Up to 20% off select tools
Maylong M-270 Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
83
All Time:
1,278
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Maylong M-270 Battery Replacement, Motherboard: step 1, image 1 of 2 Maylong M-270 Battery Replacement, Motherboard: step 1, image 2 of 2
      • Use the plastic opening tool to separate the back cover plate from the front.
      • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
      Ask FixBot
    2. Maylong M-270 Battery Replacement: step 2, image 1 of 2 Maylong M-270 Battery Replacement: step 2, image 2 of 2
      • Locate the two ribbons attached to the device's motherboard.
      • Flip the small black plastic catches down by using the small end of the spudger.
      • Remove the ribbons by gently pulling them away from the motherboard.
      Ask FixBot
    3. Maylong M-270 Battery Replacement: step 3, image 1 of 2 Maylong M-270 Battery Replacement: step 3, image 2 of 2
      • Remove the two screws from the motherboard.
      • Remove the four screws and metal holds from the edge of the device.
      Ask FixBot
    4. Maylong M-270 Battery Replacement: step 4, image 1 of 1
      • Remove the motherboard by gently pulling it away from the bottom of the device.
      Ask FixBot
    1. Maylong M-270 Battery Replacement, Battery: step 5, image 1 of 2 Maylong M-270 Battery Replacement, Battery: step 5, image 2 of 2
      Ask FixBot
    2. Maylong M-270 Battery Replacement: step 6, image 1 of 3 Maylong M-270 Battery Replacement: step 6, image 2 of 3 Maylong M-270 Battery Replacement: step 6, image 3 of 3
      • Remove the battery by using the spudger to gently pry the battery away from metal case around the front screen.
      Ask FixBot
Author
with
Adam Sanders
222 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 83
All Time: 1,278
