Microsoft Surface Pro 6 Battery Replacement
    1. Microsoft Surface Pro 6 Battery Replacement, Heat the screen: step 1, image 1 of 1
      • Completely power off the Surface before you begin disassembly.
      • If the screen's glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the display until all the glass is covered. Wear safety glasses to protect your eyes.
      • Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
      • You may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
      • A hair dryer, heat gun, or hot plate may also be used for more heat, but be careful not to overheat the Surface—the screen and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Microsoft Surface Pro 6 Battery Replacement, Take note of the adhesive layout: step 2, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Take note of the adhesive layout: step 2, image 2 of 2
      • Take note of the screen adhesive layout before continuing:
      • These areas only contain adhesive and are safe to cut.
      • The display board and flex cables sit here close to the edge. Cut very carefully and do not insert the pick as deep under the display.
      • Fragile antenna cables lie under this part of the screen. Carefully follow the procedure to avoid damaging them. The adhesive is also the thickest here.
      Ask FixBot
    3. Microsoft Surface Pro 6 Battery Replacement, Insert an opening pick into the speaker opening: step 3, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Insert an opening pick into the speaker opening: step 3, image 2 of 2
      • Insert an opening pick into the speaker opening on the screen and slide the pick under the glass. Do not press the pick into the speaker grille, as the grille is easily torn.
      • Don't insert the opening pick any deeper than the black bezel on the side of the screen. Inserting the pick too far may damage the LCD.
      Ask FixBot
    4. Microsoft Surface Pro 6 Battery Replacement, Slide an opening pick under the screen: step 4, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Slide an opening pick under the screen: step 4, image 2 of 2
      • Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
      Ask FixBot
    5. Microsoft Surface Pro 6 Battery Replacement, Cut through the screen adhesive: step 5, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Cut through the screen adhesive: step 5, image 2 of 2
      • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
      • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
      • Leave this opening pick in the right edge to prevent the adhesive from resealing.
      Ask FixBot
    6. Microsoft Surface Pro 6 Battery Replacement: step 6, image 1 of 1
      • Reheat the iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
      Ask FixBot
    7. Microsoft Surface Pro 6 Battery Replacement: step 7, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 7, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 7, image 3 of 3
      • Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
      • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
      • Leave this pick in the bottom edge to prevent the adhesive from resealing.
      Ask FixBot
    8. Microsoft Surface Pro 6 Battery Replacement: step 8, image 1 of 1
      • Reheat the iOpener and apply it to the left edge of the Surface's screen for two minutes.
      Ask FixBot
    9. Microsoft Surface Pro 6 Battery Replacement: step 9, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 9, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 9, image 3 of 3
      • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
      • Take care cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inches (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
      • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
      • Leave this pick in the left edge to prevent the adhesive from resealing.
      Ask FixBot
    10. Microsoft Surface Pro 6 Battery Replacement: step 10, image 1 of 1
      • Reheat the iOpener and apply it to the top edge of the Surface's screen for two minutes.
      • The adhesive is thickest along this edge, and you may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
      Ask FixBot
    11. Microsoft Surface Pro 6 Battery Replacement: step 11, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 11, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 11, image 3 of 3
      • Round the left corner with the opening pick and slide it along the top edge of the Surface. Stop when the pick is 2.75 inches (70 mm) away from the left edge.
      • The next 6 inches (15 cm) of the top edge of the case is covered by the left and right antennas, which sit between the case and the screen bezel. Follow the next steps carefully to avoid damaging the antennas.
      Ask FixBot
    12. Microsoft Surface Pro 6 Battery Replacement: step 12, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 12, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 12, image 3 of 3
      • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
      • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
      • Keep the pick parallel to the screen throughout the whole procedure so that it doesn't catch on the antennas. Do not press the pick against the case.
      • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
      Ask FixBot
    13. Microsoft Surface Pro 6 Battery Replacement: step 13, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 13, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 13, image 3 of 3
      • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, away from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
      Ask FixBot
    14. Microsoft Surface Pro 6 Battery Replacement, Open the Surface: step 14, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Open the Surface: step 14, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Open the Surface: step 14, image 3 of 3
      • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
      • Do not remove the screen yet. It is still connected to the motherboard by two cables.
      • Use an opening pick to cut through any remaining adhesive.
      • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
      Ask FixBot
    15. Microsoft Surface Pro 6 Battery Replacement: step 15, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 15, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 15, image 3 of 3
      • Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
      • Gently lay the screen down on the case with the connectors facing up. Take care to avoid creasing the display cables.
