MacBook Pro 13" Touch Bar 2017 Screen Replacement
    1. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Disable Auto Boot: step 1, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Disable Auto Boot: step 1, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Disable Auto Boot: step 1, image 3 of 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      Ask FixBot
    1. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the pentalobe screws: step 2, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.2 mm screws
      • Four 3.4 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Open a gap using a suction cup: step 3, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Open a gap using a suction cup: step 3, image 2 of 2
      • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
      • Lift the suction handle to create a slight gap between the lower case and the chassis.
      Ask FixBot
    3. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Separate the clips: step 4, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Separate the clips: step 4, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Separate the clips: step 4, image 3 of 3
      • Insert one corner of an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the nearest corner and halfway up the side of the case.
      • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 5, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 5, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 5, image 3 of 3
      • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
      Ask FixBot
    5. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 6, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 6, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 6, image 3 of 3
      • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
      • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
      • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
      Ask FixBot
    6. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 7, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 7, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 7, image 3 of 3
      • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • Pull first at one corner, then the other.
      • Pull to the side—not up.
      • This can require a lot of force.
      Ask FixBot
    7. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the lower case: step 8, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the lower case: step 8, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the lower case: step 8, image 3 of 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      Ask FixBot
    1. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Uncover the battery connector: step 9, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Uncover the battery connector: step 9, image 2 of 2
      • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
      • Remove the tape.
      Ask FixBot
    2. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 10, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 10, image 2 of 2
      • Gently peel back the small piece of tape covering the battery board data cable connector.
      • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
      Ask FixBot
    3. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 11, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 11, image 2 of 2
      • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
      Ask FixBot
    4. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 12, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 12, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket.
      • Slide parallel to the logic board, in the direction of the cable.
      Ask FixBot
    5. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 13, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 13, image 2 of 2
      • Fold the battery board data cable to the side and out of the way.
      Ask FixBot
    6. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 14, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 14, image 2 of 2
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      Ask FixBot
    7. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Disconnect the battery: step 15, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Disconnect the battery: step 15, image 2 of 2
      • Use a spudger to gently lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
      Ask FixBot
    1. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Antenna Cable Assembly: step 16, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Antenna Cable Assembly: step 16, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Antenna Cable Assembly: step 16, image 3 of 3
      • Remove the four 1.9 mm T3 Torx screws securing the plastic covers on top of the display hinges.
      • Remove both plastic hinge covers.
      Ask FixBot
    2. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 17, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 17, image 2 of 2
      • Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
      • Remove the cover.
      Ask FixBot
    3. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 18, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 18, image 2 of 2
      • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
      • Remove the cover.
      Ask FixBot
    4. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 19, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 19, image 2 of 2
      • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
      Ask FixBot
    5. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 20, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 20, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 20, image 3 of 3
      Buy
      • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
      • Use a pair of tweezers to remove the two aluminium covers.
      Ask FixBot
    6. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 21, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 21, image 2 of 2
      • Remove the four 3.9 mm T5 Torx screws (two from each side) securing the antenna cable assembly.
      • Also remove the twelve 1.1 mm P2 pentalobe screws (six from each side).
      Ask FixBot
    7. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 22, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 22, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 22, image 3 of 3
      • Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
      • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
      • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
      Ask FixBot
    8. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 23, image 1 of 1
      • Remove the 2.8 mm T5 Torx screw securing the three antenna coax cables to the main board.
      Ask FixBot
    9. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 24, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 24, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 24, image 3 of 3
      • Use an opening pick to lever out the antenna cable assembly in the areas shown.
      • Don't slide the opening pick from side to side, because there are two display cables that can be damaged.
      Ask FixBot
    10. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 25, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 25, image 2 of 2
      • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
      Ask FixBot
    11. MacBook Pro 13" Touch Bar 2017 Screen Replacement: step 26, image 1 of 1
      • Remove the antenna cable assembly.
      • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
      Ask FixBot
    1. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Unscrew the display cable assembly: step 27, image 1 of 1
      • Remove the four 3.9 mm T3 Torx screws securing the two display cable cover springs.
      Ask FixBot
    2. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the display cable assembly: step 28, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the display cable assembly: step 28, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the display cable assembly: step 28, image 3 of 3
      Buy
      • Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the cover spring.
      • Use a pair of tweezers to pull the cover spring of the display cable out of its recess.
      • Repeat this step with the right cover spring of the display cable assembly.
      Ask FixBot
    3. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Set your laptop down: step 29, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Set your laptop down: step 29, image 2 of 2
      • Fully open your MacBook and gently place it keyboard-side-down on a table so the screen hangs over the edge.
      Ask FixBot
    4. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the hinge screws: step 30, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the hinge screws: step 30, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the hinge screws: step 30, image 3 of 3
      • Support the screen with one hand and use your free hand to remove the six T8 Torx screws securing the hinges.
      • Keep a firm grip on your laptop, as it can easily fall off the table.
      Ask FixBot
    5. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Free the left hinge: step 31, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Free the left hinge: step 31, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Free the left hinge: step 31, image 3 of 3
      • Keep the screen supported constantly during the next two steps.
      • Firmly secure the main body of your MacBook with one hand.
      • With your free hand, push the left side of the screen up and towards the bottom of your laptop to free the left hinge.
      • Be very careful not to damage the Touch Bar connector when moving the left hinge. It can be easily crushed, resulting in an inoperable Touch Bar.
      Ask FixBot
    6. MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the screen: step 32, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the screen: step 32, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Screen Replacement, Remove the screen: step 32, image 3 of 3
      • Free the right hinge and remove the screen.
      • During reassembly:
      • Make sure the screen hinges are fully open and guide them into their recesses in the frame.
      • Be very careful not to damage the Touch Bar connector when inserting the left hinge.
      • Partially tighten the six hinge screws.
      • Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
      • Fully tighten the hinge screws.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
98 other people completed this guide.
Nicholas H. of Experimac
2,412 Reputation
2 Guides authored
34 Guide Comments
What is the ribbon cable that you must remove before disconnecting the battery do?
Max4r - Reply Share
your mom.
all joking aside, its the communication between the logic board and the battery controller (cycle count, battery health etc)
Joe Jankins - Reply Share
What is the exact P2 bit you need to remove the 12 screws holding the antenna bar? I ordered a P2 bit on Amazon that says it’s 0.8mm P2 bit and it’s too big. Not sure if they shipped me the wrong one or what. Been trying to find out exactly what bit to use and no luck so far.
Tyson Roehrkasse - Reply Share
Pentalobe P1L from Wiha tools fits perfectly.
Robin Ray - Reply Share
What about the display ribbon cable ?
I have a bad cable and don’t want to spend 400 on display assy when the cable is available on this site for 25
Robin Bonathan - Reply Share
Past 24 Hours: 38
Past 7 Days: 193
Past 30 Days: 864
All Time: 221,204
