MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement
  1. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the screws securing the lower case: step 1, image 1 of 1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    Ask FixBot
  2. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the lower case: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
    Ask FixBot
  3. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the battery: step 3, image 1 of 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
    Ask FixBot
  4. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 4, image 1 of 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 4, image 2 of 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
    Ask FixBot
  5. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the right speaker: step 5, image 1 of 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the right speaker: step 5, image 2 of 2
    • Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
    Ask FixBot
  6. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the audio board: step 6, image 1 of 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the audio board: step 6, image 2 of 2
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
    • Remove the cable bracket.
    Ask FixBot
  7. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 7, image 1 of 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 7, image 2 of 2
    • Use the flat end of a spudger to pry the audio board connector straight up and disconnect it.
    Ask FixBot
  8. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 8, image 1 of 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 8, image 2 of 2
    • Use the flat end of a spudger to pry the Touch ID sensor connector straight up and disconnect it.
    Ask FixBot
  9. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the audio board: step 9, image 1 of 1
    • Remove the following screws:
    • Two 4.3 mm, T5 Torx screws
    • One 2.4 mm, T3 Torx screw
    Ask FixBot
  10. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 10, image 1 of 1
    • Slide the flat end of a spudger underneath the Touch ID sensor cable to slice through the adhesive securing it to the audio board.
    Ask FixBot
  11. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 11, image 1 of 1
    • Remove the audio board.
    Ask FixBot
  12. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the Touch ID sensor: step 12, image 1 of 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the Touch ID sensor: step 12, image 2 of 2
    • Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
    • Remove the Touch ID bracket.
    Ask FixBot
  13. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: step 13, image 1 of 1
    • Turn the MacBook right-side up and open the display.
    • Lift the Touch ID sensor sensor out of its recess and remove it.
    Ask FixBot
10 other people completed this guide.
Adam O'Camb
223,844 Reputation
416 Guides authored
4 Guide Comments
Hold on so you can replace the touch id but you wont be able to use it? lol kind of redundant if you ask me.
Hamdi Hoxha - Reply Share
Does one need to replace the adhesive, and if so, what is the adhesive and how is it applied? Thanks.
wadeb - Reply Share
Can you still use the power button with a touch id replacement?
Nathan Morris - Reply Share
yes, it will power the machine up!
Bugembe Kenson - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 104
All Time: 12,238
