JBL Flip 4 cable for buttons Replacement
    1. JBL Flip 4 cable for buttons Replacement, remove adhesive: step 2, image 1 of 1
      • remove all adhesive tapes / sticker inside (above the cables).
      • Take care of other sensitive cables.
      Ask FixBot
    2. JBL Flip 4 cable for buttons Replacement, Unlock cables: step 3, image 1 of 3 JBL Flip 4 cable for buttons Replacement, Unlock cables: step 3, image 2 of 3 JBL Flip 4 cable for buttons Replacement, Unlock cables: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Flip open the top flap on the ZIF connectors (the grey clip):
      • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the cable ZIF connectors.
      • Use a pair of tweezers to pull the cable out of the ZIF connectors.
      Ask FixBot
    3. JBL Flip 4 cable for buttons Replacement, Open both rubber cover (a bit): step 4, image 1 of 2 JBL Flip 4 cable for buttons Replacement, Open both rubber cover (a bit): step 4, image 2 of 2
      • Insert the plastic opening tool under the clear rubber cover over the button control board.
      • Pry up the cover using the opening tool.
      • Only open a bit (until cable).
      • The cover is glued on so it will take some force to pry up.
      Ask FixBot
    4. JBL Flip 4 cable for buttons Replacement, Unlock cables: step 5, image 1 of 2 JBL Flip 4 cable for buttons Replacement, Unlock cables: step 5, image 2 of 2
      • Flip open the top flap on the ZIF connectors (the grew part).
      Ask FixBot
    5. JBL Flip 4 cable for buttons Replacement, Remove old cables: step 6, image 1 of 1
      • The 6 Pin cable have some glue here.
      • Pull the cables out.
      Ask FixBot
    6. JBL Flip 4 cable for buttons Replacement, The new cables: step 7, image 1 of 3 JBL Flip 4 cable for buttons Replacement, The new cables: step 7, image 2 of 3 JBL Flip 4 cable for buttons Replacement, The new cables: step 7, image 3 of 3
      • Buy new cables. These cables are called FFC or FPC flex cable. The distance between the contacts ( called Pitch ) is 0.5mm. Cable length is origin 12 cm (10 cm or 15 cm fits also). Details:
      • Buttons power, led, : 13 Pin - Type A
      • Buttons play, + , - , connect : 6 Pin - Type B (=reverse) (=the connectors are reversed to each other)
      • Modification at one side / end:
      • The (blue) inflexible cable-end, is called supporting tape. It is import for a fixed connection. It will latch in the connector clip.
      • This part should be maximal 0.5 cm long. This part is often too long, at the 6 Pin-cable. You must modify it (one time in total):
      • Use tools like cutter & scissors ( see video in next step ),
      • or use a mini rasp / file
      Ask FixBot
      • Read the step before.
      Ask FixBot
    7. JBL Flip 4 cable for buttons Replacement, insert new: step 9, image 1 of 3 JBL Flip 4 cable for buttons Replacement, insert new: step 9, image 2 of 3 JBL Flip 4 cable for buttons Replacement, insert new: step 9, image 3 of 3
      Ask FixBot
    8. JBL Flip 4 cable for buttons Replacement, Test and fixing: step 10, image 1 of 2 JBL Flip 4 cable for buttons Replacement, Test and fixing: step 10, image 2 of 2
      • Test it: Reconnect the battery. Check if all buttons are working. Disconnect the battery again.
      • Final: Rolling in cable. Fixing the cable with tape and glue it. ( Put upright for a day, while drying glue (due to glue solvent) )
      Ask FixBot
4 other people completed this guide.
Joe Musters
2,395 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 97
Past 30 Days: 376
All Time: 3,681
