MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement
Views: 45K
View statistics:
Past 24 Hours:
11
Past 7 Days:
133
Past 30 Days:
556
All Time:
44,975
Comments: 74
67 comments on steps, 7 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the display assembly of your MacBook Pro 13" Touch Bar 2019.
For your safety, drain your MacBook Pro's battery below 25% charge before starting repairs.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disable Auto Boot: step 1, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disable Auto Boot: step 1, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disable Auto Boot: step 1, image 3 of 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      Ask FixBot
    1. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Remove the lower case: step 2, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Before you proceed, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.2 mm screws
      • Two 5.3 mm screws
      • Two 3.4 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 3, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 3, image 2 of 2
      • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
      • Lift the suction handle to create a slight separation between the lower case and the chassis.
      Ask FixBot
    3. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 4, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 4, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 4, image 3 of 3
      • Insert one corner of an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the nearest corner and halfway up the side of the case.
      • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 5, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 5, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 5, image 3 of 3
      • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
      Ask FixBot
    5. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 6, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 6, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 6, image 3 of 3
      • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
      • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
      • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
      Ask FixBot
    6. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 7, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 7, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 7, image 3 of 3
      • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • It may help to pull first at one corner, then the other.
      • Pull to the side—not up.
      • This may require a lot of force.
      Ask FixBot
    7. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 8, image 1 of 1
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      Ask FixBot
    1. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disconnect the battery: step 9, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disconnect the battery: step 9, image 2 of 2
      • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
      • Remove the tape.
      Ask FixBot
    2. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 10, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 10, image 2 of 2
      • Gently peel back the small piece of tape covering the battery board data cable connector.
      • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
      Ask FixBot
    3. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 11, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 11, image 2 of 2
      • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
      • Locking tabs on ZIF connectors are fragile, so be gentle when using the tip of the spudger.
      Ask FixBot
    4. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 12, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 12, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket.
      • Slide parallel to the logic board, in the direction of the cable.
      Ask FixBot
    5. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 13, image 1 of 1
      • Fold the battery board data cable back and out of the way.
      • If you're replacing your battery, you may need to completely remove and transfer this cable to your new battery. Disconnect both ends and carefully remove the cable. During installation, be careful not to install it upside-down or backwards—note the orientation in the photos.
      Ask FixBot
    6. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 14, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 14, image 2 of 2
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      Ask FixBot
    7. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 15, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 15, image 2 of 2
      • Use a spudger to gently lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough so that it stays separated from its socket.
      • If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
      Ask FixBot
    1. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Remove the antenna cable assembly: step 16, image 1 of 1
      • Remove the four 3.3 mm T3 Torx screws securing the plastic covers on top of the display hinges.
      Ask FixBot
    2. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 17, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 17, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 17, image 3 of 3
      • Remove both plastic hinge covers.
      Ask FixBot
    3. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 18, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 18, image 2 of 2
      • Remove the two 3.1 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
      • Remove the cover.
      Ask FixBot
    4. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 19, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 19, image 2 of 2
      • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
      • Remove the cover.
      Ask FixBot
    5. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 20, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 20, image 2 of 2
      • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
      Ask FixBot
    6. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 21, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 21, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 21, image 3 of 3
      Buy
      • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
      • Use a pair of tweezers to remove the two aluminum covers.
      Ask FixBot
    7. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 22, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 22, image 2 of 2
      • Remove the four 3.3 mm T5 Torx screws on both sides, which secure the antenna cable assembly.
      • Also remove the twelve 1.1 mm P2 pentalobe screws on both sides.
      • These small screws can strip easily, so make sure your P2 pentalobe driver is in good condition before applying pressure.
      Ask FixBot
    8. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 23, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 23, image 2 of 2
      • Carefully disconnect the two antenna coax cables by prying them straight up from the logic board.
      • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
      • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
      Ask FixBot
    9. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 24, image 1 of 1
      • Remove the 3.4 mm T5 Torx screw securing the two antenna coax cables to the main board.
      Ask FixBot
    10. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 25, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 25, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 25, image 3 of 3
      • Use an opening pick to lever out the antenna cable assembly in the areas shown.
      • Don't slide the opening pick from side to side, because there are two display cables that can be damaged.
      Ask FixBot
    11. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 26, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 26, image 2 of 2
      • Carefully remove the antenna assembly while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
      Ask FixBot
    12. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 27, image 1 of 1
      • Remove the antenna cable assembly.
      • During reassembly, gently pinch the cable bundle together and guide it under the frame into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
      Ask FixBot
    1. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Remove the display assembly: step 28, image 1 of 1
      • Remove the four 3.9 mm T3 Torx screws securing the spring hinges of the two display cables.
      Ask FixBot
    2. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 29, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 29, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 29, image 3 of 3
      Buy
      • Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the spring hinge.
      • Use a pair of tweezers to pull the spring hinge of the display cable out of its bracket.
      • Repeat this step with the right spring hinge of the display cable assembly.
      Ask FixBot
    3. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 30, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 30, image 2 of 2
      • Fully open the screen and stand your MacBook Pro up on one side.
      • While steadying the MacBook pro with your free hand, remove the three T8 Torx screws from the lower display hinge.
      • Remove the remaining three T8 Torx screws from the upper display bracket.
      Ask FixBot
    4. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 31, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 31, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: step 31, image 3 of 3
      • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
      • Push both halves of the MacBook Pro together so that the hinge brackets can be lifted clear of their recesses in the chassis.
      • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
      • Remove the display/screen assembly, being careful not to snag it on any cables.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
20 other people completed this guide.
Carsten Frauenheim
173,822 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
120 Members
72,955 Guides authored
7 Guide Comments
Un tout grand merci!
vpirart - Reply Share
Are these the same steps for the 2020?
Axel - Reply Share
After replacing the display, the display works fine but the touch bar can’t work. Anyone comes across the same problem or have any idea what’s going on?
VincentZ - Reply Share
Why does the guide suggest purchasing the "MacBook Pro 13" Retina (A1708, A2159) Display Cable "
Richard Ness - Reply Share
Replaced my display with a genuine used panel and the true tone still worked. However, be very careful of the touchbar flex.
Tain Peacock - Reply Share
Past 24 Hours: 11
Past 7 Days: 133
Past 30 Days: 556
All Time: 44,975
