Up to 20% off select tools
Google Pixel 7a Battery Replacement
Views: 214K
View statistics:
Past 24 Hours:
204
Past 7 Days:
1,383
Past 30 Days:
6,889
All Time:
213,697
Comments: 145
94 comments on steps, 51 guide comments.
Go to guide comments
Completed: 151
151 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to remove or replace the battery in your Google Pixel 7a.
Lithium-ion batteries have a limited lifespan. If your phone doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
Note: This guide uses the Verizon model Google Pixel 7a (G0DZQ), which has a 5G mmWave antenna. If you have a different carrier model, some photos in this guide differ, but the procedure is the same.
If your battery is swollen, take appropriate precautions.
You'll need replacement adhesive in order to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the adhesive.
    1. Google Pixel 7a Battery Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Google Pixel 7a Battery Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your battery to drain below 25% before starting this repair. A charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone and fully power it down.
      Ask FixBot
    1. Google Pixel 7a Battery Replacement, Soften the adhesive: step 2, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the rear cover for three minutes.
      • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover.
      • Only heat the phone enough so it's just hot to the touch. Extreme heat can damage the screen, rear cover, or battery.
      Ask FixBot
    2. Google Pixel 7a Battery Replacement, Secure an Anti-Clamp: step 3, image 1 of 3 Google Pixel 7a Battery Replacement, Secure an Anti-Clamp: step 3, image 2 of 3 Google Pixel 7a Battery Replacement, Secure an Anti-Clamp: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backward to unlock the Anti-Clamp's arms.
      • Slide the arms over the bottom edge of the phone, with one suction cup on the rear cover and one on the screen.
      • Squeeze the cups together to create suction.
      Ask FixBot
    3. Google Pixel 7a Battery Replacement, Use the Anti-Clamp to create a gap: step 4, image 1 of 3 Google Pixel 7a Battery Replacement, Use the Anti-Clamp to create a gap: step 4, image 2 of 3 Google Pixel 7a Battery Replacement, Use the Anti-Clamp to create a gap: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
      • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
      Ask FixBot
    4. Google Pixel 7a Battery Replacement, Insert an opening pick using the Anti-Clamp: step 5, image 1 of 1
      • While the heat from an iOpener is sufficient to separate the rear cover, it might cool down while you set up the Anti-Clamp. Reheat the rear cover if you need more time to set it up.
      • Place an object under your phone so it rests level while between the Anti-Clamp's arms.
      • Wait one minute, or until the adhesive separates, for a gap to form along the bottom edge of the phone.
      • Insert an opening pick into the gap between the rear cover and the frame.
      • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat with a hair dryer or heat gun if the rear cover cools down.
      • Remove the suction cups from the phone using their pull-tabs and set the Anti-Clamp aside.
      Ask FixBot
    5. Google Pixel 7a Battery Replacement, Insert an opening pick using a suction handle: step 6, image 1 of 3 Google Pixel 7a Battery Replacement, Insert an opening pick using a suction handle: step 6, image 2 of 3 Google Pixel 7a Battery Replacement, Insert an opening pick using a suction handle: step 6, image 3 of 3
      • If you've already inserted an opening pick using the Anti-Clamp, skip this step.
      • Apply a suction handle to the center of the bottom edge of the rear cover.
      • Pull up on the suction handle with a strong, steady force until a gap forms between the rear cover and frame.
      • Insert the tip of an opening pick into the gap.
      • Remove the suction handle.
      Ask FixBot
    6. Google Pixel 7a Battery Replacement, Adhesive information: step 7, image 1 of 2 Google Pixel 7a Battery Replacement, Adhesive information: step 7, image 2 of 2
      • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you slice the adhesive.
      Ask FixBot
    7. Google Pixel 7a Battery Replacement, Angle the opening pick: step 8, image 1 of 3 Google Pixel 7a Battery Replacement, Angle the opening pick: step 8, image 2 of 3 Google Pixel 7a Battery Replacement, Angle the opening pick: step 8, image 3 of 3
      • Angle the opening pick upward so the tip faces away from the frame.
      • From here on, keep all opening picks angled upward while slicing until the rear cover is fully removed.
