Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Introduction
Go to step 1 ↓Follow this guide to replace a worn-out or dead battery in your Logitech G915 TKL wireless keyboard.
It’s natural for batteries to lose capacity as they age. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
Slide the power switch on the top edge of the keyboard to the OFF (left) position.
Unplug all cables from the keyboard.
Lay the keyboard down with the feet facing up on a clean work surface.
Use a Phillips screwdriver to remove the two 4 mm‑long screws securing the battery cover.
If you have a USB receiver stored in the battery cover compartment, use your finger to slide it out and remove it.
Insert your finger into the USB receiver compartment on the battery cover.
Pull up the bottom edge of the cover to release the clips.
Gently pull the cover to the right so you can access the battery connector on the left side of the recess.
Use a pair of angled tweezers to firmly grip the battery connector.
Slide the connector straight out of its socket.
Gently slide the flat end of a spudger under one of the short edges of the battery and lift to separate the adhesive.
Remove the battery from its cover.
Tool used on this step:Tesa 61395 Tape$8.95
Cut a piece of double-sided tape so it fits on the line of squares on the inside of the battery cover.
Press the tape firmly into place on the squares and remove the liner.
Insert the new battery's connector into its socket so the side with exposed pins is on the bottom.
Use a spudger to push the battery connector fully into its socket.
Set the battery cover into place and firmly press down around its edges to engage all the clips.
Use a Phillips screwdriver to install the two 4 mm‑long screws securing the battery cover.
Use your fingers to apply the sticker to the battery cover.
Congratulations on completing your repair!
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
2 other people completed this guide.
