MacBook Pro 13" 2022 (M2) Headphone Jack Replacement
    1. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Prepare your MacBook for disassembly: step 1, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Prepare your MacBook for disassembly: step 1, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Prepare your MacBook for disassembly: step 1, image 3 of 3
      • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug all cables and fully shut down your MacBook.
      • Close the lid and flip your MacBook over. Keep the lid closed until you've physically disconnected the battery.
      • Opening the lid will power on your MacBook. If you're using macOS Big Sur v11.1 or earlier, disable this function using this guide.
      Ask FixBot
    1. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Unfasten the lower case: step 2, image 1 of 1
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.8 mm screws
      • Two 5.3 mm screws
      • Two 3.4 mm screws
      Ask FixBot
    2. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Separate the lower case: step 3, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Separate the lower case: step 3, image 2 of 2
      • Apply a suction handle near the front edge of the lower case, between the screw holes.
      • Pull up on the suction handle to create a gap between the lower case and the frame.
      Ask FixBot
    3. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the left clips: step 4, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the left clips: step 4, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the left clips: step 4, image 3 of 3
      • Insert an opening pick between the lower case and the frame.
      • Slide the pick around the left corner to release the first set of clips.
      • You'll hear and feel a pop when each clip releases.
      Ask FixBot
    4. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the right clips: step 5, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the right clips: step 5, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the right clips: step 5, image 3 of 3
      • Slide your opening pick around the right corner to release the second set of clips securing the lower case.
      Ask FixBot
    5. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Pry the lower case up: step 6, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Pry the lower case up: step 6, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Pry the lower case up: step 6, image 3 of 3
      • Insert your opening pick between the lower case and the frame near the middle left screw hole.
      • Firmly twist the pick until the clip releases.
      • Repeat this procedure for the clip near the middle right screw hole.
      Ask FixBot
    6. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the remaining clips: step 7, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the remaining clips: step 7, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Release the remaining clips: step 7, image 3 of 3
      • Firmly pull the lower case away from the screen hinges to release the last clips securing it to the frame.
      • This motion requires significant force. Don't pull the lower case up, as you may bend the clips.
      • If it feels stuck, pull one corner at a time.
      Ask FixBot
    7. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the lower case: step 8, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the lower case: step 8, image 2 of 2
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinges. Press down and slide the lower case toward the hinges.
      • Once the lower case is secured near the hinges, press down firmly to engage the remaining four clips.
      • You'll hear and feel a pop when each clip engages.
      Ask FixBot
    1. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the battery board cover: step 9, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the battery board cover: step 9, image 2 of 2
      Buy
      • Use blunt nose tweezers or your fingers to peel and remove the cover from the battery board, just above the middle battery cell.
      Ask FixBot
    2. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the battery data cable: step 10, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the battery data cable: step 10, image 2 of 2
      • Use blunt nose tweezers to gently peel back the pull tab covering the battery data connector.
      • Don't remove or tear the pull tab, as it's attached to the head of the connector.
      Ask FixBot
    3. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement: step 11, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement: step 11, image 2 of 2
      • Use the point of a spudger to flip up the small locking tab securing the battery data connector.
      • Locking tabs on ZIF connectors are fragile—be gentle with your spudger.
      Ask FixBot
    4. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement: step 12, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement: step 12, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement: step 12, image 3 of 3
      • Use blunt nose tweezers or your fingers to grab the battery data cable pull tab and slide it straight out of its socket.
      • Move the cable to the left, out of the way of the battery board.
      • Don't strain the cable, as it's still attached to the battery board.
      Ask FixBot
    5. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Unfasten the battery connector: step 13, image 1 of 1
      • Use a T5 Torx driver to remove the 3.7 mm screw securing the battery connector.
      Ask FixBot
    6. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the battery: step 14, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the battery: step 14, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the battery: step 14, image 3 of 3
      • Use the flat end of your spudger to slightly lift the battery connector away from the battery board.