      • Slide your pick to the bottom left corner of the rear cover.
      • Leave this pick in place to prevent the adhesive from resealing.
      Ask FixBot
    8. Google Pixel 7a Battery Replacement, Separate the bottom edge adhesive: step 9, image 1 of 2 Google Pixel 7a Battery Replacement, Separate the bottom edge adhesive: step 9, image 2 of 2
      • Insert a second opening pick in the bottom left corner.
      • Slide the new pick to the bottom right corner of the rear cover to separate the bottom edge adhesive.
      Ask FixBot
    9. Google Pixel 7a Battery Replacement, Soften the right edge adhesive: step 10, image 1 of 1
      • Apply a heated iOpener to the right edge of the rear cover for two minutes.
      • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover. Remember to not overheat the phone.
      Ask FixBot
    10. Google Pixel 7a Battery Replacement, Separate the right edge adhesive: step 11, image 1 of 3 Google Pixel 7a Battery Replacement, Separate the right edge adhesive: step 11, image 2 of 3 Google Pixel 7a Battery Replacement, Separate the right edge adhesive: step 11, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the wireless charging coil.
      • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
      • Insert a third opening pick in the bottom right corner of the rear cover.
      • Slide your pick up the right edge of the rear cover to separate its adhesive. Stop when you reach the camera bar.
      Ask FixBot
    11. Google Pixel 7a Battery Replacement, Soften the left edge adhesive: step 12, image 1 of 2 Google Pixel 7a Battery Replacement, Soften the left edge adhesive: step 12, image 2 of 2
      • Apply a heated iOpener to the left edge of the rear cover for two minutes.
      Ask FixBot
    12. Google Pixel 7a Battery Replacement, Separate the left edge adhesive: step 13, image 1 of 3 Google Pixel 7a Battery Replacement, Separate the left edge adhesive: step 13, image 2 of 3 Google Pixel 7a Battery Replacement, Separate the left edge adhesive: step 13, image 3 of 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid damaging the wireless charging coil and button cables.
      • For a visual reference, you can measure 2 mm from the tip and mark your pick with a permanent marker.
      • Insert a fourth opening pick in the bottom left corner of the rear cover.
      • Slide your pick up the left edge of the rear cover to separate the adhesive. Stop when you reach the camera bar.
      • Be careful not to slice the two button cables running along the left edge. If you feel resistance, stop, back the pick out slightly, and slice slowly.
      Ask FixBot
    13. Google Pixel 7a Battery Replacement, Soften the top edge adhesive: step 14, image 1 of 1
      • Apply a heated iOpener to the top edge of the rear cover for two minutes.
      Ask FixBot
    14. Google Pixel 7a Battery Replacement, Separate the antenna bracket adhesive: step 15, image 1 of 3 Google Pixel 7a Battery Replacement, Separate the antenna bracket adhesive: step 15, image 2 of 3 Google Pixel 7a Battery Replacement, Separate the antenna bracket adhesive: step 15, image 3 of 3
      • There's a thick strip of adhesive along the antenna housing.
      • Insert a fifth opening pick in the top left corner of the rear cover between 8 mm and 10 mm (0.3–0.4 in) deep, or just over halfway between the tip of the pick and the iFixit logo.
      • If you can't insert the pick, start with the small gap near the camera bar from the previous pick.
      • Slide your pick halfway across the top edge to separate the antenna bracket adhesive. Stop at the halfway point along the top edge.
      Ask FixBot
    15. Google Pixel 7a Battery Replacement, Separate the remaining top edge adhesive: step 16, image 1 of 3 Google Pixel 7a Battery Replacement, Separate the remaining top edge adhesive: step 16, image 2 of 3 Google Pixel 7a Battery Replacement, Separate the remaining top edge adhesive: step 16, image 3 of 3
      • Pull your opening pick out to a depth of 3 mm.
      • Slide your pick to the top right corner to slice the rest of the top edge adhesive.
      • Don't insert your pick deeper than 3 mm to avoid damaging the antenna housing graphite tape.
