Linksys WAP54g Bottom Casing/Motherboard Replacement
  1. Linksys WAP54g Bottom Casing/Motherboard Replacement, Top Casing: step 1, image 1 of 1
    • Power down and unplug the device.
    Ask FixBot
  2. Linksys WAP54g Bottom Casing/Motherboard Replacement: step 2, image 1 of 1
    Ask FixBot
  3. Linksys WAP54g Bottom Casing/Motherboard Replacement: step 3, image 1 of 1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
    Ask FixBot
  4. Linksys WAP54g Bottom Casing/Motherboard Replacement: step 4, image 1 of 1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
    Ask FixBot
  5. Linksys WAP54g Bottom Casing/Motherboard Replacement: step 5, image 1 of 1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
    Ask FixBot
  6. Linksys WAP54g Bottom Casing/Motherboard Replacement: step 6, image 1 of 1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
    Ask FixBot
  7. Linksys WAP54g Bottom Casing/Motherboard Replacement: step 7, image 1 of 2 Linksys WAP54g Bottom Casing/Motherboard Replacement: step 7, image 2 of 2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
    Ask FixBot
  8. Linksys WAP54g Bottom Casing/Motherboard Replacement: step 8, image 1 of 2 Linksys WAP54g Bottom Casing/Motherboard Replacement: step 8, image 2 of 2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
    Ask FixBot
  9. Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: step 9, image 1 of 2 Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: step 9, image 2 of 2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
    Ask FixBot
After the motherboard is isolated component level repairs can be made.
2 other people completed this guide.
Mathew Fuller
146 Reputation
1 Guide authored
Cal Poly, Team 21-21, Maness Fall 2011 Member of Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 2,961