      • Lifting the connector too high will break it. Angle it enough so it won't accidentally contact the battery board during repair.
      • Optionally, you may insert a barrier, such as a piece of a playing card, between the connector and the board during the repair.
      Ask FixBot
    1. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the left cable bracket: step 15, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the left cable bracket: step 15, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the left cable bracket: step 15, image 3 of 3
      • Use your T5 Torx driver to remove the two screws securing the left cable bracket to the logic board:
      • One 3.6 mm screw
      • One 2.6 mm screw
      • Remove the bracket.
      Ask FixBot
    2. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the interconnect cable: step 16, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the interconnect cable: step 16, image 2 of 2
      • Use the flat end of your spudger to pry up and disconnect the left interconnect cable.
      Ask FixBot
    3. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the antenna cable cover: step 17, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the antenna cable cover: step 17, image 2 of 2
      • Peel and remove the plastic cover from the antenna cables.
      Ask FixBot
    4. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the antenna bar: step 18, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the antenna bar: step 18, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the antenna bar: step 18, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the antenna cables from the logic board.
      • Pry on the metal head of the connector. Avoid lifting the cable itself as much as possible.
      • To reconnect the cables, align the connectors directly over their sockets and press down with the flat end of a spudger until they snap into place.
      Ask FixBot
    5. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Unfasten the antenna cables: step 19, image 1 of 1
      • Use your T5 Torx driver to remove the 3.4 mm screw securing the antenna cables to the logic board.
      Ask FixBot
    6. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the logic board: step 20, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the logic board: step 20, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the logic board: step 20, image 3 of 3
      • Use the point of a spudger to flip up the small locking tab securing the right speaker connector.
      • Grab the pull tab on the head of the cable and slide it straight out of its socket.
      Ask FixBot
    7. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the trackpad cable bracket: step 21, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the trackpad cable bracket: step 21, image 2 of 2
      • Use your T5 Torx driver to remove the two 1.9 mm screws securing the trackpad cable bracket.
      Ask FixBot
    8. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the trackpad: step 22, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the trackpad: step 22, image 2 of 2
      • Use the flat end of your spudger to pry up and disconnect the trackpad cable from the logic board.
      Ask FixBot
    9. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement: step 23, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement: step 23, image 2 of 2
      • Disconnect the seven remaining ZIF connectors from the logic board by lifting their locking tabs and pulling them straight out of their sockets.
      Ask FixBot
    10. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the right cable bracket: step 24, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the right cable bracket: step 24, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the right cable bracket: step 24, image 3 of 3
      • Use your T3 Torx driver to remove the three 1.4 mm screws securing the cable bracket to the top right of the logic board.
      Ask FixBot
    11. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the top right press connectors: step 25, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the top right press connectors: step 25, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the top right press connectors: step 25, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the Touch Bar press connector from the top right of the logic board.
      • Repeat this step for the lid angle sensor and the Thunderbolt ports press connectors.
      Ask FixBot
    12. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the top left cable cover: step 26, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the top left cable cover: step 26, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the top left cable cover: step 26, image 3 of 3
      • Use your T3 Torx driver to remove the two screws securing the cable cover near the headphone jack:
      • One 1.4 mm screw
      • One 4.9 mm screw
      • Remove the cover.
      Ask FixBot
    13. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Unfasten the logic board: step 27, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Unfasten the logic board: step 27, image 2 of 2
      • Remove the five screws securing the logic board:
      • One 3.0 mm hex head screw
      • One 3.7 mm T5 Torx screw
      • Three 3.3 mm T5 Torx screws
      Ask FixBot
    14. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Reassembly information: step 28, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Reassembly information: step 28, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Reassembly information: step 28, image 3 of 3
      Buy
      • Your 3.0 mm nut driver may be too long to thread the hex head screw in. Use one of the following techniques to begin threading the screw in:
      • Thread the screw in using your fingertips.
      • Thread the screw in using blunt nose tweezers.
