of 2
      • Eight strips of stetch-release adhesive secure the battery cells to the frame.
      • Be careful not to damage the battery when removing the strips—it can leak dangerous chemicals and/or catch fire.
      Ask FixBot
    4. Microsoft Surface Pro 8 Battery Replacement, Peel up the pull tab: step 31, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Peel up the pull tab: step 31, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Peel up the pull tab: step 31, image 3 of 3
      • Start with the three strips on the left battery cell. They have better access, making it easier to get a feel for how to properly remove the strips.
      • Slide the tip of an opening pick under one of the pull tabs and use your fingers to fully separate it from the battery.
      Ask FixBot
    5. Microsoft Surface Pro 8 Battery Replacement, Remove the adhesive strip: step 32, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the adhesive strip: step 32, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the adhesive strip: step 32, image 3 of 3
      • It takes time and constant tension to release the adhesive strips. Be patient and don't yank on them.
      • Grip the pull tab with a pair of blunt-nose tweezers and slowly pull the strip out from under the battery at a shallow angle.
      • Twist the adhesive around the tweezers while continuing to pull until the whole strip comes out.
      • The strip may make a "squeaking" noise—that's normal and means the adhesive is releasing.
      • If a strip or its pull tab breaks off, use tweezers to try and retrieve it. If you can't reach it, leave it—a different method for separating any leftover adhesive will be shown later in the guide.
      Ask FixBot
    6. Microsoft Surface Pro 8 Battery Replacement, Remove the remaining adhesive strips: step 33, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Remove the remaining adhesive strips: step 33, image 2 of 2
      • Remove the seven remaining adhesive strips from the top edge of the battery.
      • Because the motherboard is so close to the strips on the middle and right battery cells, you'll need to pull the strips out at an angle. Make sure they don't rub against the motherboard, or the strips may break.
      • Remember: if a strip breaks and you can't retrieve it, move on to the next one.
      Ask FixBot
    7. Microsoft Surface Pro 8 Battery Replacement, Apply isopropyl alcohol: step 34, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Apply isopropyl alcohol: step 34, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Apply isopropyl alcohol: step 34, image 3 of 3
      • If you successfully removed all eight adhesive strips, skip the next two steps. Otherwise, follow the next two steps to separate any remaining adhesive.
      • Apply a couple drops of high-concentration (>90%) isopropyl alcohol along the top edge of the battery near the broken adhesive strips.
      • Prop up the top edge of the device so the alcohol flows under the battery.
      • Wait one minute to allow the alcohol to soften the adhesive.
      Ask FixBot
    8. Microsoft Surface Pro 8 Battery Replacement, Separate any remaining adhesive: step 35, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate any remaining adhesive: step 35, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Separate any remaining adhesive: step 35, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Insert a plastic card under the top edge of the battery where the adhesive strips broke off.
      • You can use any rigid card the size of a standard credit card.
      • Slide the card under the battery and lift to separate the adhesive.
      • Repeat the last two steps to separate any other sections of the battery where the adhesive strips broke off.
      Ask FixBot
    9. Microsoft Surface Pro 8 Battery Replacement, Remove the battery: step 36, image 1 of 2 Microsoft Surface Pro 8 Battery Replacement, Remove the battery: step 36, image 2 of 2
      • Use two hands to grip the outer edges of the battery and remove it.
      • Check your replacement battery for any liners and remove them.
      • Remove all remaining adhesive liners from the battery and frame, so the battery adhesive is exposed.
      • Lay the battery into place, making sure the small cutouts on the bottom corners go over their alignment posts.
      • Take your time aligning the battery—once the adhesive sticks, it's very hard to reposition.
      Ask FixBot
    10. Microsoft Surface Pro 8 Battery Replacement, Remove the old adhesive: step 37, image 1 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the old adhesive: step 37, image 2 of 3 Microsoft Surface Pro 8 Battery Replacement, Remove the old adhesive: step 37, image 3 of 3
      • Remove any bits of adhesive strips left on the frame with tweezers or your fingers.
      • Use high-concentration (>90%) isopropyl alcohol to clean up any adhesive residue left on the frame.
      • If your battery doesn't come with adhesive pre-installed, you'll need to replace the adhesive. You can apply strips of thin, double-sided tape to the frame where the old adhesive was, or you can apply stretch-release adhesive to the battery.
      Ask FixBot
Calibrate your newly installed battery after completing this guide.
Spencer Day
206,456 Reputation
1,266 Guides authored
2 Guide Comments
I don’t know if different manufacturing runs are the culprit (benefit of the doubt) but following this guide was an absolute disaster.
I have disassembled several iPads/iPhones without incident (all the ones I have tried), but doing this without heat was EXTREMELY inadvisable. I proceeded very slowly, with constant light pressure, and did not feel like I hit too much resistance - but it cracked at the very center of the bottom of the screen and it was nothing but snowball disaster from that point on.
My advice is to NOT even attempt to follow this guide without using heat to soften the glue. If you feel any resistance, it’s too much. The pic should ONLY glide through easily! Do not make my mistake and proceed anyway if it doesn’t!
jack44556677 - Reply Share
I have a Microsoft window 8pro and the problem is the battery where are you located 8n Doha
sharkcen bea - Reply Share
Past 24 Hours: 46
Past 7 Days: 221
Past 30 Days: 948
All Time: 3,094
