MacBook Pro 15" Touch Bar 2018 Screen Replacement
Views: 112K
View statistics:
Past 24 Hours:
30
Past 7 Days:
147
Past 30 Days:
641
All Time:
111,664
Comments: 127
99 comments on steps, 28 guide comments.
Go to guide comments
Completed: 45
45 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace the entire display assembly on your MacBook Pro, in order to fix a cracked or faulty screen. This assembly also includes the integrated ribbon cables that are known to fail as part of the “FlexGate” defect on earlier models, so replacing it will also resolve the “stage lights” effect and other issues resulting from ribbon cable damage.
Although we’ve successfully tested this procedure on 2018 models using original Apple replacement displays, Apple’s T2 chip may prevent aftermarket displays from working correctly, and your MacBook Pro may not boot as a result.
For your safety, discharge your MacBook Pro's battery below 25% before you begin. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured.
Parts
Tools
    1. MacBook Pro 15" Touch Bar 2018 Screen Replacement, Disable Auto Boot: step 1, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement, Disable Auto Boot: step 1, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement, Disable Auto Boot: step 1, image 3 of 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      Ask FixBot
    1. MacBook Pro 15" Touch Bar 2018 Screen Replacement, Lower Case: step 2, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement, Lower Case: step 2, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
      • Four 4.7 mm screws
      • Two 6.6 mm screws
      • Note how the screws come out at a slight angle—you must reinstall them the same way.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 3, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 3, image 2 of 2
      • Press a suction handle into place near the front edge of the lower case, between the screw holes.
      • Pull up on the suction handle just enough to open a small gap under the lower case.
      Ask FixBot
    3. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 4, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 4, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 4, image 3 of 3
      • Slide the corner of an opening pick into the gap you just created underneath the lower case.
      • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
      • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 5, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 5, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 5, image 3 of 3
      • Repeat the previous step on the other side, using an opening pick to release the second clip.
      Ask FixBot
    5. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 6, image 1 of 1
      • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
      • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
      • Don't lift more than an inch or so, and don't try to remove the lower case yet.
      Ask FixBot
    6. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 7, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 7, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 7, image 3 of 3
      • Insert the flat end of a spudger into the hinge cutout in the lower case, at the corner nearest the headphone jack.
      • Pry to lever the lower case away from the hinge area, pushing it slightly towards the front edge of the MacBook.
      • Repeat at the opposite side of the cutout.
      Ask FixBot
    7. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 8, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 8, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 8, image 3 of 3
      • Mind your fingers or wear protective gloves during this step—the case edges may be very sharp.
      • Grab the front edge of the lower case again, and pull firmly to slide it towards the front edge of the MacBook (away from the hinge area), separating the last of the clips.
      • Pull first at one corner, then the other.
      • Pull to the side—not up.
      Ask FixBot
    8. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 9, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 9, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 9, image 3 of 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      Ask FixBot
    1. MacBook Pro 15" Touch Bar 2018 Screen Replacement, Battery Connector: step 10, image 1 of 1
      • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
      • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
      • If the cover doesn't seat securely during reassembly, try rotating it 180 degrees. It must be oriented correctly in order for the adhesive pads underneath to contact the board screws.
      Ask FixBot
    2. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 11, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 11, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 11, image 3 of 3
      • Peel back any tape covering the battery board data cable connector.
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
      Ask FixBot
    3. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 12, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 12, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
      • Slide parallel to the logic board, in the direction of the cable.
      Ask FixBot
    4. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 13, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 13, image 2 of 2
      • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
      Ask FixBot
    5. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 14, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 14, image 2 of 2
      • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
      • Take care not to install this cable backwards or upside-down. When installed correctly, the white liquid indicator sticker should face up, positioned directly over the battery power connector screw.
