Huawei Watch 3 Battery Replacement
Views: 27K
View statistics:
Past 24 Hours:
19
Past 7 Days:
144
Past 30 Days:
573
All Time:
26,517
Comments: 5
5 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Huawei Watch 3.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You may need replacement adhesive to reattach components when reassembling the device.
Parts
Tools
      • User your fingernail to pull the small metal pin on each wrist band towards the inside. This unlocks the wrist bands from the body of the watch.
      • Remove the wrist bands.
      Ask FixBot
    1. Huawei Watch 3 Battery Replacement, Remove the four Torx screws: step 2, image 1 of 1
      • Use a Torx T3 screwdriver to remove the four 4 mm-long screws on the back of the Huawei Watch 3.
      Ask FixBot
    2. Huawei Watch 3 Battery Replacement, Pry the back cover open: step 3, image 1 of 3 Huawei Watch 3 Battery Replacement, Pry the back cover open: step 3, image 2 of 3 Huawei Watch 3 Battery Replacement, Pry the back cover open: step 3, image 3 of 3
      • Locate the small notch at the top of the back cover.
      • Use a Jimmy to pry open the back cover by twisting it.
      • Using a sharp metal tool might cause cosmetic damage to the watch case. Covering the tool with a nitril glove can minimize the damage.
      • Don’t remove the back cover just yet. It is still connected to the motherboard with a flex cable.
      Ask FixBot
    3. Huawei Watch 3 Battery Replacement, Loosen the back cover gasket: step 4, image 1 of 2 Huawei Watch 3 Battery Replacement, Loosen the back cover gasket: step 4, image 2 of 2
      • Insert the tip of an opening pick between the back cover and the case.
      • Slide the opening pick around the back cover to loosen the gasket from the back cover.
      Ask FixBot
    4. Huawei Watch 3 Battery Replacement, Lift the back cover: step 5, image 1 of 3 Huawei Watch 3 Battery Replacement, Lift the back cover: step 5, image 2 of 3 Huawei Watch 3 Battery Replacement, Lift the back cover: step 5, image 3 of 3
      • There is a ribbon cable running from the back cover to the motherboard.
      • Use an opening pick or your fingers to carefully lift the back cover open.
      • Flip the back cover open away from the crown.
      • You can prop up the back cover to minimize the stress on the ribbon cable.
      Ask FixBot
    5. Huawei Watch 3 Battery Replacement, Remove the battery bracket screw: step 6, image 1 of 1
      • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the battery bracket.
      Ask FixBot
    6. Huawei Watch 3 Battery Replacement, Remove the battery bracket: step 7, image 1 of 3 Huawei Watch 3 Battery Replacement, Remove the battery bracket: step 7, image 2 of 3 Huawei Watch 3 Battery Replacement, Remove the battery bracket: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • User a pair of tweezers to lift the top of the battery bracket free from its screw socket.
      • Unhook the opposite side of the bracket and remove it.
      Ask FixBot
    7. Huawei Watch 3 Battery Replacement, Unplug the battery connector: step 8, image 1 of 2 Huawei Watch 3 Battery Replacement, Unplug the battery connector: step 8, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the battery connector.
      • The battery connector is the smallest of the three connectors.
      Ask FixBot
    8. Huawei Watch 3 Battery Replacement, Remove the sensor bracket screw: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the sensor bracket.
      Ask FixBot
    9. Huawei Watch 3 Battery Replacement, Remove the sensor bracket: step 10, image 1 of 3 Huawei Watch 3 Battery Replacement, Remove the sensor bracket: step 10, image 2 of 3 Huawei Watch 3 Battery Replacement, Remove the sensor bracket: step 10, image 3 of 3
      • User a pair of tweezers to move the top of the sensor bracket free from a small latch near the case by rotating in inwards.
      Ask FixBot
    10. Huawei Watch 3 Battery Replacement, Unplug the sensor connector: step 11, image 1 of 3 Huawei Watch 3 Battery Replacement, Unplug the sensor connector: step 11, image 2 of 3 Huawei Watch 3 Battery Replacement, Unplug the sensor connector: step 11, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the sensor connector.
      • Remove the back cover.
      Ask FixBot
    1. Huawei Watch 3 Battery Replacement, Disconnect the home button: step 12, image 1 of 2 Huawei Watch 3 Battery Replacement, Disconnect the home button: step 12, image 2 of 2
      • Use the tip of a spudger to disconnect the home button cable.
      Ask FixBot
    2. Huawei Watch 3 Battery Replacement, Lift the battery: step 13, image 1 of 3 Huawei Watch 3 Battery Replacement, Lift the battery: step 13, image 2 of 3 Huawei Watch 3 Battery Replacement, Lift the battery: step 13, image 3 of 3
      • Insert the tip of an opening pick between the battery and the plastic frame opposite to the cables.
      • Use the opening pick to lift the battery up.
      • The battery is held down by mild adhesive.
      Ask FixBot
    3. Huawei Watch 3 Battery Replacement, Remove the battery: step 14, image 1 of 2 Huawei Watch 3 Battery Replacement, Remove the battery: step 14, image 2 of 2
      • Grab the battery with your fingers and remove it.
      • For reassembly you may need to apply some adhesive to the new battery if it does not come equipped with it.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 other people completed this guide.
Tobias Isakeit
136,049 Reputation
189 Guides authored
5 Guide Comments
do you know where can i find the back cover for huawei gt3 pro?
Drako Outsgard - Reply Share
I want to now //
Hampus Akvist - Reply Share
Beste Tobias ik heb een watch 3 waarvan de batterij sneller leegloopt, inmiddels werken de sensors niet meer, dus nieuwe batterij besteld met een toolkit, dat de sensors niet meer werken hoop ik dat door dikker wordende defecte batterij de sensorkabeltje is los gaan zitten, dus duim met me mee dat batterijvervanging de oplossing is en dat het horloge dat in augustus 3 jaar wordt weer leven in wordt geblazen, ik durf zekf vervangen wel aan, prijsopgave Eur 329,00 voor Mediamarkt servicecentrum die motherboard gemujk wil vervangen wegens risico uitnemen batterij
Peter Schmeitz - Reply Share
You can do it, Peter–I believe in you.
As long as you are careful with the short cables when opening. Those brackets inside have nifty little hooks, look closely at the images and read the text, this way you’ll be safe.
Keep my fingers crossed for you :)
Tobias Isakeit - Reply Share
Hallo Tobias!
Ich bin so froh, dass ich Euch gefunden habe. Ich schraube gerne und möchte, wenn es nur geht kaputte Dinge nicht wegschmeißen.
Dieser Akkuwechsel wird mich mal wieder auf die Probe stellen.
Dank für Deine sehr guter Beschreibung Tobias, bin ich sehr zuversichtlich.
Muss allerdings tief Luft Holen.
Wie es ausgegangen ist werde ich berichten.
LG
Csaba
Dr. Csaba Tatai - Reply Share
Past 24 Hours: 19
Past 7 Days: 144
Past 30 Days: 573
All Time: 26,517
