MacBook Air 13" Early 2020 Audio Board Replacement
  1. MacBook Air 13" Early 2020 Audio Board Replacement, Remove the screws securing the lower case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    Ask FixBot
  2. MacBook Air 13" Early 2020 Audio Board Replacement, Remove the lower case: step 2, image 1 of 3 MacBook Air 13" Early 2020 Audio Board Replacement, Remove the lower case: step 2, image 2 of 3 MacBook Air 13" Early 2020 Audio Board Replacement, Remove the lower case: step 2, image 3 of 3
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    Ask FixBot
  3. MacBook Air 13" Early 2020 Audio Board Replacement, Disconnect the battery: step 3, image 1 of 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
    Ask FixBot
  4. MacBook Air 13" Early 2020 Audio Board Replacement: step 4, image 1 of 2 MacBook Air 13" Early 2020 Audio Board Replacement: step 4, image 2 of 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
    Ask FixBot
  5. MacBook Air 13" Early 2020 Audio Board Replacement, Disconnect the right speaker: step 5, image 1 of 2 MacBook Air 13" Early 2020 Audio Board Replacement, Disconnect the right speaker: step 5, image 2 of 2
    • Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
    Ask FixBot
  6. MacBook Air 13" Early 2020 Audio Board Replacement, Disconnect the audio board: step 6, image 1 of 2 MacBook Air 13" Early 2020 Audio Board Replacement, Disconnect the audio board: step 6, image 2 of 2
    • Use a T4 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • Remove the audio board connector cover.
    Ask FixBot
  7. MacBook Air 13" Early 2020 Audio Board Replacement: step 7, image 1 of 2 MacBook Air 13" Early 2020 Audio Board Replacement: step 7, image 2 of 2
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Ask FixBot
  8. MacBook Air 13" Early 2020 Audio Board Replacement: step 8, image 1 of 3 MacBook Air 13" Early 2020 Audio Board Replacement: step 8, image 2 of 3 MacBook Air 13" Early 2020 Audio Board Replacement: step 8, image 3 of 3
    • Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
    • Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
    • The Touch ID cable is secured to the audio board with some light adhesive.
    Ask FixBot
  9. MacBook Air 13" Early 2020 Audio Board Replacement, Remove the audio board: step 9, image 1 of 1
    • Remove the three screws securing the audio board:
    • Two 4.3 mm T4 Torx screws
    • One 2.4 mm T3 Torx screw
    Ask FixBot
  10. MacBook Air 13" Early 2020 Audio Board Replacement: step 10, image 1 of 1
    • Remove the audio board.
    Ask FixBot
3 other people completed this guide.
Carsten Frauenheim
167,350 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
1 Guide Comment
Can anybody provide me with the capaciter value of the cap next to the audo flex connecter? Its right under the right bottom screw in step #6
Saihood - Reply Share
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 87
All Time: 5,144
