Up to 20% off select tools
Liquid Damage Technique
Views: 8.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
106
All Time:
8,133
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
In this guide we will go over repairing the WAP54g when there is water damage. If something is spilled or you realize that there is liquid inside the device it is recommended to turn it off and unplug it as soon as possible. This guide is an attempt to fix the router if all else fails.
    1. Liquid Damage Technique, Top Casing: step 1, image 1 of 1
      • Power down and unplug the device.
      Ask FixBot
    2. Liquid Damage Technique: step 2, image 1 of 1
      Ask FixBot
    3. Liquid Damage Technique: step 3, image 1 of 1
      • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
      Ask FixBot
    4. Liquid Damage Technique: step 4, image 1 of 1
      • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
      Ask FixBot
    5. Liquid Damage Technique: step 5, image 1 of 1
      • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
      • This may require a bit of force.
      Ask FixBot
    6. Liquid Damage Technique: step 6, image 1 of 1
      • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
      Ask FixBot
    7. Liquid Damage Technique: step 7, image 1 of 2 Liquid Damage Technique: step 7, image 2 of 2
      • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
      Ask FixBot
    8. Liquid Damage Technique: step 8, image 1 of 2 Liquid Damage Technique: step 8, image 2 of 2
      • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
      • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
      • Once the top panel is removed the main board will still be attached to the bottom panel.
      Ask FixBot
    1. Liquid Damage Technique, Bottom Casing/Motherboard: step 9, image 1 of 2 Liquid Damage Technique, Bottom Casing/Motherboard: step 9, image 2 of 2
      • Unscrew the two screws that connect the motherboard to the bottom casing.
      • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
      Ask FixBot
    1. Liquid Damage Technique, Liquid Damage Technique: step 10, image 1 of 1
      • If the spilled substance is dry use a cleaning tool such as a toothbrush with soft bristles, so you do not damage the device, to brush off as much of the foreign material as possible.
      Ask FixBot
    2. Liquid Damage Technique: step 11, image 1 of 1
      • Dry off circuit board with kitchen paper; using other types of paper products such as toilet paper will fall apart. Be sure not to rub but carefully apply pressure to dry up wet spots.
      Ask FixBot
    3. Liquid Damage Technique: step 12, image 1 of 1
      • Clean off the components to make sure the rest of the residue comes off by using a chemical gasoline or another solvent that contains one substance that evaporates quickly.
      Ask FixBot
After the device is cleaned and put back together it should work properly.
Author
with
Derek Myers
288 Reputation
5 Guides authored
Cal Poly, Team 21-21, Maness Fall 2011 Member of Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Members
72 Guides authored
1 Guide Comment
I did all of this still not working it gets hot only but doesn’t turn it on.
DM MG - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 106
All Time: 8,133
