Up to 20% off select tools
HP 15-ba0709dx RAM Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
67
All Time:
1,246
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to find your RAM and how to remove it properly.
    1. HP 15-ba0709dx RAM Replacement, Battery: step 1, image 1 of 1
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch on the left and right side until the battery is detached from its slot.
      • A noticeable pop will be heard when the battery is fully released.
      Ask FixBot
    2. HP 15-ba0709dx RAM Replacement: step 2, image 1 of 1
      • Pull the battery out of its slot.
      • Be careful not to damage any of the connectors in the process.
      Ask FixBot
    1. HP 15-ba0709dx RAM Replacement, Back Cover: step 3, image 1 of 1
      • Place the laptop on a clean, flat surface with the bottom side facing up.
      Ask FixBot
    2. HP 15-ba0709dx RAM Replacement: step 4, image 1 of 1
      • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
      • Note: Make sure to keep track of the screws once they have been removed.
      Ask FixBot
    3. HP 15-ba0709dx RAM Replacement: step 5, image 1 of 1
      • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
      • Note:Place these newly removed screws with the ones removed in Step 2.
      Ask FixBot
    4. HP 15-ba0709dx RAM Replacement: step 6, image 1 of 2 HP 15-ba0709dx RAM Replacement: step 6, image 2 of 2
      • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
      • Removing the friction pads will reveal two more anchoring screws.
      • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
      Ask FixBot
    5. HP 15-ba0709dx RAM Replacement: step 7, image 1 of 1
      • Remove disc reader.
      • Note: If all screws are removed it should slide out easily.
      Ask FixBot
    6. HP 15-ba0709dx RAM Replacement: step 8, image 1 of 2 HP 15-ba0709dx RAM Replacement: step 8, image 2 of 2
      • Use a plastic prod to pry the back cover off the laptop.
      • Be careful not to damage the laptop while prying.
      Ask FixBot
    1. HP 15-ba0709dx RAM Replacement, RAM: step 9, image 1 of 1
      • Ensure your computer is shut down.
      • Remove any power adapters and cords connected to the laptop body.
      • Turn the computer over so the bottom is facing up.
      • Follow our guide on how to remove the backcover.
      Ask FixBot
    2. HP 15-ba0709dx RAM Replacement: step 10, image 1 of 1
      • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
      Ask FixBot
    3. HP 15-ba0709dx RAM Replacement: step 11, image 1 of 2 HP 15-ba0709dx RAM Replacement: step 11, image 2 of 2
      • Once the module is released, gently pull the module upwards.
      Ask FixBot
2 other people completed this guide.
Author
with
Reece Marr
369 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 67
All Time: 1,246
