How to Hem Pants by Hand-Sewing
Views: 160K
View statistics:
Past 24 Hours:
47
Past 7 Days:
287
Past 30 Days:
998
All Time:
160,359
Comments: 2
2 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 16
16 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Introduction
Go to step 1 ↓
Do you have pants that need hemming but don't have a sewing machine to do it? Use this guide to help you hem any type of pants without using a sewing machine.
Parts
Tools
    1. How to Hem Pants by Hand-Sewing, How to Hem Pants by Hand-Sewing: step 1, image 1 of 1
      • Wear the pants and fold the hem up until you get your desired length.
      Ask FixBot
    2. How to Hem Pants by Hand-Sewing: step 2, image 1 of 1
      • Remove the pants, making sure that the folded hem remains fixed.
      • Lay the pants down on a table and measure the length from the original hem to the folded edge.
      • Make sure to take note of all of your measurements.
      Ask FixBot
    3. How to Hem Pants by Hand-Sewing: step 3, image 1 of 1
      • Turn the pants inside out, and unfold the folded edge.
      • Starting from the original hem, measure out the length of what will be your new hem.
      • The length you will need for this step would be the length you measured out from the previous step.
      • Using your fabric marker, draw a line marking where your new hem would be.
      Ask FixBot
    4. How to Hem Pants by Hand-Sewing: step 4, image 1 of 1
      • Starting from the line you just created, measure out 1 inch and mark with a line.
      Ask FixBot
    5. How to Hem Pants by Hand-Sewing: step 5, image 1 of 1
      • Using the 1 inch line as your guide, cut off the extra fabric.
      Ask FixBot
    6. How to Hem Pants by Hand-Sewing: step 6, image 1 of 2 How to Hem Pants by Hand-Sewing: step 6, image 2 of 2
      • Fold the raw edge up to the new hem line.
      • Fold it again along the new hem line, so that the raw edge is now inside the fold.
      Ask FixBot
    7. How to Hem Pants by Hand-Sewing: step 7, image 1 of 2 How to Hem Pants by Hand-Sewing: step 7, image 2 of 2
      • Place a sewing pin parallel to the fold to make sure that the fold stays in place.
      • Fold and pin all the way around to create your new hem.
      Ask FixBot
    8. How to Hem Pants by Hand-Sewing: step 8, image 1 of 1
      • Have your needle threaded and ready to go.
      • Sew the fold close to create a new hem; try to keep your stitches small and even.
      • White thread was used instead of black to make the stitches more evident in the pictures.
      Ask FixBot
    9. How to Hem Pants by Hand-Sewing: step 9, image 1 of 3 How to Hem Pants by Hand-Sewing: step 9, image 2 of 3 How to Hem Pants by Hand-Sewing: step 9, image 3 of 3
      • Once you're done stitching, tie off the thread by creating a knot towards the end of the string.
      • Cut off the excess string above the knot.
      • Remove all of the sewing pins.
      • Repeat steps 3 to 8 for the other pant leg using the same measurements, and then you're officially done!
      Ask FixBot
20 other people completed this guide.
Irish Pellas
763 Reputation
1 Guide authored
Cal Poly, Team 15-5, Green Fall 2015 Member of Cal Poly, Team 15-5, Green Fall 2015
CPSU-GREEN-F15S15G5
4 Members
48 Guides authored
2 Guide Comments
Thank you for this guide! The only thing I am uncertain about is how determine a good length for the pants. I read in another guide that it would be good to measure with shoes on. So that the pant leg grazes the shoe. Can you recommend the same?
Christin Kalina - Reply Share
Vielen lieben Dank für diese ausführliche Anleitung.
Die Beschreibung ist sehr gut erklärt und anhand der Fotos kann man sich ein besseres Bild davon machen.
Meine Jeans hat nun die richtige Länge und ich bin sehr stolz auf mein Meisterwerk. :)
Jessica Schütze - Reply Share
Past 24 Hours: 47
Past 7 Days: 287
Past 30 Days: 998
All Time: 160,359
