MNT Pocket Reform Speaker Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
54
All Time:
282
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the speaker in your MNT Pocket Reform laptop.
If your laptop's sound is distorted or not playing, you may need to replace the speaker.
Tools
    1. MNT Pocket Reform Speaker Replacement, Shut down the laptop: step 1, image 1 of 3 MNT Pocket Reform Speaker Replacement, Shut down the laptop: step 1, image 2 of 3 MNT Pocket Reform Speaker Replacement, Shut down the laptop: step 1, image 3 of 3
      • If you've installed an operating system, follow the appropriate steps to safely shut down the laptop.
      • If you've not yet installed an operating system, or the laptop is not responsive, you can shut it down with these steps:
      • Turn on the OLED screen by pressing the Hyper key (diagonal arrow) and Enter at the same time.
      • Use the arrow keys to select Power Off on the OLED screen.
      • Press Enter to shut down the laptop.
      • Disconnect all cables from the laptop.
      Ask FixBot
    2. MNT Pocket Reform Speaker Replacement, Turn off the standby power: step 2, image 1 of 2 MNT Pocket Reform Speaker Replacement, Turn off the standby power: step 2, image 2 of 2
      • Use a small tool, like a SIM eject tool or a bent paperclip, to turn off the standby power switch by sliding the switch away from the headset jack.
      • The standby power switch is located in a small recess on the same side as the headset jack.
      Ask FixBot
    1. MNT Pocket Reform Speaker Replacement, Remove the bottom cover screws: step 3, image 1 of 2 MNT Pocket Reform Speaker Replacement, Remove the bottom cover screws: step 3, image 2 of 2
      • Place the laptop on your work surface so the bottom cover, with the regulatory info box, is facing up.
      • Use a Phillips screwdriver to remove the six 4.8 mm‑long screws securing the bottom cover.
      Ask FixBot
    2. MNT Pocket Reform Speaker Replacement, Remove the bottom cover: step 4, image 1 of 3 MNT Pocket Reform Speaker Replacement, Remove the bottom cover: step 4, image 2 of 3 MNT Pocket Reform Speaker Replacement, Remove the bottom cover: step 4, image 3 of 3
      • The bottom cover is made of printed circuit board (PCB) material. Press gently but firmly near an edge when applying the suction handle to avoid breaking the cover.
      • Apply a suction handle to the bottom cover.
      • Use the suction handle to lift the bottom cover off of the laptop.
      • Alternatively, you can use a thin prying tool to lift the cover, or tilt the laptop until the cover falls out.
      • During reassembly, place the bottom cover on the laptop so the info box is opposite the hinges.
      Ask FixBot
    1. MNT Pocket Reform Speaker Replacement, Disconnect the batteries: step 5, image 1 of 3 MNT Pocket Reform Speaker Replacement, Disconnect the batteries: step 5, image 2 of 3 MNT Pocket Reform Speaker Replacement, Disconnect the batteries: step 5, image 3 of 3
      • Be careful not to damage the lithium-polymer batteries when working around them with metal tools. If the batteries are damaged or deformed in any way, take appropriate precautions.
      • Use a pair of tweezers or your fingers to disconnect the batteries' sliding connectors from the charger board.
      Ask FixBot
    2. MNT Pocket Reform Speaker Replacement, Remove the batteries: step 6, image 1 of 3 MNT Pocket Reform Speaker Replacement, Remove the batteries: step 6, image 2 of 3 MNT Pocket Reform Speaker Replacement, Remove the batteries: step 6, image 3 of 3
      • Lift the batteries out of the frame.
      • During reassembly, install the batteries so the foam stickers face up, the sides of the batteries with wires are towards the hinges, and the wires run towards the middle of the laptop.
      Ask FixBot
    1. MNT Pocket Reform Speaker Replacement, Secure the bottom cover: step 7, image 1 of 3 MNT Pocket Reform Speaker Replacement, Secure the bottom cover: step 7, image 2 of 3 MNT Pocket Reform Speaker Replacement, Secure the bottom cover: step 7, image 3 of 3
      • Place the bottom cover on the laptop.
      • Use a Phillips screwdriver to secure the bottom cover with the six 4.8 mm‑long screws.
      Ask FixBot
    1. MNT Pocket Reform Speaker Replacement, Remove the top cover: step 8, image 1 of 2 MNT Pocket Reform Speaker Replacement, Remove the top cover: step 8, image 2 of 2
      • Place the laptop on your work surface so the top cover with the MNT logo is facing up.
      • Use a Phillips screwdriver to remove the seven 4.8 mm‑long screws securing the top cover.
      Ask FixBot
    2. MNT Pocket Reform Speaker Replacement: step 9, image 1 of 3 MNT Pocket Reform Speaker Replacement: step 9, image 2 of 3 MNT Pocket Reform Speaker Replacement: step 9, image 3 of 3
      • The top cover is made of printed circuit board (PCB) material. Press gently but firmly near an edge when applying the suction handle to avoid breaking the cover.
      • Apply a suction handle to the top cover.
      • Use the suction handle to lift the top cover off of the laptop.
      • There's a thermal pad between the top cover and the processor that may stick to the top cover during removal.
      Ask FixBot
    1. MNT Pocket Reform Speaker Replacement, Thermal pad info: step 10, image 1 of 1
      • During reassembly:
      • If the thermal pad is damaged in any way, follow the thermal pad replacement guide to install a new thermal pad.
      • The thermal pad may be stuck to the top cover or the processor.
      • If the thermal pad is in good condition, you can proceed with reassembly.
      • Make sure the thermal pad makes good contact with the processor and the top cover.
      Ask FixBot
    1. MNT Pocket Reform Speaker Replacement, Disconnect the speaker: step 11, image 1 of 3 MNT Pocket Reform Speaker Replacement, Disconnect the speaker: step 11, image 2 of 3 MNT Pocket Reform Speaker Replacement, Disconnect the speaker: step 11, image 3 of 3
      • Use a pair of angled tweezers or your fingers to disconnect the speaker sliding connector from the motherboard.
      Ask FixBot
    2. MNT Pocket Reform Speaker Replacement, Remove the speaker: step 12, image 1 of 2 MNT Pocket Reform Speaker Replacement, Remove the speaker: step 12, image 2 of 2
      • Use a Phillips screwdriver to remove the two 4.8 mm‑long screws securing the speaker.
      Ask FixBot
    3. MNT Pocket Reform Speaker Replacement: step 13, image 1 of 2 MNT Pocket Reform Speaker Replacement: step 13, image 2 of 2
      • Lift the speaker out of its slot to remove it.
      Ask FixBot
Spencer Pennington
27,659 Reputation
125 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 54
All Time: 282
