Introduction
Use this guide to replace the top cover on your MNT Pocket Reform laptop.
If the top cover of your Pocket Reform is scratched or damaged, you may want to replace it. You can find specs to make your own bottom cover on MNT's documentation page.
Note: The top cover is made of PCB material and acts as the heat sink. Your replacement top cover must have similar thermal properties to ensure the laptop's heat is managed properly.
The top cover must also be thermally connected to the processor. Therefore, you will need to apply a thermal pad to the new top cover. You can either apply a new thermal pad or transfer the old thermal pad if it's in good condition.
Place the laptop on your work surface so the top cover with the MNT logo is facing up.
Use a Phillips screwdriver to remove the seven 4.8 mm‑long screws securing the top cover.
Use a pair of tweezers or your fingers to carefully peel the thermal pad off of the old cover.
