How to Reapply Durable Water Repellent (DWR) Coating
Views: 41K
View statistics:
Past 24 Hours:
37
Past 7 Days:
164
Past 30 Days:
850
All Time:
41,377
Comments: 3
3 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Very easy
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Introduction
Go to step 1 ↓
Your jacket has got your back. It follows you on adventures, keeping you warm and dry even through the stormiest weather. Return the favor by periodically refreshing its durable water repellent (DWR) coating!
DWR is your jacket's first line of waterproof defense, causing water droplets to bead up and roll off the surface of the fabric instead of soaking in. Over time, dirt, oil, and regular use can wear down this protective layer, allowing water to seep into the fabric.
This guide will show you how to reapply a DWR coating using Storm Eco Proofer, a Patagonia® recommended product. With just a few simple steps, you can restore your jacket’s water repellency and keep it adventure-ready!
Related Tutorials
Related Wikis
Return to the Patagonia Care & Repair homepage.
    1. How to Reapply Durable Water Repellent (DWR) Coating, Prepare your jacket: step 1, image 1 of 3 How to Reapply Durable Water Repellent (DWR) Coating, Prepare your jacket: step 1, image 2 of 3 How to Reapply Durable Water Repellent (DWR) Coating, Prepare your jacket: step 1, image 3 of 3
      • Zip up all zippers to protect them during the wash and dry cycles.
      • Check all pockets for forgotten items and hidden treasures!
      Ask FixBot
    2. How to Reapply Durable Water Repellent (DWR) Coating: step 2, image 1 of 3 How to Reapply Durable Water Repellent (DWR) Coating: step 2, image 2 of 3 How to Reapply Durable Water Repellent (DWR) Coating: step 2, image 3 of 3
      • Loosen drawstrings and drawcords as much as possible.
      • Fasten hook-and-loop closures in their most relaxed position to avoid snagging.
      Ask FixBot
    3. How to Reapply Durable Water Repellent (DWR) Coating, Load the washer: step 3, image 1 of 1
      • Place the jacket in the washing machine.
      • Add 1–3 garments at a time. Avoid overfilling the drum—technical garments need room to move freely.
      • Ideally, use a front-loading washer instead of a top-loading machine.
      • Top-loaders usually have agitators, a rotating spindle that creates friction to clean your gear. Jackets can get caught in that spindle, leading to tangles, tears, or scratches.
      • Top-loaders also require more DWR treatment. (For example Storm Eco Proofer requires 75 ml for front-loaders vs. 112 ml for top-loaders.)
      Ask FixBot
    4. How to Reapply Durable Water Repellent (DWR) Coating, Add DWR treatment: step 4, image 1 of 3 How to Reapply Durable Water Repellent (DWR) Coating, Add DWR treatment: step 4, image 2 of 3 How to Reapply Durable Water Repellent (DWR) Coating, Add DWR treatment: step 4, image 3 of 3
      • Add durable water repellent treatment to the wash, following the instructions on the bottle.
      • For Patagonia® recommended Storm Eco Proofer:
      • Shake the bottle and measure out 2.5 ounces (75 ml) (about 1/3 cup or 5 tablespoons) per item.
      • Pour the treatment into the fabric softener compartment.
      • You can add Storm Clothing Wash to the detergent compartment. It’s designed to work with the Eco Proofer.
      • Don't use regular household detergent. It can interfere with the DWR treatment.
      Ask FixBot
    5. How to Reapply Durable Water Repellent (DWR) Coating, Set the washing machine: step 5, image 1 of 2 How to Reapply Durable Water Repellent (DWR) Coating, Set the washing machine: step 5, image 2 of 2
      • Set the load size to small or medium, depending on the number of garments you're washing.
      • Set the water temperature to cold.
      • Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
      • Set the spin cycle to low.
      • Start the washing machine.
      Ask FixBot
    6. How to Reapply Durable Water Repellent (DWR) Coating, Tumble dry: step 6, image 1 of 3 How to Reapply Durable Water Repellent (DWR) Coating, Tumble dry: step 6, image 2 of 3 How to Reapply Durable Water Repellent (DWR) Coating, Tumble dry: step 6, image 3 of 3
      • Hang the jacket up to drip dry first to remove excess water.
      • Tumble dry the jacket on low heat.
      • Don't skip the dryer! Heat activates the DWR coating.
      • Follow the garment care instructions for dryer time settings. While a lightweight rain shell may only take 20 minutes, a down insulated jacket could take up to 2 hours to fully dry.
      • If you don't have access to a dryer, use a low-heat iron with a clean damp cloth between the iron and the jacket to heat-set the treatment. See How to Iron a Waterproof Jacket for more info.
      Ask FixBot
    7. How to Reapply Durable Water Repellent (DWR) Coating, All done!: step 7, image 1 of 1
      • Your jacket is now refreshed and ready to take on the elements again. Whether you're heading into the mountains, the forest, or just out for a rainy-day walk, your gear is good to go.
      • Get back out there!
      Ask FixBot
      • Spray-on treatments are great for targeted reapplication or when you want to avoid a full wash. Follow the instructions on the bottle, which typically include:
      • Spray onto a freshly cleaned garment while it's hanging or laid flat.
      • Focus the spray on high-wear areas like shoulders.
      • Let it sit for a few minutes, then heat-set it with a dryer or iron.
      Ask FixBot
    8. Ask FixBot
Finish Line
8 other people completed this guide.
Clara Redwood
2,574 Reputation
19 Guides authored
Patagonia Member of Patagonia
Community
9 Members
384 Guides authored
3 Guide Comments
Can you recommend a durable water repellency treatment? I have tried to treat my rain jacket in the past and have been disappointed in the results.
Andrea Jeffery - Reply Share
If fabric becomes wet, it loses its performance and breathability indeed. Therefore, most technical garments contain a tiny layer of Durable Water Repellency (DWR) coating outside. This layer of liquid prevents dirt, grease, oil, and water as well. But, usually, protecting this essential fabric layer becomes very difficult yet.
Therefore, some people use the best waterproofing spray for the outdoor fabric to protect this liquid coating. These waterproofing sprays protect our footwear, and other clothing stuffs from water damage. Though this spray’s main function is to prevent water and form a protective barrier against sun and dirt, it has more benefits than one. These waterproofing sprays improve the performance of your fabrics.
For More Information & Products Review and Buying Guide Visit - https://www.bestoutdoorreview.com/best-w...
Best Outdoor Review - Reply Share
I’ve used every DWR product available, none of them work
DaveWave - Reply Share
Past 24 Hours: 37
Past 7 Days: 164
Past 30 Days: 850
All Time: 41,377
