Linksys WAP54g Top Casing Replacement
    1. Linksys WAP54g Top Casing Replacement, Top Casing: step 1, image 1 of 1
      • Power down and unplug the device.
      Ask FixBot
    2. Linksys WAP54g Top Casing Replacement: step 2, image 1 of 1
      Ask FixBot
    3. Linksys WAP54g Top Casing Replacement: step 3, image 1 of 1
      • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
      Ask FixBot
    4. Linksys WAP54g Top Casing Replacement: step 4, image 1 of 1
      • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
      Ask FixBot
    5. Linksys WAP54g Top Casing Replacement: step 5, image 1 of 1
      • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
      • This may require a bit of force.
      Ask FixBot
    6. Linksys WAP54g Top Casing Replacement: step 6, image 1 of 1
      • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
      Ask FixBot
    7. Linksys WAP54g Top Casing Replacement: step 7, image 1 of 2 Linksys WAP54g Top Casing Replacement: step 7, image 2 of 2
      • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
      Ask FixBot
    8. Linksys WAP54g Top Casing Replacement: step 8, image 1 of 2 Linksys WAP54g Top Casing Replacement: step 8, image 2 of 2
      • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
      • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
      • Once the top panel is removed the main board will still be attached to the bottom panel.
      Ask FixBot
From here you can take apart the rest of the router apart by following subsequent guides.
Derek Myers
288 Reputation
5 Guides authored
Cal Poly, Team 21-21, Maness Fall 2011 Member of Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Members
72 Guides authored
1 Guide Comment
Bon Tutoriel. Simple, mais les plastiques sont solidement attacher. Il faut donc forcer pour démonter la partie bleu. Mais c’est possible.
Merci.
Philippe Gabriel - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,939
