MacBook Air 13" Late 2020 Lower Case Replacement
  1. MacBook Air 13" Late 2020 Lower Case Replacement, Remove the screws securing the lower case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    Ask FixBot
  2. MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: step 2, image 1 of 3 MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: step 2, image 2 of 3 MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: step 2, image 3 of 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    Ask FixBot
6 other people completed this guide.
Carsten Frauenheim
167,268 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
1 Guide Comment
Hi, I accidentally stripped one of the female thread in the chassis what can I do to fix this? as the screw won't stay in place/screw in
TheTechDisassembler24 - Reply Share
Past 24 Hours: 13
Past 7 Days: 102
Past 30 Days: 426
All Time: 31,289