      Ask FixBot
    16. Google Pixel 7a Battery Replacement, Rotate your top edge opening picks: step 17, image 1 of 3 Google Pixel 7a Battery Replacement, Rotate your top edge opening picks: step 17, image 2 of 3 Google Pixel 7a Battery Replacement, Rotate your top edge opening picks: step 17, image 3 of 3
      • Remember to angle your picks upward and away from the frame during this step.
      • Roll the top edge pick so its flat edge is under the rear cover.
      • Roll the picks on each side of the camera bar so their flat edges are under the camera bar.
      Ask FixBot
    17. Google Pixel 7a Battery Replacement, Pry up the camera bar: step 18, image 1 of 3 Google Pixel 7a Battery Replacement, Pry up the camera bar: step 18, image 2 of 3 Google Pixel 7a Battery Replacement, Pry up the camera bar: step 18, image 3 of 3
      • There's a long strip of adhesive securing the rear cover below the camera bar.
      • Use the opening picks under the camera bar to pry the top edge of the rear cover from the frame.
      • Pry back and forth until the camera bar loosens.
      • Be careful not to bend the rear cover. Only pry enough to loosen the adhesive near the camera bar. If the adhesive feels stubborn, rotate the rear cover side-to-side to further loosen the adhesive.
      Ask FixBot
    18. Google Pixel 7a Battery Replacement, Finish separating the adhesive: step 19, image 1 of 3 Google Pixel 7a Battery Replacement, Finish separating the adhesive: step 19, image 2 of 3 Google Pixel 7a Battery Replacement, Finish separating the adhesive: step 19, image 3 of 3
      • Slide the opening picks from the camera bar down the long edges of the rear cover to separate any adhesive that may have resealed.
      Ask FixBot
    19. Google Pixel 7a Battery Replacement, Remove the rear cover: step 20, image 1 of 2 Google Pixel 7a Battery Replacement, Remove the rear cover: step 20, image 2 of 2
      • Remove the rear cover.
      • During reassembly:
      • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
      • Follow this guide to apply new adhesive and install your rear cover.
      Ask FixBot
    1. Google Pixel 7a Battery Replacement, Soften the flash unit adhesive: step 21, image 1 of 2 Google Pixel 7a Battery Replacement, Soften the flash unit adhesive: step 21, image 2 of 2
      • Apply a heated iOpener to the flash unit for one minute to soften the adhesive securing it to the logic board cover.
      • Alternatively, you can use a hair dryer or heat gun to warm the flash.
      • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
      Ask FixBot
    2. Google Pixel 7a Battery Replacement, Separate the flash unit adhesive: step 22, image 1 of 2 Google Pixel 7a Battery Replacement, Separate the flash unit adhesive: step 22, image 2 of 2
      • Be careful not to slip and tear the flash cable, as it's very fragile.
      • Slide your pick under the right edge of the flash to separate the adhesive securing it to the cover.
      Ask FixBot
    3. Google Pixel 7a Battery Replacement, Clean the logic board cover: step 23, image 1 of 3 Google Pixel 7a Battery Replacement, Clean the logic board cover: step 23, image 2 of 3 Google Pixel 7a Battery Replacement, Clean the logic board cover: step 23, image 3 of 3
      Buy
      • If the copper tape lifted away with the flash, use tweezers or your fingers to remove the black foam residue from the logic board cover.
      Ask FixBot
    4. Google Pixel 7a Battery Replacement, Remove the old copper tape: step 24, image 1 of 3 Google Pixel 7a Battery Replacement, Remove the old copper tape: step 24, image 2 of 3 Google Pixel 7a Battery Replacement, Remove the old copper tape: step 24, image 3 of 3
      • Be careful not to damage the battery with your tool during this step.
      • Apply a heated iOpener to the underside of the flash for one minute.
      • Hold the neck of the flash cable steady and use tweezers to peel and remove the copper tape from the flash unit.
      • If the copper tape stayed on the logic board cover and you have a replacement, remove the old tape now.
