Linksys WAP54g Antennas Replacement
  1. Linksys WAP54g Antennas Replacement, Antennas: step 1, image 1 of 2 Linksys WAP54g Antennas Replacement, Antennas: step 1, image 2 of 2
    • Make sure the antennas are in a straight position, not bent, to remove the black casing.
    • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
    Ask FixBot
  2. Linksys WAP54g Antennas Replacement: step 2, image 1 of 1
    • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
    Ask FixBot
  3. Linksys WAP54g Antennas Replacement: step 3, image 1 of 1
    • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
    Ask FixBot
  4. Linksys WAP54g Antennas Replacement: step 4, image 1 of 1
    • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
    Ask FixBot
  5. Linksys WAP54g Antennas Replacement: step 5, image 1 of 1
    • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Repeat these steps for other antenna.
    Ask FixBot
After the repairs are made the device should working.
2 other people completed this guide.
Derek Myers
288 Reputation
5 Guides authored
Cal Poly, Team 21-21, Maness Fall 2011 Member of Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 33
All Time: 3,137
