Introduction
Go to step 1 ↓Use this guide to replace the thermal pad in your MNT Pocket Reform laptop.
If your laptop is overheating, or if your thermal pad is damaged during a repair, you may need to replace your thermal pad.
The thermal pad should be 2 mm thick.
Parts
Tools
Place the laptop on your work surface so the top cover with the MNT logo is facing up.
Use a Phillips screwdriver to remove the seven 4.8 mm‑long screws securing the top cover.
Use tweezers or your fingers to peel up the old thermal pad.
Use high concentration (greater than 90%) isopropyl alcohol and a coffee filter or a lint-free cloth to clean the processor and the area of the top cover that will contact the thermal pad.
Peel the backing off of one side of the thermal pad.
Apply the thermal pad to the processor, which is the large chip on the processor module that sits on top of the motherboard.
Peel the backing off of the other side of the thermal pad.