      Ask FixBot
    6. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 15, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 15, image 2 of 2
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      Ask FixBot
    7. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 16, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 16, image 2 of 2
      • Use a spudger to lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
      Ask FixBot
    1. MacBook Pro 15" Touch Bar 2018 Screen Replacement, Screen: step 17, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement, Screen: step 17, image 2 of 2
      • Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
      • Remove the display board flex cover.
      Ask FixBot
    2. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 18, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 18, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.7 mm screws securing the bracket for the display board cable connector.
      • Remove the display board cable connector bracket.
      Ask FixBot
    3. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 19, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 19, image 2 of 2
      • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
      Ask FixBot
    4. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 20, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 20, image 2 of 2
      • Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
      Ask FixBot
    5. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 21, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 21, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 21, image 3 of 3
      • Remove both hinge covers.
      Ask FixBot
    6. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 22, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 22, image 2 of 2
      • Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
      Ask FixBot
    7. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 23, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 23, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 23, image 3 of 3
      Buy
      • Disconnect all three antenna cables by prying each one straight up from its socket.
      • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
      • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
      Ask FixBot
    8. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 24, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 24, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 24, image 3 of 3
      • Use a T5 Torx driver to remove the four 3.3 mm screws securing the display board.
      • Before reinstalling these screws:
      • Make sure the display board flex cable lies on top of the board, not trapped underneath.
      Ask FixBot
    9. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 25, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 25, image 2 of 2
      • Use a P2 Pentalobe driver to remove the sixteen 1.5 mm screws securing the antenna assembly.
      Ask FixBot
    10. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 26, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 26, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 26, image 3 of 3
      • Use an opening pick to pry up the antenna assembly and separate it from the MacBook Pro.
      • Watch out for the delicate ribbon cables in the middle section. Avoid sliding the pick from side to side so as not to damage the cables.
      Ask FixBot
    11. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 27, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 27, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 27, image 3 of 3
      • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
      • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
      Ask FixBot
    12. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 28, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 28, image 2 of 2
      • Use a T3 Torx driver to remove the four 3.9 mm screws securing the display cable cover springs.
      Ask FixBot
    13. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 29, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 29, image 2 of 2
      • Use a T8 Torx driver to remove two 4.9 mm screws from each hinge (four screws total).
      • Each hinge has a third screw, which you should leave in place for now.
      Ask FixBot
    14. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 30, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 30, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 30, image 3 of 3
      • During reassembly, first install the hinge screws without tightening them. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
      • If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
      • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
      Ask FixBot
    15. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 31, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 31, image 2 of 2
      • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following step.
      • Fully open the screen and stand your MacBook Pro up on one side.
      Ask FixBot
    16. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 32, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 32, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 32, image 3 of 3
      • Use a T8 Torx driver to remove the two remaining 4.9 mm hinge screws (one from each hinge).
      • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
      Ask FixBot
    17. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 33, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 33, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 33, image 3 of 3
      • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
      • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
      • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
      Ask FixBot
    18. MacBook Pro 15" Touch Bar 2018 Screen Replacement: step 34, image 1 of 1
      • Remove the screen.
      Ask FixBot
45 other people completed this guide.
Jeff Suovanen
455,213 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,907 Guides authored
28 Guide Comments
where can I purchase an lcd screen for this computer?
Ron Glines - Reply Share
hai jeff. Is that possible I can revive my screen not to buy a new one, instead of replacing 3 pairs of flexible cable? thanks
endyk novianto - Reply Share
To reiterate Ron’s request - you’ve shown me how to fix the screen (thank you!) without showing me where/how to purchase the replacement?
John Capehart - Reply Share
Banggodd or AliExpress but ta
Apple sry to get a genuine Apple screen as ‘compatibles’ may not pass in built Apple security- more expensive but can save a lot of heartache and later expense.
Terence Dixon - Reply Share
Pleeeaaase I really need to know where I can purchase a new screen like this one
Vico - Reply Share
Past 24 Hours: 30
Past 7 Days: 147
Past 30 Days: 641
All Time: 111,664
