Up to 20% off select tools
Sew a Ladder Stitch
Views: 17K
View statistics:
Past 24 Hours:
18
Past 7 Days:
119
Past 30 Days:
475
All Time:
16,905
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 28
28 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Sew a Ladder Stitch
Parts
Tools
Introduction
Go to step 1 ↓
A ladder stitch, or closure stitch, is a sewing technique that allows you to close a tear without leaving the stitching visible.
The trick is to make the stitches as small and as even as possible. This technique works for repairing almost any type of tear.
    1. Sew a Ladder Stitch, Sew a Ladder Stitch: step 1, image 1 of 3 Sew a Ladder Stitch, Sew a Ladder Stitch: step 1, image 2 of 3 Sew a Ladder Stitch, Sew a Ladder Stitch: step 1, image 3 of 3
      • Thread your needle and tie a knot in the end.
      • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
      • Drive the needle from the back of the material, just before where the tear starts.
      • Pull the thread taut.
      Ask FixBot
    2. Sew a Ladder Stitch: step 2, image 1 of 2 Sew a Ladder Stitch: step 2, image 2 of 2
      • Take a small stitch, going in and out of the material, on one side of the tear only.
      Ask FixBot
    3. Sew a Ladder Stitch: step 3, image 1 of 2 Sew a Ladder Stitch: step 3, image 2 of 2
      • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
      • Pull the thread taut. This should cinch the material together.
      • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
      Ask FixBot
    4. Sew a Ladder Stitch: step 4, image 1 of 2 Sew a Ladder Stitch: step 4, image 2 of 2
      • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
      • Stitch until you come to the end of the tear.
      Ask FixBot
    5. Sew a Ladder Stitch: step 5, image 1 of 3 Sew a Ladder Stitch: step 5, image 2 of 3 Sew a Ladder Stitch: step 5, image 3 of 3
      • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
      • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
      • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
      • Ensure that the stitches are tight, and cut any excess threads.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 119
Past 30 Days: 475
All Time: 16,905
