How to fix alignment on an E-TKT Label Printer
    1. How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: step 1, image 1 of 2 How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: step 1, image 2 of 2
      • Reboot the device.
      • After the splash screen the machine will home by rotating until the magnet meets the hall sensor.
      • Check the letter J position in the top window: If the letter is visually centered (second image), then you can skip ahead to to Step 3.
      Ask FixBot
    2. How to fix alignment on an E-TKT Label Printer, Rough adjustment: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Turn off the device to avoid short circuiting the leads of the hall sensor.
      • Use blunt tweezers to finely adjust the hall sensor position along the tangential (cyan) axis as shown in the image:
      • If J is too much to the right, push the hall sensor toward the centre of the device (yellow arrow).
      • If J is too much to the left, pull the hall sensor towards yourself (magenta arrow).
      • Make sure to keep the same distance on the transversal (red) axis.
      Ask FixBot
    3. How to fix alignment on an E-TKT Label Printer, Fine tuning: step 3, image 1 of 2 How to fix alignment on an E-TKT Label Printer, Fine tuning: step 3, image 2 of 2
      • Enter the web interface and click on SETUP.
      • Now press the TEST-button to the right side of ALIGN.
      • The machine will now slowly and lightly press the carousel letter, as shown in the second image.
      • Adjust the ALIGN-value until the press is fully centered on the character being pressed.
      • The align value ranges from 1 to 9, with 5 being the default (middle) value.
      Ask FixBot
Happy printing!
Sebastian
33,610 Reputation
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 31
All Time: 442
