Up to 20% off select tools
Google Pixel 9 Pro Screen Replacement
Views: 30K
View statistics:
Past 24 Hours:
42
Past 7 Days:
369
Past 30 Days:
1,484
All Time:
30,131
Comments: 33
23 comments on steps, 10 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken, cracked, or unresponsive screen on your Google Pixel 9 Pro.
If your screen doesn't come with adhesive pre‑installed, you'll need replacement screen adhesive in order to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the adhesive.
    1. Google Pixel 9 Pro Screen Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 9 Pro Screen Replacement, Safety precautions: step 1, image 2 of 2
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your phone.
      Ask FixBot
    1. Google Pixel 9 Pro Screen Replacement, Tape over any cracks: step 2, image 1 of 2 Google Pixel 9 Pro Screen Replacement, Tape over any cracks: step 2, image 2 of 2
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
      • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    2. Google Pixel 9 Pro Screen Replacement: step 3, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 3, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 3, image 3 of 3
      • Adhesive secures the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
      • Use a hair dryer, heat gun, or hot plate to heat the entire screen until it's almost too hot to touch.
      • Be careful not to overheat the phone—the battery and plastic components are susceptible to heat damage. Stop heating if the frame becomes too hot to touch.
      Ask FixBot
    3. Google Pixel 9 Pro Screen Replacement, Apply a suction handle: step 4, image 1 of 2 Google Pixel 9 Pro Screen Replacement, Apply a suction handle: step 4, image 2 of 2
      • Apply a suction handle to the center of the screen's top edge.
      Ask FixBot
    4. Google Pixel 9 Pro Screen Replacement, Screen information: step 5, image 1 of 3 Google Pixel 9 Pro Screen Replacement, Screen information: step 5, image 2 of 3 Google Pixel 9 Pro Screen Replacement, Screen information: step 5, image 3 of 3
      • There are delicate metal spring‑contacts around the perimeter of your device. To prevent damaging them when separating the screen, don't insert your pick more than 3 mm deep.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    5. Google Pixel 9 Pro Screen Replacement, Insert an opening pick: step 6, image 1 of 3 Google Pixel 9 Pro Screen Replacement, Insert an opening pick: step 6, image 2 of 3 Google Pixel 9 Pro Screen Replacement, Insert an opening pick: step 6, image 3 of 3
      • Inserting an opening pick is difficult. Be patient and reheat the screen at any point if it feels stuck.
      • Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
      • Insert the tip of an opening pick under the screen.
      • A plastic frame is attached to the backside of the display. When inserting your pick, make sure it's underneath this frame, and not between the frame and the display glass.
      Ask FixBot
    6. Google Pixel 9 Pro Screen Replacement, Separate the screen adhesive: step 7, image 1 of 3 Google Pixel 9 Pro Screen Replacement, Separate the screen adhesive: step 7, image 2 of 3 Google Pixel 9 Pro Screen Replacement, Separate the screen adhesive: step 7, image 3 of 3
      • Slide the opening pick along the top edge to separate the adhesive securing it.
      Ask FixBot
    7. Google Pixel 9 Pro Screen Replacement: step 8, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 8, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 8, image 3 of 3
      • Continue sliding your opening pick around the perimeter of the screen to separate the remaining adhesive.
      Ask FixBot
    1. Google Pixel 9 Pro Screen Replacement, Prop up the screen: step 9, image 1 of 3 Google Pixel 9 Pro Screen Replacement, Prop up the screen: step 9, image 2 of 3 Google Pixel 9 Pro Screen Replacement, Prop up the screen: step 9, image 3 of 3
      • Flip the screen over the right edge of your phone and prop it up with the suction handle.
      • Be careful not to strain the display cable, located near the bottom right corner.
      • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
      Ask FixBot
    2. Google Pixel 9 Pro Screen Replacement, Disconnect the screen: step 10, image 1 of 3 Google Pixel 9 Pro Screen Replacement, Disconnect the screen: step 10, image 2 of 3 Google Pixel 9 Pro Screen Replacement, Disconnect the screen: step 10, image 3 of 3
      • Use angled tweezers to pry up the top edge of the screen cable bracket.
      • Remove the bracket.
      Ask FixBot
    3. Google Pixel 9 Pro Screen Replacement: step 11, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 11, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 11, image 3 of 3
      • Be very careful not to damage any of the small, surface‑mounted components around the screen's press connector.
      • Insert the point of a spudger under the left edge of the screen cable press connector and pry up to disconnect it.
      • Remove the screen.
      Ask FixBot
    4. Google Pixel 9 Pro Screen Replacement, Screen information: step 12, image 1 of 1
      • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
      • To prevent damaging your screen or replacement screen:
      • When handling your screen, grip it by its edges.
      • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
      Ask FixBot
    5. Google Pixel 9 Pro Screen Replacement, Remove all the old screen adhesive: step 13, image 1 of 3 Google Pixel 9 Pro Screen Replacement, Remove all the old screen adhesive: step 13, image 2 of 3 Google Pixel 9 Pro Screen Replacement, Remove all the old screen adhesive: step 13, image 3 of 3
      • When removing the screen adhesive during this step, be very careful not to damage any of the fragile components near the perimeter of the frame.
      • Use a spudger to scrape up and remove all the old screen adhesive from the perimeter of the frame.
      • This will take some time as the adhesive can be tricky to remove. Work slowly and try to roll the adhesive onto itself.
      • Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
      • In order for the new adhesive to form a good bond, the frame needs to be completely clean of all adhesive and its residue.
      • Allow the frame to dry completely before continuing.
