Up to 20% off select tools
LG Chocolate 3 Display Connector Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
5
Past 30 Days:
36
All Time:
781
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Parts
Tools
Introduction
Go to step 1 ↓
This guide walks you through replacing the display connector on the LG Chocolate 3 (VX8560). If the screen is malfunctioning due to a loose or damaged connector, following this guide will help you restore functionality.
The display connector links the phone's screen to the motherboard, transmitting visual data. A faulty connector can cause the screen to have a blank display or the screen to flicker.
Important Safety and Handling Information:
  • Power off and battery removal: before beginning, turn off the device and remove the battery to prevent electrical damage
  • Careful Handling of small parts: the display connector can be fragile; avoid applying excessive force when reconnecting
    1. LG Chocolate 3 Display Connector Replacement, Battery: step 1, image 1 of 1
      • Turn the phone over so that the backside is facing up.
      Ask FixBot
    2. LG Chocolate 3 Display Connector Replacement: step 2, image 1 of 1
      • Push the battery cover from the indentation and slide it away from the phone to remove it.
      Ask FixBot
    3. LG Chocolate 3 Display Connector Replacement: step 3, image 1 of 2 LG Chocolate 3 Display Connector Replacement: step 3, image 2 of 2
      • Remove the battery from the phone.
      Ask FixBot
    1. LG Chocolate 3 Display Connector Replacement, Side Keys: step 4, image 1 of 2 LG Chocolate 3 Display Connector Replacement, Side Keys: step 4, image 2 of 2
      • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
      Ask FixBot
    2. LG Chocolate 3 Display Connector Replacement: step 5, image 1 of 3 LG Chocolate 3 Display Connector Replacement: step 5, image 2 of 3 LG Chocolate 3 Display Connector Replacement: step 5, image 3 of 3
      • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
      • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
      Ask FixBot
    3. LG Chocolate 3 Display Connector Replacement: step 6, image 1 of 2 LG Chocolate 3 Display Connector Replacement: step 6, image 2 of 2
      • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
      Ask FixBot
    1. LG Chocolate 3 Display Connector Replacement, Display Connector: step 7, image 1 of 2 LG Chocolate 3 Display Connector Replacement, Display Connector: step 7, image 2 of 2
      • Keep in mind that you will need to reinstall the side keys after completing this repair.
      • Skip this step if the screen blue and red display connector is already detached from the motherboard.
      • Insert the pointed end of a spudger between the plastic end of the wire and the motherboard socket, then carefully lift or push the wire to disconnect it.
      • You should see two golden pins protruding from the plastic connector.
      • To reconnect, align the two golden pins with their corresponding socket on the motherboard and gently press down until you hear a click indicating a secure connection.
      • To reassemble your device, follow the Side Keys Installation guide in reverse order.
      Ask FixBot
    2. LG Chocolate 3 Display Connector Replacement: step 8, image 1 of 1
      • Skip this step if the screen display connector is already detached from the motherboard. Using a spudger, insert the pointed end between the plastic end of the wire and the motherboard socket, then carefully lift or push the wire to disconnect it. You should see two golden pins protruding from the plastic connector.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Mitchel
1 Reputation
1 Guide authored
Cal Poly, Team 13-62, Johann Spring 2013 Member of Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 36
All Time: 781
