Community-Contributed Guide
Introduction
Go to step 1 ↓WARNING: This is a challenging repair, involving micro soldering, and cutting cables inside your macbook. Only attempt if you are sure that this is possible for you, or you have no other hope. This repair is a marathon, and can take many hours of very delicate surgical work (good practice for open heart probably)
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Tool used on this step:Magnetic Project Mat$16.96
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.2 mm screws
Two 5.3 mm screws
Two 3.4 mm screws
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Remove the four 1.9 mm T3 Torx screws securing the plastic covers on top of the display hinges.
Remove both plastic hinge covers.
Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
Remove the cover.
Tool used on this step:Tweezers$4.99
Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cables.
Use a pair of tweezers to remove the two aluminium covers.
Remove the two 3.3 mm T5 Torx screws (one from each side) securing the antenna cable assembly.
Also remove the two 4.1 mm T5 Torx screws (one from each side).
Remove the twelve 1.1 mm P2 pentalobe screws (six from each side) securing the rest of the antenna cable assembly.
Carefully disconnect the two antenna coax cables by prying them straight up from the logic board.
Slide your tweezers or spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
Use an opening pick to lever out the antenna cable assembly in the areas shown.
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle through the hole in the chassis.
Remove the four 3.9 mm T3 Torx screws securing the cover springs on the two display cables.
Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the cover spring.
Use a pair of tweezers to pull the cover spring on the display cable out of its recess.
Repeat this step with the right cover spring.
While steadying the MacBook pro with your free hand, remove the three T8 Torx screws from the lower display hinge.
Remove the remaining three T8 Torx screws from the upper display bracket.
Push both halves of the MacBook Pro together so that the hinge brackets can be lifted clear of their recesses in the chassis.
Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
Remove the display/screen assembly, being careful not to snag it on any cables.
Identify the backlight flex cable and bend it looking for breaks
Breaks look like sharp bends in the cable - if unbroken, i should bend in a smooth arc
Cut the new cable so it can cover the distance past the break in the original cable
Add a few millimeters for buffer, and so that the final cable is 1.5-2mm longer than it was originally - this is the fix that future mac books used to prevent this issue in the first place
Tape the new cable, and begin to scrape off the solder mask
Use a hobby knife with a fresh blade, or a fiberglass pencil to expose a few mm of trace.
Using some light heat from a hot air gun can help with this step
Cut it just behind the break. Try and cut as straight as possible - this will allow the joint to be as clean and easy as possible.
Use a fresh razor blade, or utility blade to press straight down on the cable
I have attached a picture of my setup, as it can be tricky to work on. Find something to sit under the cable - I used a 5mm glass plate
Same as the new cable, tape the cable down, and scrape away a few mm of solder mask.
Be gentle - and use heat if needed. this coating can be tough. A fiberglass pencil is highly recommended
Tape them down securely
Make sure that they are flat and clean
Green: Ground
Red: Power
Yellow: Signal (current return)
You don't need jumpers for the thicker traces, it is possible to gently flood them with solder, and bridge across
NOTE: Be quick with your iron, you don't want to melt the cable too bad - I set my iron to 450c and had the thinnest tip I could find in the lab.
The outermost traces are ground, the two thicker traces are backlight power and ground, and the thin traces are backlight return for current sensing
NOTE: it should work to bridge all the thinner cables together, but the backlight sensing will not work properly. I am not sure what the ramifications of this are but your backlight should still function.
Using a very fine un coated magnet wire, Affix one end to the old connector, and then bridge it down to the new connector.
I used the internal strands of a very fine multi strand wire, but this is not ideal. Ideally use pure copper magnet wire, as it will be the easiest to solder
Try not to put too much heat into the cables, just melt the solder you tinned onto the pads
Check for bridges with a multimeter in continuity mode
Trying to avoid bridging the power and ground - ultimately nothing should be bridged.
If a connection is bridged you can use solder wick to pull up some solder, and that may be enough to separate the traces
Using a silicone conformal coating, or any dielectric coating (I was in a pinch and only had access to a nail polish for this step - not ideal but works in a pinch) coat the connection and allow to dry.
Put on 2-3 coats on both sides
