Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Heavy-Duty F-ClampOptional
Introduction
Go to step 1 ↓This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the battery in your Google Pixel 9.
Lithium-ion batteries have a limited lifespan. If your phone doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
This procedure requires clamping your phone to your workspace. If you don't have clamps, you'll need a second person to secure the phone.
You'll need replacement back glass adhesive to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the rear cover adhesive.
Adhesive secures the perimeter of the back glass to the frame.
Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
Push down to attach the suction cup.
Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
Insert the tip of an opening pick into the gap.
Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
Remove the back glass.
Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
Follow this guide to apply new adhesive and install your back glass.
Tool used on this step:FixMat$31.41
Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
Four 5.4 mm-long screws
One 2.2 mm-long screw
Use a pair of tweezers to peel the flash cable off of the metal midframe.
Use the tip of a spudger to pry up and disconnect the battery connector.
Use a 3IP Torx Plus driver to remove the two screws securing the charging board cover:
One 5.4 mm-long screw
One 2.9 mm-long screw
Use the tip of a spudger to pry up and disconnect the top two interconnect cable press connectors from the bottom edge of the motherboard.
Disconnect the bottom two interconnect cable press connectors from the charging board.
Remove the interconnect cable.
Use the tip of a spudger to pry up and disconnect the secondary interconnect cable's top press connector from the motherboard.
Disconnect the secondary interconnect cable's bottom press connector from the charging board.
Use a 3IP Torx Plus driver to remove the two 2.5 mm-long screws securing the secondary interconnect cable.
Remove the secondary interconnect cable.
Use a 3IP Torx Plus driver to remove the 5.4 mm-long screw securing the antenna board cover.
Use the tip of a spudger to pry up and disconnect the autofocus connector from the motherboard.
Insert one arm of a pair of angled tweezers under the neck of the antenna board's coaxial antenna cable.
Lift straight up to disconnect the antenna.
Use the tip of a spudger to pry up and disconnect the front camera press connector.
Tool used on this step:Standoff Screwdriver for iPhones$5.49
Remove the two screws securing the motherboard:
One 2.9 mm-long 3IP Torx Plus screw
One 5 mm-long standoff screw
Insert the tip of a spudger underneath the bottom right corner of the motherboard.
Use your spudger to lift the motherboard until you can grip the right edge with your fingers.
Grip the right edge of the motherboard and remove it.
Check the condition of the logic board thermal pad—it will either be on the bottom of the logic board or on the frame.
If the pad is undamaged, skip the rest of this step.
If the pad is damaged, use the flat end of a spudger to scrape it up and remove it.
Use isopropyl alcohol (greater than 90%) and a microfiber cloth to remove all thermal pad residue from the frame and bottom of the logic board.
Apply a new thermal pad to its spot on the frame.
Tool used on this step:Finger Stalls$8.99
Use your fingers to peel up the plastic tabs near the bottom edge of the battery.
Fold the tabs under the phone or tape them out of the way so they don't warp when heating the battery in the next step.
Wear finger stalls to help get a solid grip on the battery pull tabs in the next few steps.
Strong strips of adhesive secure the battery to the frame. Heating the battery will soften the adhesive, making it easier to separate.
Use a hair dryer on High heat and Low speed settings to heat the battery for three minutes, while holding the hair dryer about three inches from the battery. Try to evenly spread the heat over the entire surface of the battery.
Move the pull tabs out from under your phone so they're accessible.
Use F‑Clamps or C‑Clamps to secure the phone to your work surface. At minimum, you'll need two clamps—one for the top edge and one for the bottom edge.
If you don't have any clamps, have a friend hold the phone firmly in place.
Pull straight up on the battery pull tabs and apply constant, steady pressure until the battery separates from the frame.
Remove the battery.
If you successfully removed the battery, congratulations! Skip down seven steps for reassembly information.
If the pull tab broke or accidentally slipped out from under the battery, don't worry! Go to the next step for an alternate battery removal method.
Apply two or three drops of isopropyl alcohol (greater than 90%) to the top corners of the battery.
Tool used on this step:Heavy-Duty Suction Cups (Pair)$16.95
Pull the handle on the large suction cup down to open it.
Use your fingers to fold the plastic battery tabs fully out of the way of the battery.
Place the suction cup in the center of the battery.
With one hand, firmly secure the phone to your work surface.
With your free hand, pull the suction cup towards the bottom of your phone with strong, steady force to lift the top edge of the battery. Apply constant pressure with the suction cup to allow time for the adhesive to separate.
Remove the battery from its recess.
Take the suction cup off the battery.
If the battery pull tab stayed in the recess, remove it.
Use a spudger to scrape up and remove all the old battery adhesive from the frame.
Once all the old adhesive has been removed, use isopropyl alcohol (greater than 90%) and a microfiber cloth to clean up any adhesive residue.
Allow the frame to completely dry before installing a replacement battery.
Tool used on this step:Tesa 61395 Tape$2.95
Remove any tape or liners from the battery cable.
Remove the larger plastic liner from the bottom of the battery to expose the adhesive.
Firmly press the battery into its recess to secure it with the adhesive.
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
4 other people completed this guide.