      Ask FixBot
    16. Microsoft Surface Pro 6 Battery Replacement, Disconnect the screen: step 16, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the screen: step 16, image 2 of 2
      • Use an opening pick to pry up one edge of the EMI shield covering the display board.
      • Repeat this procedure at different points around the shield until it is free.
      • Try not to deform the shield too much—you will need to reinstall it during reassembly.
      Ask FixBot
    17. Microsoft Surface Pro 6 Battery Replacement: step 17, image 1 of 1
      • Lift the EMI shield away from the display board and remove it.
      Ask FixBot
    18. Microsoft Surface Pro 6 Battery Replacement: step 18, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement: step 18, image 2 of 2
      • Use the flat end of a spudger to pry the display interconnect cable straight up and out of its socket on the board.
      Ask FixBot
    19. Microsoft Surface Pro 6 Battery Replacement: step 19, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement: step 19, image 2 of 2
      Tool used on this step:
      Buy
      • Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
      • Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
      • Repeat this procedure at different points around the shield until it is free. Remove the shield.
      Ask FixBot
    20. Microsoft Surface Pro 6 Battery Replacement: step 20, image 1 of 1
      • Pull the rest of the shield off of the digitizer connector and remove it.
      Ask FixBot
    21. Microsoft Surface Pro 6 Battery Replacement: step 21, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement: step 21, image 2 of 2
      • Use the tip of a spudger to pry the digitizer connector straight up and out of its socket on the screen.
      Ask FixBot
    22. Microsoft Surface Pro 6 Battery Replacement: step 22, image 1 of 1
      • Remove the screen assembly from the Surface.
      • During reassembly, pause here and follow this guide to replace the screen adhesive.
      Ask FixBot
    1. Microsoft Surface Pro 6 Battery Replacement, Disconnect the antenna support: step 23, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the antenna support: step 23, image 2 of 2
      • Use the point of a spudger to pry the microphone connector straight up and out of its socket on the motherboard.
      Ask FixBot
    2. Microsoft Surface Pro 6 Battery Replacement, Unscrew the antenna support: step 24, image 1 of 1
      • Use a T5 Torx driver to remove the four screws securing the antenna support:
      • Three 4.5 mm screws
      • One 6 mm screw
      Ask FixBot
    3. Microsoft Surface Pro 6 Battery Replacement, Remove the antenna support: step 25, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the antenna support: step 25, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the antenna support: step 25, image 3 of 3
      • Use a spudger to lift the antenna support out of its recess in the Surface.
      • Remove the antenna support.
      Ask FixBot
    1. Microsoft Surface Pro 6 Battery Replacement, Remove the heat sink shield: step 26, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Remove the heat sink shield: step 26, image 2 of 2
      Buy
      • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
      • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
      • Take care not to puncture the battery with the tweezers while working on this shield.
      Ask FixBot
    2. Microsoft Surface Pro 6 Battery Replacement: step 27, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 27, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 27, image 3 of 3
      • Repeat the last step for each corner of the EMI shield covering the heat sink.
      Ask FixBot
    3. Microsoft Surface Pro 6 Battery Replacement: step 28, image 1 of 1
      • Remove the heat sink shield.
      Ask FixBot
    4. Microsoft Surface Pro 6 Battery Replacement, Remove the heat sink: step 29, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Remove the heat sink: step 29, image 2 of 2
      • Remove the ten Torx screws securing the heat sink:
      • Six 2.6 mm-long T3 screws
      • Four 3.3 mm-long T5 screws
      • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
      • Screw 1
      • Screw 2
      • Screw 3
      • Screw 4
      Ask FixBot
    5. Microsoft Surface Pro 6 Battery Replacement: step 30, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 30, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 30, image 3 of 3
      Ask FixBot
    1. Microsoft Surface Pro 6 Battery Replacement, Disconnect the left speaker: step 31, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the left speaker: step 31, image 2 of 2
      • Use the point of a spudger to lift the left speaker connector out of its socket on the motherboard.
      Ask FixBot
    2. Microsoft Surface Pro 6 Battery Replacement, Disconnect the volume and power buttons: step 32, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Disconnect the volume and power buttons: step 32, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Disconnect the volume and power buttons: step 32, image 3 of 3
      • Use the point of a spudger to flip up the small locking flap securing the volume and power button cable ZIF connector.
      • Slide the volume and power button cable straight out of its socket on the motherboard.
