Up to 20% off select tools
How to Iron a Waterproof Jacket
Views: 208K
View statistics:
Past 24 Hours:
66
Past 7 Days:
461
Past 30 Days:
1,444
All Time:
208,122
Comments: 23
6 comments on steps, 17 guide comments.
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Very easy
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Introduction
Go to step 1 ↓
You may want to iron your waterproof jacket if it's gotten a little wrinkly, or if it's just been washed and you don’t have access to a dryer but still want to restore its water-repellent finish. Applying heat is key to both smoothing out the fabric and reactivating the DWR coating. While a dryer is ideal for both of these purposes because it evenly distributes heat across the entire garment, using an iron is better than no heat at all!
Every jacket is different, so pay close attention as you iron. Avoid ironing over drawcords, zippers, or other closures that can create a bumpy surface or risk damage. If you don’t have an ironing board, no problem—just fold up a towel on a solid heat-resistant surface like a table or countertop to create a makeshift ironing station.
Related Tutorials
Related Wikis
Return to the Patagonia Care & Repair homepage.
    1. How to Iron a Waterproof Jacket, Prepare the jacket: step 1, image 1 of 1
      • Unzip your clean jacket and slide one half over your ironing board or towel-covered surface.
      • You only want to iron through one layer of the jacket at a time. Ironing through two layers can create creases in the bottom layer.
      • Flatten your jacket with your hands.
      Ask FixBot
    2. How to Iron a Waterproof Jacket, Set up the iron: step 2, image 1 of 3 How to Iron a Waterproof Jacket, Set up the iron: step 2, image 2 of 3 How to Iron a Waterproof Jacket, Set up the iron: step 2, image 3 of 3
      • Set the iron to its lowest heat setting, below 230 °F.
      • Turn off the steam function. Steam can damage the fabric and the DWR coating. If you can't turn off the steam function on your iron, drain the water chamber completely.
      Ask FixBot
    3. How to Iron a Waterproof Jacket, Protect the jacket: step 3, image 1 of 2 How to Iron a Waterproof Jacket, Protect the jacket: step 3, image 2 of 2
      Ask FixBot
    4. How to Iron a Waterproof Jacket, Iron the jacket: step 4, image 1 of 2 How to Iron a Waterproof Jacket, Iron the jacket: step 4, image 2 of 2
      • Iron in one smooth stroke, running parallel to the zipper.
      • Only iron in one direction, don't go back and forth or you risk creating creases. Change directions only when you move to a new section of the jacket.
      • Don't press down. Let the heat and weight of the iron do the work.
      • Keep the iron moving continuously to avoid melting or burning the fabric.
      Ask FixBot
    5. How to Iron a Waterproof Jacket, Check your progress: step 5, image 1 of 3 How to Iron a Waterproof Jacket, Check your progress: step 5, image 2 of 3 How to Iron a Waterproof Jacket, Check your progress: step 5, image 3 of 3
      • Remove the towel and inspect the jacket.
      • If the fabric looks unchanged, increase the heat slightly and try again.
      • If the area looks smooth, move on to the next section.
      Ask FixBot
      • To fully reactivate the DWR coating, heat must make contact with every part of the jacket. Go slowly and work in small, manageable sections to ensure even coverage.
      • Be extra careful around tight or curved areas like hoods, cuffs, and sleeves.
      • For the sleeves, slide a tailor’s ham, sleeve board, or folded towel inside the sleeve to separate the two sides.
      • Continue repositioning the jacket and repeating the ironing process until the entire surface has been treated.
      • Don't forget to turn off the iron when you're finished.
      Ask FixBot
Finish Line
24 other people completed this guide.
Author
with
Clara Redwood
2,574 Reputation
19 Guides authored
Patagonia Member of Patagonia
Community
9 Members
384 Guides authored
17 Guide Comments
Thank you, good advice for younger generation who have clue.
keirakeith26 - Reply Share
Thank you - good reminder for the older generation who have lost their marbles
Swag McYolo - Reply Share
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - Reply Share
謝謝,對於說中文的外國人來說,這是一個很好的建議,即使他們沒有失去彈珠,他們也沒有投棄權,但仍然沒有任何線索。
艾爾伯特愛因斯坦 - Reply Share
I hope the non-English comment is also in the same form as the first 3.
Eva - Reply Share
Past 24 Hours: 66
Past 7 Days: 461
Past 30 Days: 1,444
All Time: 208,122
