HP 15-ba0709dx Back Cover Replacement
    1. HP 15-ba0709dx Back Cover Replacement, Battery: step 1, image 1 of 1
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch on the left and right side until the battery is detached from its slot.
      • A noticeable pop will be heard when the battery is fully released.
      Ask FixBot
    2. HP 15-ba0709dx Back Cover Replacement: step 2, image 1 of 1
      • Pull the battery out of its slot.
      • Be careful not to damage any of the connectors in the process.
      Ask FixBot
    1. HP 15-ba0709dx Back Cover Replacement, Back Cover: step 3, image 1 of 1
      • Place the laptop on a clean, flat surface with the bottom side facing up.
      Ask FixBot
    2. HP 15-ba0709dx Back Cover Replacement: step 4, image 1 of 1
      • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
      • Note: Make sure to keep track of the screws once they have been removed.
      Ask FixBot
    3. HP 15-ba0709dx Back Cover Replacement: step 5, image 1 of 1
      • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
      • Note:Place these newly removed screws with the ones removed in Step 2.
      Ask FixBot
    4. HP 15-ba0709dx Back Cover Replacement: step 6, image 1 of 2 HP 15-ba0709dx Back Cover Replacement: step 6, image 2 of 2
      • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
      • Removing the friction pads will reveal two more anchoring screws.
      • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
      Ask FixBot
    5. HP 15-ba0709dx Back Cover Replacement: step 7, image 1 of 1
      • Remove disc reader.
      • Note: If all screws are removed it should slide out easily.
      Ask FixBot
    6. HP 15-ba0709dx Back Cover Replacement: step 8, image 1 of 2 HP 15-ba0709dx Back Cover Replacement: step 8, image 2 of 2
      • Use a plastic prod to pry the back cover off the laptop.
      • Be careful not to damage the laptop while prying.
      Ask FixBot
Lydia Brown
369 Reputation
2 Guides authored
2 Guide Comments
Make sure to use a very thin shim, but strong enough to pry.
spotty118 - Reply Share
thanks- also worked for 15-ba053nr
Renee Brandt - Reply Share
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 127
All Time: 3,062