      Ask FixBot
    6. Google Pixel 9 Pro Screen Replacement, Orient the adhesive: step 14, image 1 of 3 Google Pixel 9 Pro Screen Replacement, Orient the adhesive: step 14, image 2 of 3 Google Pixel 9 Pro Screen Replacement, Orient the adhesive: step 14, image 3 of 3
      • If your replacement screen has adhesive pre‑installed, skip down seven steps. Otherwise, follow the next seven steps to install new screen adhesive.
      • Before applying the adhesive, make sure you know its proper orientation on the frame. Hold the adhesive over your phone to find its proper alignment.
      • The blue liner should be facing up, with the larger clear liner on the bottom.
      • The adhesive has a corresponding groove on the perimeter of the frame.
      • Cutouts in the blue liner correspond to spring contacts on the frame.
      Ask FixBot
    7. Google Pixel 9 Pro Screen Replacement, Apply the screen adhesive: step 15, image 1 of 1
      • Peel down the top half of the larger, clear liner to expose the adhesive—don't remove the whole liner yet.
      Ask FixBot
    8. Google Pixel 9 Pro Screen Replacement: step 16, image 1 of 2 Google Pixel 9 Pro Screen Replacement: step 16, image 2 of 2
      • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
      • Keep the larger, clear liner folded towards the bottom of the phone during this step.
      • Lay the exposed top edge of the adhesive onto the frame, using the frame's lip to help align it.
      • Once the top edge is properly aligned, gently press down with your fingers to secure it in place.
      Ask FixBot
    9. Google Pixel 9 Pro Screen Replacement: step 17, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 17, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 17, image 3 of 3
      • Slowly lay the rest of the adhesive onto the frame, peeling away the larger clear liner as you go.
      Ask FixBot
    10. Google Pixel 9 Pro Screen Replacement, Secure the screen adhesive: step 18, image 1 of 3 Google Pixel 9 Pro Screen Replacement, Secure the screen adhesive: step 18, image 2 of 3 Google Pixel 9 Pro Screen Replacement, Secure the screen adhesive: step 18, image 3 of 3
      • Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
      Ask FixBot
    11. Google Pixel 9 Pro Screen Replacement: step 19, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 19, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 19, image 3 of 3
      • Use tweezers to grip the top right corner of the blue liner and remove it.
      • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
      Ask FixBot
    12. Google Pixel 9 Pro Screen Replacement: step 20, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 20, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 20, image 3 of 3
      Ask FixBot
    13. Google Pixel 9 Pro Screen Replacement, Connect the replacement screen: step 21, image 1 of 1
      • Carefully lay your replacement screen display‑side‑down just to the right of your phone so you can reconnect the cable.
      Ask FixBot
    14. Google Pixel 9 Pro Screen Replacement: step 22, image 1 of 2 Google Pixel 9 Pro Screen Replacement: step 22, image 2 of 2
      • Be very careful not to strain the screen cable during this step. You may need to hold the screen up at an angle to help position the cable.
      • Align the screen press connector over its socket and gently press down on one side until it clicks into place, then press down on the other side.
      • Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      • Hook the bottom edge of the screen cable bracket into its cutout and firmly press down on the top edge until the bracket clicks into place.
      Ask FixBot
    15. Google Pixel 9 Pro Screen Replacement: step 23, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 23, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 23, image 3 of 3
      • Follow this step only if your screen has adhesive pre‑installed on the underside.
      • Use tweezers or your fingers to remove the two remaining blue liners from the underside of the screen.
      • Skip the next step.
      Ask FixBot
    16. Google Pixel 9 Pro Screen Replacement: step 24, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 24, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 24, image 3 of 3
      • Follow this step if you applied screen adhesive directly to the frame.
      • Use tweezers or your fingers to remove the two remaining liners from the frame. You'll need to carefully hold the screen up to remove the right liner.
      Ask FixBot
    17. Google Pixel 9 Pro Screen Replacement: step 25, image 1 of 1
      • Thoroughly check your replacement screen for any remaining plastic liners (specifically near the front facing camera and screen cable) and use your fingers to remove them—you can identify the liners by their plastic pull tabs.
      • Be very careful not to damage the screen when removing the liners.
      Ask FixBot
    18. Google Pixel 9 Pro Screen Replacement, Secure the screen with its adhesive: step 26, image 1 of 2 Google Pixel 9 Pro Screen Replacement, Secure the screen with its adhesive: step 26, image 2 of 2
      • Carefully flip the screen onto the frame.
      Ask FixBot
    19. Google Pixel 9 Pro Screen Replacement: step 27, image 1 of 3 Google Pixel 9 Pro Screen Replacement: step 27, image 2 of 3 Google Pixel 9 Pro Screen Replacement: step 27, image 3 of 3
      • Firmly press around the perimeter of the screen to secure it to the frame.
      • When powering on your Pixel for the first time after your repair, make sure the phone is laying flat and nothing is touching the screen (fingers, plastic liners, screen protectors, cases).
      Ask FixBot
Congratulations on completing your screen repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
16 other people completed this guide.
Author
with
Spencer Day
210,806 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
10 Guide Comments
ifixit's instructions that show a suction cup to remove a screen or a glass back always assume your glass is intact. I would assume most often it is shattered so forget using a suction cup. I used some thick shipping tape to cover the broken glass which gives the suction cup a chance to hold.
Scott Z - Reply Share
Isnt that why Step 2 is there?.....
Andrew Eyring - Reply Share
Is the screw in the top left corner supposed to stick out? Pulled a screen and the screw in the top left corner sticks out a little.
Travis Brubaker - Reply Share
Took multiple apart and all were that way so apparently that's how there built. Looks like it's close to hitting the display though.
Also Googles Pixel Update and Sowftware Repair Tool says "Couldn't find the unique calibration software for this device" when I try to calibrate the fingerprint reader.
Past 24 Hours: 42
Past 7 Days: 369
Past 30 Days: 1,484
All Time: 30,131
