Keurig K70 Limit Switch Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
91
All Time:
3,040
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the Limit Switch that tells the Keurig that the K-Cup section is closed.
Tools
    1. Keurig K70 Limit Switch Replacement, Limit Switch: step 1, image 1 of 1
      • Open the K-Cup Holder by lifting the handle.
      Ask FixBot
    2. Keurig K70 Limit Switch Replacement: step 2, image 1 of 1
      • While looking upwards from underneath the Keurig, remove the two 8mm Phillips #2 screws from underneath the black plastic "shroud".
      Ask FixBot
    3. Keurig K70 Limit Switch Replacement: step 3, image 1 of 3 Keurig K70 Limit Switch Replacement: step 3, image 2 of 3 Keurig K70 Limit Switch Replacement: step 3, image 3 of 3
      • Remove the black plastic "shroud" by pushing inwards and then pulling upwards to disengage the plastic hooks that are not visible.
      Ask FixBot
    4. Keurig K70 Limit Switch Replacement: step 4, image 1 of 2 Keurig K70 Limit Switch Replacement: step 4, image 2 of 2
      • Remove the two 10mm Phillips #1 screws from the switch.
      Ask FixBot
    5. Keurig K70 Limit Switch Replacement: step 5, image 1 of 2 Keurig K70 Limit Switch Replacement: step 5, image 2 of 2
      Ask FixBot
2 other people completed this guide.
Kyle Maxwell
196 Reputation
1 Guide authored
Cal Poly, Team 20-4, Livingston Fall 2016 Member of Cal Poly, Team 20-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 91
All Time: 3,040
