MacBook Pro 16" 2019 Trackpad Replacement
Views: 29K
View statistics:
Past 24 Hours:
24
Past 7 Days:
115
Past 30 Days:
393
All Time:
29,068
Comments: 61
60 comments on steps, 1 guide comment.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a faulty trackpad, or to simply remove the trackpad temporarily when servicing the battery.
For your safety, discharge your MacBook Pro's battery below 25% before you begin this procedure. A charged lithium-ion battery can create a dangerous fire if accidentally punctured.
Parts
Tools
    1. MacBook Pro 16" 2019 Trackpad Replacement, Disable Auto Boot: step 1, image 1 of 3 MacBook Pro 16" 2019 Trackpad Replacement, Disable Auto Boot: step 1, image 2 of 3 MacBook Pro 16" 2019 Trackpad Replacement, Disable Auto Boot: step 1, image 3 of 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      Ask FixBot
    1. MacBook Pro 16" 2019 Trackpad Replacement, Remove lower case screws: step 2, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement, Remove lower case screws: step 2, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
      • Four 3.7 mm screws
      • Two 7.3 mm screws
      • Note how the screws come out at a slight angle—you must reinstall them the same way.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 16" 2019 Trackpad Replacement, Unclip lower case: step 3, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement, Unclip lower case: step 3, image 2 of 2
      • Press a suction handle into place near the front edge of the lower case, between the screw holes.
      • Pull up on the suction handle just enough to open a small gap under the lower case.
      Ask FixBot
    3. MacBook Pro 16" 2019 Trackpad Replacement: step 4, image 1 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 4, image 2 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 4, image 3 of 3
      • Slide the corner of an opening pick into the gap you just created underneath the lower case.
      • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
      • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 16" 2019 Trackpad Replacement: step 5, image 1 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 5, image 2 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 5, image 3 of 3
      • Repeat the previous step on the other side, using an opening pick to to release the second clip.
      Ask FixBot
    5. MacBook Pro 16" 2019 Trackpad Replacement: step 6, image 1 of 1
      • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
      • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
      • Don't lift more than an inch or so, and don't try to remove the lower case yet.
      Ask FixBot
    6. MacBook Pro 16" 2019 Trackpad Replacement: step 7, image 1 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 7, image 2 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 7, image 3 of 3
      • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • Pull first at one corner, then the other.
      • Pull to the side—not up.
      • This may require a lot of force.
      Ask FixBot
    7. MacBook Pro 16" 2019 Trackpad Replacement, Remove lower case: step 8, image 1 of 3 MacBook Pro 16" 2019 Trackpad Replacement, Remove lower case: step 8, image 2 of 3 MacBook Pro 16" 2019 Trackpad Replacement, Remove lower case: step 8, image 3 of 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      Ask FixBot
    1. MacBook Pro 16" 2019 Trackpad Replacement, Remove battery board sticker: step 9, image 1 of 1
      • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
      • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
      Ask FixBot
    2. MacBook Pro 16" 2019 Trackpad Replacement: step 10, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement: step 10, image 2 of 2
      • Peel back any tape covering the battery board data cable connector.
      Ask FixBot
    3. MacBook Pro 16" 2019 Trackpad Replacement, Disconnect battery board data cable: step 11, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement, Disconnect battery board data cable: step 11, image 2 of 2
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
      Ask FixBot
    4. MacBook Pro 16" 2019 Trackpad Replacement: step 12, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement: step 12, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
      • Slide parallel to the logic board. Don't pull up.
      Ask FixBot
    5. MacBook Pro 16" 2019 Trackpad Replacement: step 13, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement: step 13, image 2 of 2
      • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
      Ask FixBot
    6. MacBook Pro 16" 2019 Trackpad Replacement, Remove battery board data cable: step 14, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement, Remove battery board data cable: step 14, image 2 of 2
      • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
      • Take care not to reinstall this cable backwards or upside-down.
      Ask FixBot
    7. MacBook Pro 16" 2019 Trackpad Replacement, Disconnect the battery: step 15, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement, Disconnect the battery: step 15, image 2 of 2
      • Use a T5 Torx driver to remove the 6.7 mm pancake screw securing the battery power connector.
      Ask FixBot
    8. MacBook Pro 16" 2019 Trackpad Replacement: step 16, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement: step 16, image 2 of 2
      • Use a spudger to lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
      Ask FixBot
    1. MacBook Pro 16" 2019 Trackpad Replacement, Remove trackpad cable connector bracket: step 17, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement, Remove trackpad cable connector bracket: step 17, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.8 mm screws securing the cover bracket for the keyboard and trackpad cable connectors.
      • Remove the bracket.
      Ask FixBot
    2. MacBook Pro 16" 2019 Trackpad Replacement, Disconnect trackpad cable: step 18, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement, Disconnect trackpad cable: step 18, image 2 of 2
      • Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
      Ask FixBot
    3. MacBook Pro 16" 2019 Trackpad Replacement: step 19, image 1 of 1
      • Apply mild heat to the trackpad ribbon cable to soften the adhesive securing it to the battery.
      • You can use an iOpener, hair dryer, or heat gun, but be careful not to overheat the battery. The cable should be warm, but not too hot to touch.
      Ask FixBot
    4. MacBook Pro 16" 2019 Trackpad Replacement: step 20, image 1 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 20, image 2 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 20, image 3 of 3
      • Carefully peel the trackpad cable up off the battery, and push it out of the way.
      • Don't crease or tear the cable. If you have trouble, don't force it—apply more heat and try again.
      Ask FixBot
    5. MacBook Pro 16" 2019 Trackpad Replacement, Remove the trackpad assembly screws: step 21, image 1 of 2 MacBook Pro 16" 2019 Trackpad Replacement, Remove the trackpad assembly screws: step 21, image 2 of 2
      • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
      • Nine 5.8 mm screws
      • Four 4.9 mm screws
      • These screws all look similar—be careful not to mix them up.
      • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
      • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
      Ask FixBot
    6. MacBook Pro 16" 2019 Trackpad Replacement, Remove the trackpad: step 22, image 1 of 3 MacBook Pro 16" 2019 Trackpad Replacement, Remove the trackpad: step 22, image 2 of 3 MacBook Pro 16" 2019 Trackpad Replacement, Remove the trackpad: step 22, image 3 of 3
      • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
      • Carefully feed the trackpad's ribbon cable through its slot in the chassis.
      Ask FixBot
    7. MacBook Pro 16" 2019 Trackpad Replacement: step 23, image 1 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 23, image 2 of 3 MacBook Pro 16" 2019 Trackpad Replacement: step 23, image 3 of 3
      • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
      • Remove the trackpad assembly.
      • Make sure your new trackpad has a ribbon cable installed before reassembly. If necessary, transfer the old cable, or install the one your new trackpad came with.
      Ask FixBot
13 other people completed this guide.
Carsten Frauenheim
172,100 Reputation
441 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,895 Guides authored
1 Guide Comment
I have a macbook pro 16" from 2019, it did not give me a haptic response, the Force Touch is sensitive to touch and pressure but there was no sensation of "click" or vibration, I disassembled the mac and the trackpad out of pure curiosity, and when closing and turn on the mac, the trackpad was completely unusable as well as the keyboard and the fans at full, I already tried to restore PRAM and SMC with an external keyboard and nothing worked, I already started in safe mode and neither. I reopen it to verify all the grants but there is nothing visibly wrong. Please Help...
José Eduardo Mendoza - Reply Share
Past 24 Hours: 24
Past 7 Days: 115
Past 30 Days: 393
All Time: 29,068
