Introduction
Use this guide to replace the daughterboard, also called the headset board, on your MNT Pocket Reform laptop.
The daughterboard holds the power standby switch, headset jack, and wifi antenna. If your replacement daughterboard doesn't include a wifi antenna, you will need to buy a replacement antenna, too.
You can find specs to make your own daughterboard on MNT's documentation page.
If you've installed an operating system, follow the appropriate steps to safely shut down the laptop.
If you've not yet installed an operating system, or the laptop is not responsive, you can shut it down with these steps:
Turn on the OLED screen by pressing the Hyper key (diagonal arrow) and Enter at the same time.
Use the arrow keys to select Power Off on the OLED screen.
Press Enter to shut down the laptop.
Disconnect all cables from the laptop.
Use a small tool, like a SIM eject tool or a bent paperclip, to turn off the standby power switch by sliding the switch away from the headset jack.
Place the laptop on your work surface so the bottom cover, with the regulatory info box, is facing up.
Use a Phillips screwdriver to remove the six 4.8 mm‑long screws securing the bottom cover.
Apply a suction handle to the bottom cover.
Use the suction handle to lift the bottom cover off of the laptop.
Use a pair of tweezers or your fingers to disconnect the batteries' sliding connectors from the charger board.
Place the bottom cover on the laptop.
Use a Phillips screwdriver to secure the bottom cover with the six 4.8 mm‑long screws.
Place the laptop on your work surface so the top cover with the MNT logo is facing up.
Use a Phillips screwdriver to remove the seven 4.8 mm‑long screws securing the top cover.
If the thermal pad is damaged in any way, follow the thermal pad replacement guide to install a new thermal pad.
If the thermal pad is in good condition, you can proceed with reassembly.
Slide one arm of a pair of tweezers under the antenna coaxial cable connector, as close to the metal head as possible.
Lift the connector straight up and off the processor module to disconnect it.
Use a pair of angled tweezers or your fingers to disconnect the headset jack sliding connector from the daughterboard.
Use a Phillips screwdriver to remove the two 4.8 mm‑long screws securing the daughterboard.
1 Guide Comment
Why do I have to disconnect/remove the batteries first?