      • Use your T3 Torx driver to install the 1.4 mm screw into the hex head screw. Then, install the hex head screw using the T3 Torx driver. Finally, hold the hex head screw while you remove the 1.4 mm screw.
      • Once the hex head screw is threaded in a few turns, tighten it using your nut driver.
      Ask FixBot
    15. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Pry up the logic board: step 29, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Pry up the logic board: step 29, image 2 of 2
      • Insert the point of your spudger between the bottom left of the logic board and the left speaker assembly.
      • Pry up on the logic board until you can grab it with your fingers.
      Ask FixBot
    16. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the logic board: step 30, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the logic board: step 30, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the logic board: step 30, image 3 of 3
      • Grip the bottom left edge of the logic board.
      • Pull the logic board down and left to free it from the press connectors and antenna cables in the upper right corner.
      • Lift the logic board out of its recess, making sure not to catch on any loose cables.
      • During reassembly, make sure all 15 connectors are above the logic board before reinstalling it.
      Ask FixBot
    1. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Unfasten the left speaker: step 31, image 1 of 1
      • Use your T5 Torx driver to remove the three 2.8 mm screws securing the left speaker.
      • The screws are held in place by rubber spacers. If you can't remove them, just make sure they are fully loosened.
      Ask FixBot
    2. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Pry up the left speaker: step 32, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Pry up the left speaker: step 32, image 2 of 2
      • Insert the point of your spudger between the right edge of the left speaker and the frame.
      • Pry the speaker out of its recess in the frame.
      Ask FixBot
    3. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the left speaker: step 33, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the left speaker: step 33, image 2 of 2
      • Grab the right edge of the left speaker with your fingers.
      • Remove the speaker.
      Ask FixBot
    4. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Reassembly information: step 34, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Reassembly information: step 34, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Reassembly information: step 34, image 3 of 3
      • The rubber spacers might stay on their screw posts in the frame when you remove the speakers.
      • Before reinstalling the speakers, follow these instructions to ensure the rubber spacers are in the speaker screw holes and not on the frame:
      • Orient each rubber spacer so the smooth side is poking out the underside of the speaker.
      • Insert one side of the spacer through the bottom of its screw hole.
      • Use the point of a spudger to press the spacer into its slot.
      Ask FixBot
    5. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the headphone jack board: step 35, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the headphone jack board: step 35, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Disconnect the headphone jack board: step 35, image 3 of 3
      • Use the point of your spudger to pry up and disconnect the press connector from the headphone jack board.
      • Reposition the cable away from the board.
      Ask FixBot
    6. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Loosen the board cable: step 36, image 1 of 2 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Loosen the board cable: step 36, image 2 of 2
      • The interconnect cable is secured with light adhesive.
      • Separate the cable from the left fan.
      Ask FixBot
    7. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Soften the adhesive: step 37, image 1 of 1
      • Apply highly-concentrated isopropyl alcohol (over 90%) to the section of cable under the headphone jack.
      • Wait one minute for the isopropyl alcohol to soften the adhesive.
      Ask FixBot
    8. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Peel the cable: step 38, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Peel the cable: step 38, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Peel the cable: step 38, image 3 of 3
      Buy
      • Use blunt nose tweezers to grab the upper section of cable adhered to the frame.
      • Slowly lift the cable straight up to loosen it from the frame.
      • Don't force or twist the cable. If it feels stuck, apply more isopropyl alcohol and try again.
      • Grab the bottom of the cable and peel it from the frame, making sure to avoid the circuitry on the cable.
      • During reassembly, use the alignment peg on the frame to orient the cable.
      Ask FixBot
    9. MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the headphone jack: step 39, image 1 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the headphone jack: step 39, image 2 of 3 MacBook Pro 13" 2022 (M2) Headphone Jack Replacement, Remove the headphone jack: step 39, image 3 of 3
      • Grab the right edge of the headphone jack board.
      • Angle the board up and slide it out of its recess to remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Clay Eickemeyer
107,337 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,532 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 76
All Time: 2,063
