Up to 20% off select tools
How to Reattach a Broken Table Leg
Views: 14K
View statistics:
Past 24 Hours:
8
Past 7 Days:
69
Past 30 Days:
279
All Time:
13,733
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide if you have a broken leg on a wooden table.
Tables are the most common objects used at home or the workplace. Due to extensive use, multiple adjustments and frequent movements, table legs often get loose. Furniture is quite expensive to replace and very difficult to dispose of. This guide will illustrate basic steps to fix any kind of wooden table or chair.
Prerequisite: Before using this guide, analyze the issue and find all the broken or missing parts. Please make sure to collect all the missing screws and verify the size of the screws that are required. This guide does not require any existing knowledge to fix tables.
    1. How to Reattach a Broken Table Leg, How to Reattach a Broken Table Leg: step 1, image 1 of 1
      • Carefully place the table on an even surface and identify the broken parts.
      Ask FixBot
    2. How to Reattach a Broken Table Leg: step 2, image 1 of 1
      • Carefully place the table with the tabletop face down on a clean cloth or plastic cover to prevent scratching.
      • You might need some assistance depending on the size of the table.
      Ask FixBot
    3. How to Reattach a Broken Table Leg: step 3, image 1 of 2 How to Reattach a Broken Table Leg: step 3, image 2 of 2
      • Remove the screws from the broken leg.
      • I am using a Mastercraft flathead 3 mm screwdriver in this step. Your screwdriver type will depend on the screw. Follow this guide to learn more about screwdriver types.
      • Remove the broken leg.
      • Use a paper towel to clean the surface of the table and legs.
      Ask FixBot
    4. How to Reattach a Broken Table Leg: step 4, image 1 of 2 How to Reattach a Broken Table Leg: step 4, image 2 of 2
      • Caution: If you have sensitive skin, avoid direct contact with the glue and use gloves before performing this step.
      • Caution: Use adequate ventilation or wear a mask to prevent inhaling the glue fumes.
      • Carefully apply the glue on the part that connects the table and legs.
      Ask FixBot
    5. How to Reattach a Broken Table Leg: step 5, image 1 of 1
      • Press the leg against the glue for few minutes.
      • Allow the glue to dry for at least 10 minutes.
      Ask FixBot
    6. How to Reattach a Broken Table Leg: step 6, image 1 of 1
      • Once the glue is dry, insert the screws.
      Ask FixBot
    7. How to Reattach a Broken Table Leg: step 7, image 1 of 3 How to Reattach a Broken Table Leg: step 7, image 2 of 3 How to Reattach a Broken Table Leg: step 7, image 3 of 3
      • Use an electric drill or a screwdriver to tighten the screws.
      Ask FixBot
    8. How to Reattach a Broken Table Leg: step 8, image 1 of 1
      • Use a paper towel to remove extra glue stains.
      • Allow the table to dry for 24 hours before turning the table.
      Ask FixBot
    9. How to Reattach a Broken Table Leg: step 9, image 1 of 2 How to Reattach a Broken Table Leg: step 9, image 2 of 2
      • After 24 hours, carefully return the table to the original position.
      • Depending on the size of the table, you might need some assistance to turn the table.
      Ask FixBot
Repeat these steps to fix any other broken legs on the table.
Author
with
Kunpriya Aggarwal
246 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 69
Past 30 Days: 279
All Time: 13,733