      Ask FixBot
    3. Microsoft Surface Pro 6 Battery Replacement, Disconnect the right speaker: step 33, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the right speaker: step 33, image 2 of 2
      • Use the point of a spudger to lift the right speaker connector out of its socket on the motherboard.
      Ask FixBot
    4. Microsoft Surface Pro 6 Battery Replacement, Unscrew the right speaker: step 34, image 1 of 1
      • Use a T5 Torx driver to remove the two screws securing the right speaker:
      • One 6 mm screw
      • One 3.7 mm screw
      Ask FixBot
    5. Microsoft Surface Pro 6 Battery Replacement, Remove the right speaker: step 35, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the right speaker: step 35, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the right speaker: step 35, image 3 of 3
      • Use a spudger to lift the left edge of the right speaker so that it clears the components around the speaker.
      • With the left edge lifted, slide the speaker to the left, straight out of its recess in the case.
      Ask FixBot
    6. Microsoft Surface Pro 6 Battery Replacement, Remove the camera connector shield: step 36, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the camera connector shield: step 36, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the camera connector shield: step 36, image 3 of 3
      Buy
      • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the camera connectors.
      Ask FixBot
    7. Microsoft Surface Pro 6 Battery Replacement, Disconnect the front-facing cameras: step 37, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the front-facing cameras: step 37, image 2 of 2
      • Use the flat end of a spudger to pry the front-facing camera connector up and out of its socket on the motherboard.
      Ask FixBot
    8. Microsoft Surface Pro 6 Battery Replacement: step 38, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement: step 38, image 2 of 2
      • Use the flat end of a spudger to pry the face-detection camera connector up and out of its socket on the motherboard.
      Ask FixBot
    9. Microsoft Surface Pro 6 Battery Replacement, Disconnect the rear-facing camera: step 39, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the rear-facing camera: step 39, image 2 of 2
      • Use the flat end of a spudger to pry the rear-facing camera connector up and out of its socket on the motherboard.
      Ask FixBot
    10. Microsoft Surface Pro 6 Battery Replacement, Disconnect the microphone: step 40, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the microphone: step 40, image 2 of 2
      • Use the flat end of a spudger to pry the microphone connector up and out of its socket on the motherboard.
      Ask FixBot
    11. Microsoft Surface Pro 6 Battery Replacement, Remove the microSD card reader connector shield: step 41, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the microSD card reader connector shield: step 41, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the microSD card reader connector shield: step 41, image 3 of 3
      • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the microSD card reader connector.
      Ask FixBot
    12. Microsoft Surface Pro 6 Battery Replacement, Disconnect the microSD card reader: step 42, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the microSD card reader: step 42, image 2 of 2
      • Use the flat end of a spudger to pry the microSD card reader connector up and out of its socket on the motherboard.
      Ask FixBot
    13. Microsoft Surface Pro 6 Battery Replacement, Disconnect the SurfaceConnect port: step 43, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement, Disconnect the SurfaceConnect port: step 43, image 2 of 2
      • Use the flat end of a spudger to lift the flap that sits over the SurfaceConnect port connector.
      Ask FixBot
    14. Microsoft Surface Pro 6 Battery Replacement: step 44, image 1 of 2 Microsoft Surface Pro 6 Battery Replacement: step 44, image 2 of 2
      • Slide the SurfaceConnect port connector out of its socket on the motherboard.
      Ask FixBot
    15. Microsoft Surface Pro 6 Battery Replacement, Disconnect the headphone jack: step 45, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Disconnect the headphone jack: step 45, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Disconnect the headphone jack: step 45, image 3 of 3
      • Use the point of a spudger to flip up the small locking flap securing the headphone jack cable ZIF connector.
      • Slide the headphone jack cable straight out of its socket on the motherboard.
      Ask FixBot
    16. Microsoft Surface Pro 6 Battery Replacement, Remove the two large EMI shields: step 46, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the two large EMI shields: step 46, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the two large EMI shields: step 46, image 3 of 3
      • Insert one point of a pair of pointed tweezers into a gap in the corner of the left-most of the remaining large EMI shields.
      Ask FixBot
    17. Microsoft Surface Pro 6 Battery Replacement: step 47, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 47, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 47, image 3 of 3
      • Repeat the previous step to remove the remaining large EMI shield from the right side of the motherboard.
      Ask FixBot
    18. Microsoft Surface Pro 6 Battery Replacement, Remove the motherboard assembly: step 48, image 1 of 1
      • Use a T3 Torx driver to remove the eight 2.2 mm screws securing the motherboard.
