Up to 20% off select tools
How to Use Digital Calipers
Views: 24K
View statistics:
Past 24 Hours:
7
Past 7 Days:
93
Past 30 Days:
508
All Time:
23,717
Comments: 2
2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Follow this guide to learn how to use digital calipers to take measurements.
Screw and part dimensions are vital for organizing your electronics repairs, ensuring each screw is put back in its correct place during reassembly—saving you time and frustration!
Calipers precisely measure lengths, thicknesses, and diameters using two sets of jaws. The small inside jaws measure internal diameters, while the large outside jaws measure external diameters, lengths, and widths. A probe on the opposite end measures depth. Digital calipers have the ability to zero and often support more than one unit of measurement.
Dead battery? Follow this guide.
    1. How to Use Digital Calipers, The components of digital calipers: step 1, image 1 of 2 How to Use Digital Calipers, The components of digital calipers: step 1, image 2 of 2
      • Most digital calipers have the same parts, controls, and buttons:
      • An on/off button
      • A zero button that sets the current reading to zero
      • A units button that switches between imperial and metric measurements, commonly written as mm/inch
      • A thumb screw that opens and closes the jaws
      • A locking screw that holds the jaws in place to keep the current measurement
      • Click here for a more in‑depth look at the different parts of digital calipers.
      Ask FixBot
    2. How to Use Digital Calipers, Ensure the calipers are ready to use: step 2, image 1 of 2 How to Use Digital Calipers, Ensure the calipers are ready to use: step 2, image 2 of 2
      • Before using your calipers, clean the inside of the jaws with a fresh cloth or rag to make sure there's no dirt or grime that could affect measurements.
      Ask FixBot
    3. How to Use Digital Calipers, Opening and closing the jaws: step 3, image 1 of 3 How to Use Digital Calipers, Opening and closing the jaws: step 3, image 2 of 3 How to Use Digital Calipers, Opening and closing the jaws: step 3, image 3 of 3
      • To open or close the jaws, press down on the thumb screw and gently roll it in the direction you want the jaw to move.
      • You don't need to apply much pressure to the thumb screw when opening or closing the jaws.
      • Pushing too hard can lead to imprecise measurements or inaccurate zeroing.
      Ask FixBot
    4. How to Use Digital Calipers, Zeroing digital calipers: step 4, image 1 of 2 How to Use Digital Calipers, Zeroing digital calipers: step 4, image 2 of 2
      • The process of setting zero ensures the measurements you’re about to make are accurate.
      • Gently close the jaws.
      • Press the zero button to set the current measurement to zero.
      • Digital calipers can be zeroed at any point along the scale, not just when the jaws are closed. This can be useful to check the size difference between two components. Take the first measurement, press the zero button, and then take the second measurement. The result is the difference between the two measurements.
      Ask FixBot
    5. How to Use Digital Calipers: step 5, image 1 of 3 How to Use Digital Calipers: step 5, image 2 of 3 How to Use Digital Calipers: step 5, image 3 of 3
      • Open and close the jaws, making sure the calipers measure zero each time the jaws reach their fully closed position. If the reading isn’t exactly 0.00, repeat the previous step.
      Ask FixBot
    6. How to Use Digital Calipers, Using the external jaws: step 6, image 1 of 3 How to Use Digital Calipers, Using the external jaws: step 6, image 2 of 3 How to Use Digital Calipers, Using the external jaws: step 6, image 3 of 3
      • Use the larger external jaws to get external measurements, such as screw lengths or screw head diameters.
      • Open the jaws wide enough for the object being measured to comfortably fit between them.
      • Gradually close the jaws until both sides touch the object. Don’t push too hard, yet firm enough to make sure both jaws sit flat against the object.
      • Check that your object isn’t crooked when you take your measurement.
      • Read the measurement.
      • Take the measurement a few times and make sure it's the same—or very close—each time. If you get inconsistent readings, zero the calipers and try again.
      • Zero the calipers before making another measurement.
      Ask FixBot
    7. How to Use Digital Calipers, Using the internal jaws: step 7, image 1 of 3 How to Use Digital Calipers, Using the internal jaws: step 7, image 2 of 3 How to Use Digital Calipers, Using the internal jaws: step 7, image 3 of 3
      • Use the smaller internal jaws to get internal measurements, such as inside diameters or gaps between parts.
      • Close the jaws until you can comfortably fit them inside the object.
      • Gradually open the jaws until both sides touch the object. Don’t pull too hard, yet firm enough to make sure both jaws sit flat against the object’s inside edges.
      Ask FixBot
    8. How to Use Digital Calipers, Using the locking screw: step 8, image 1 of 3 How to Use Digital Calipers, Using the locking screw: step 8, image 2 of 3 How to Use Digital Calipers, Using the locking screw: step 8, image 3 of 3
      • The locking screw is used to keep the jaws in place after taking a measurement. This is helpful when you don't want your reading to change, or when checking for measurement consistency between multiples of the same part.
      • Gently remove the object from the jaws, being careful not to bump or shift the jaws.
      • Twist the locking screw clockwise to tighten it and lock the jaws in place.
      Ask FixBot
    9. How to Use Digital Calipers, Caliper maintenance: step 9, image 1 of 1
      • When you're done using your digital calipers, clean the jaws with a cloth or rag, press the on/off button to turn the calipers off, and store it in its original case in a safe location.
      • Avoid storing heavy objects on top of your calipers, even when in their case. Calipers can lose accuracy if bent or dropped, and are extra sensitive to dust and grime.
      Ask FixBot
Now you can use your digital calipers to keep track of all your fixing and tinkering dimensions—happy measuring!
If your caliper display stops working, it may need a new battery. Follow this guide to replace the battery.
Having trouble? Try some basic troubleshooting, or ask our answers community for help.
For other general electronics skills guides, click here.
8 other people completed this guide.
Author
with
Spencer Day
210,776 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
Très très bon tuto sur les pied à coulisse. Bien penser à le calibrer avant l'utilisation.
Yann VALLET - Reply Share
When measuring with calipers, apply light pressure to close on the object being measured. Do not squeeze the object being measured. Once the calipers are closed on the object being measured, lift your thumb from the wheel to avoid the readout from changing with the micromovements from your thumb. Measuring anything with give or flexibility, please consider if the caliper is the correct measuring device first. e.g. - measuring the thickness of a gasket.
Michelle M - Reply Share
Past 24 Hours: 7
Past 7 Days: 93
Past 30 Days: 508
All Time: 23,717
