Maylong M-270 Motherboard Replacement
    1. Maylong M-270 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Maylong M-270 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Use the plastic opening tool to separate the back cover plate from the front.
      • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
      Ask FixBot
    2. Maylong M-270 Motherboard Replacement: step 2, image 1 of 2 Maylong M-270 Motherboard Replacement: step 2, image 2 of 2
      • Locate the two ribbons attached to the device's motherboard.
      • Flip the small black plastic catches down by using the small end of the spudger.
      • Remove the ribbons by gently pulling them away from the motherboard.
      Ask FixBot
    3. Maylong M-270 Motherboard Replacement: step 3, image 1 of 2 Maylong M-270 Motherboard Replacement: step 3, image 2 of 2
      • Remove the two screws from the motherboard.
      • Remove the four screws and metal holds from the edge of the device.
      Ask FixBot
    4. Maylong M-270 Motherboard Replacement: step 4, image 1 of 1
      • Remove the motherboard by gently pulling it away from the bottom of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 22
All Time: 827