      Ask FixBot
    19. Microsoft Surface Pro 6 Battery Replacement: step 49, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 49, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 49, image 3 of 3
      • Lift the non-port-side of the motherboard up slightly, just enough so that it clears the components around it and the edge of the case.
      • Slide the motherboard away from the ports. Make sure the ports are completely out of their slots in the case before removing the motherboard.
      • Remove the motherboard.
      Ask FixBot
    1. Microsoft Surface Pro 6 Battery Replacement, Heat the battery connector: step 50, image 1 of 1
      • Heat an iOpener and apply it to the battery connector for two minutes to soften the adhesive securing the connector to the case.
      Ask FixBot
    2. Microsoft Surface Pro 6 Battery Replacement, Separate the battery connector adhesive: step 51, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Separate the battery connector adhesive: step 51, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Separate the battery connector adhesive: step 51, image 3 of 3
      • Starting at the edge closest to the battery, slide an opening pick under the battery connector to separate the adhesive underneath.
      • Make sure the battery connector is completely free from the case.
      Ask FixBot
    3. Microsoft Surface Pro 6 Battery Replacement, Remove the battery: step 52, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the battery: step 52, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement, Remove the battery: step 52, image 3 of 3
      • Prop the top edge of the Surface up a couple inches so the whole Surface slopes towards the bottom edge.
      • Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the top edge of the battery.
      • If you are using adhesive remover, follow these preparation steps first.
      • Let the adhesive remover sit and soak into the adhesive for 2–3 minutes before continuing.
      Ask FixBot
    4. Microsoft Surface Pro 6 Battery Replacement: step 53, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 53, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 53, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Take care not to puncture or bend the battery with your tools—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      • Slide a plastic card under the left side of the top edge of the battery.
      • If you encounter significant resistance at any point during this procedure, stop, apply a little more adhesive remover, and wait for it to soak in.
      • Slide the card side to side under the upper left battery cell to slice through the adhesive underneath.
      Ask FixBot
    5. Microsoft Surface Pro 6 Battery Replacement: step 54, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 54, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 54, image 3 of 3
      • Slide the plastic card around the left edge of the battery and under the bottom left battery cell.
      • Slide the card side to side under the bottom left cell to slice through the adhesive underneath.
      Ask FixBot
    6. Microsoft Surface Pro 6 Battery Replacement: step 55, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 55, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 55, image 3 of 3
      • Repeat the previous two steps for the right side of the battery to release the two right cells from their adhesive.
      Ask FixBot
    7. Microsoft Surface Pro 6 Battery Replacement: step 56, image 1 of 3 Microsoft Surface Pro 6 Battery Replacement: step 56, image 2 of 3 Microsoft Surface Pro 6 Battery Replacement: step 56, image 3 of 3
      • Lift each side of the battery with a plastic card and make sure all the adhesive is separated from the battery.
      • Gently lift the battery out of the case.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • During reassembly, follow this guide to clean off old adhesive and apply new adhesive from a pre-cut adhesive card.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
35 other people completed this guide.
Adam O'Camb
225,006 Reputation
415 Guides authored
11 Guide Comments
Das sieht hoch kompliziert aus. Respekt an den Autor und Kritik an Microsoft.
Musab Erdem - Reply Share
Awesome! Thanks so much. Took me an added 5 hours because I shattered the screen on step 4. Maybe I didn't heat it enough. Maybe because it was already cracked in the corner. Not sure. Luckily, I was replacing the screen anyway and already had a replacement. Good luch y'all. These things were NOT meant to be repaired! I consider myself pretty handy, but I don't think I would have made it without this guide.
david atkins - Reply Share
Took me 4 hours and the screen is just black, I was super careful, this isn't my first time.
Doug Harris - Reply Share
請問版主,我仔細小心得拆下所有部件,並更換了新的電池,也安裝得很順利,沒有拆壞什麼東西,但開啟電源一直停留在黑畫面中間是微軟白色的標誌!請問板主之道是什麼原因嗎?非常感謝,我的電腦是surface Pro 5
taiwan mini - Reply Share
Around step 31 for the left speaker, mine had a fan on it. So just disconnect the ribbon cable and there’s a few extra screws but guide worked well. Took 8 hrs for me but the battery paste and screen paste gave me a lot of trouble. The cards in the kit do well for getting the batteries off with hefty remover. Didn’t crack the screen crazy enough.
Bud Parks - Reply Share
Past 24 Hours: 29
Past 7 Days: 219
Past 30 Days: 943
All Time: 70,435
