How to join two wires with solder
    1. How to join two wires with solder, How to join two wires with solder: step 1, image 1 of 1
      • Put one of the paired wires on one of the helping hand's clamp. Put the other pair of wires on the remaining clamp.
      • Make sure the wires' stripped ends are facing each other or are towards the center of the workplace. If not, orientate the wires accordingly.
      Ask FixBot
    2. How to join two wires with solder: step 2, image 1 of 2 How to join two wires with solder: step 2, image 2 of 2
      • Using both stripped wire ends, wrap and tie both of the ends together.
      Ask FixBot
    3. How to join two wires with solder: step 3, image 1 of 1
      • Solder the tied ends of the filament.
      • Ensure to solder the connection completely, not just one area.
      • Try not to put too much solder on the connection, as it will add more resistance.
      Ask FixBot
    4. How to join two wires with solder: step 4, image 1 of 1
      • Pull on the two wires firmly to ensure the solder does not separate.
      Ask FixBot
    5. How to join two wires with solder: step 5, image 1 of 2 How to join two wires with solder: step 5, image 2 of 2
      • To properly protect the soldered wire connection, use heat shrink.
      • Cut enough heat shrink to cover the soldered connection.
      • Slip the heat shrink onto the connection.
      • Using a heat generator, such as a heat gun or a hairdryer, heat the heat shrink around all of the angles until it securely covers the soldered connection.
      Ask FixBot
This technique will allow wires to be extended both electrically and structurally without the need of longer wires.
8 other people completed this guide.
Joeny Zhen
427 Reputation
1 Guide authored
Cal Poly, Team 23-1, Green Winter 2015 Member of Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 Members
48 Guides authored
1 Guide Comment
Perhaps I might recommend sliding the H.S. tubing on before soldering the joint in case the wires are connected on the other end to something else.
Nathaniel Loeblein - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 69
All Time: 4,568
