Up to 20% off select tools
Hair Scrunchie Elastic Replacement
Views: 27K
View statistics:
Past 24 Hours:
10
Past 7 Days:
51
Past 30 Days:
276
All Time:
27,012
Comments: 1
1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Often the elastic interior of a scrunchie will break, while the outer cloth material remains intact. At this point, most people would discard their scrunchie as useless, contributing to the fashion waste stream. Buying a new scrunchie adds to pollution, depletion of natural resources, and unfair labor practices within the fast fashion industry. With the help of this guide, scrunchie users will be able to learn how to simply replace the inner elastic and repair their broken scrunchie. This guide is relatively simple, however, it requires the use of sharp objects, such as a needle and hem ripper.
    1. Hair Scrunchie Elastic Replacement, Hair Scrunchie Elastic: step 1, image 1 of 1
      • There are two seams that hold the fabric outer tube of the scrunchie together. The long seam runs along the entire circumference of the tube. The short seam goes around just one part of the tube.
      Ask FixBot
    2. Hair Scrunchie Elastic Replacement: step 2, image 1 of 2 Hair Scrunchie Elastic Replacement: step 2, image 2 of 2
      • Locate the short seam and use the hem ripper to carefully cut through each stitch without damaging the fabric.
      • Do not cut through the stitches where the long seam intersect with he short seam.
      Ask FixBot
    3. Hair Scrunchie Elastic Replacement: step 3, image 1 of 1
      • Attach the elastic band to the end of a pencil with a piece of tape.
      Ask FixBot
    4. Hair Scrunchie Elastic Replacement: step 4, image 1 of 2 Hair Scrunchie Elastic Replacement: step 4, image 2 of 2
      • Insert the pencil tip into one end of the fabric tube.
      • As you push the pencil through, scrunch the fabric together until the tip comes out the other side.
      Ask FixBot
    5. Hair Scrunchie Elastic Replacement: step 5, image 1 of 2 Hair Scrunchie Elastic Replacement: step 5, image 2 of 2
      • Tie a secure knot with the newly replaced elastic.
      Ask FixBot
    6. Hair Scrunchie Elastic Replacement: step 6, image 1 of 1
      • Prepare your needle and thread by tying a knot at the end.
      Ask FixBot
    7. Hair Scrunchie Elastic Replacement: step 7, image 1 of 1
      • Insert the needle at the spot holding each end of the tube together.
      Ask FixBot
    8. Hair Scrunchie Elastic Replacement: step 8, image 1 of 3 Hair Scrunchie Elastic Replacement: step 8, image 2 of 3 Hair Scrunchie Elastic Replacement: step 8, image 3 of 3
      • Use the ladder stitch technique to sew each end of the tube back together.
      • Use this guide for assistance.
      Ask FixBot
    9. Hair Scrunchie Elastic Replacement: step 9, image 1 of 3 Hair Scrunchie Elastic Replacement: step 9, image 2 of 3 Hair Scrunchie Elastic Replacement: step 9, image 3 of 3
      • Tie a knot and use your finger to keep the knot close as close to the fabric as possible.
      • Repeat this process until the thread is secure.
      Ask FixBot
    10. Hair Scrunchie Elastic Replacement: step 10, image 1 of 1
      • Trim the thread as close to the knot as possible.
      Ask FixBot
This is a simple and effective way to replace the elastic so that you can continue to use the hair accessory.
9 other people completed this guide.
Author
with
Malena Hansen
241 Reputation
1 Guide authored
UC Davis, Team S2-G2, Bender Fall 2018 Member of UC Davis, Team S2-G2, Bender Fall 2018
UCD-BENDER-F18S2G2
3 Members
12 Guides authored
1 Guide Comment
Amazing
Been looking for a way to fix my scrunchie
Thanks!
Mollytheduck1 - Reply Share
Past 24 Hours: 10
Past 7 Days: 51
Past 30 Days: 276
All Time: 27,012