      Ask FixBot
    5. Google Pixel 7a Battery Replacement, Unfasten the logic board cover: step 25, image 1 of 2 Google Pixel 7a Battery Replacement, Unfasten the logic board cover: step 25, image 2 of 2
      iFixit Precision 4 mm Screwdriver Bit
      $2.99
      Buy
      • While the Pixel 7a uses Torx Plus screws, standard Torx drivers may still work. If your kit came with standard Torx bits, use the T2 bit to remove 1IP Torx Plus screws, and the T3 Torx bit to remove 3IP Torx Plus screws. Make sure to apply constant, downward force to prevent stripping.
      • Use a 3IP Torx Plus driver to remove the thirteen 4.3 mm screws securing the logic board cover.
      • Use a 1IP Torx Plus driver to remove the 1.5 mm screw securing the right edge of the cover.
      Ask FixBot
    6. Google Pixel 7a Battery Replacement, Unclip the logic board cover: step 26, image 1 of 2 Google Pixel 7a Battery Replacement, Unclip the logic board cover: step 26, image 2 of 2
      • Insert an opening pick between the bottom right corner of the logic board cover and the frame.
      • Pry up to release the clip securing the cover.
      Ask FixBot
    7. Google Pixel 7a Battery Replacement, Free the flash unit: step 27, image 1 of 3 Google Pixel 7a Battery Replacement, Free the flash unit: step 27, image 2 of 3 Google Pixel 7a Battery Replacement, Free the flash unit: step 27, image 3 of 3
      • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
      • During reassembly, thread the flash through its cutout as you lower the logic board into place.
      Ask FixBot
    8. Google Pixel 7a Battery Replacement, Remove the wireless charging assembly: step 28, image 1 of 2 Google Pixel 7a Battery Replacement, Remove the wireless charging assembly: step 28, image 2 of 2
      • Remove the wireless charging assembly.
      Ask FixBot
    1. Google Pixel 7a Battery Replacement, Remove the connector cover: step 29, image 1 of 3 Google Pixel 7a Battery Replacement, Remove the connector cover: step 29, image 2 of 3 Google Pixel 7a Battery Replacement, Remove the connector cover: step 29, image 3 of 3
      Buy
      • Use your 1IP Torx Plus driver to remove the 1.5 mm screw securing the connector cover.
      • Use tweezers or your fingers to remove the cover.
      • During reassembly, place the upper left corner of the cover under the hook on the logic board before installing its screw.
      Ask FixBot
    2. Google Pixel 7a Battery Replacement: step 30, image 1 of 1
      • The Verizon model (G0DZQ) Google Pixel 7a has an extra cable and connector for the 5G mmWave antenna. Unless otherwise mentioned, the rest of the guide procedure is the same for either type of phone.
      Ask FixBot
    3. Google Pixel 7a Battery Replacement, Disconnect the battery: step 31, image 1 of 2 Google Pixel 7a Battery Replacement, Disconnect the battery: step 31, image 2 of 2
      • Insert the flat end of a spudger under the top edge of the battery press connector.
      • Pry straight up to disconnect the battery press connector.
      • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
      Ask FixBot
    1. Google Pixel 7a Battery Replacement, Disconnect the 5G mmWave antenna: step 32, image 1 of 2 Google Pixel 7a Battery Replacement, Disconnect the 5G mmWave antenna: step 32, image 2 of 2
      • Verizon models: Use the point of your spudger to pry up and disconnect the 5G mmWave press connector.
      Ask FixBot
    1. Google Pixel 7a Battery Replacement, Move the cables: step 33, image 1 of 3 Google Pixel 7a Battery Replacement, Move the cables: step 33, image 2 of 3 Google Pixel 7a Battery Replacement, Move the cables: step 33, image 3 of 3
      • Move the battery cable toward the bottom of the phone, out of the way of the battery.
      • Verizon models: Move the 5G mmWave cable toward the top of the phone.
      Ask FixBot
    2. Google Pixel 7a Battery Replacement, Peel up the battery jacket: step 34, image 1 of 3 Google Pixel 7a Battery Replacement, Peel up the battery jacket: step 34, image 2 of 3 Google Pixel 7a Battery Replacement, Peel up the battery jacket: step 34, image 3 of 3
      • Peel up both sides of the battery jacket from the battery.
      • If you're using a tool, be careful not to puncture the battery.
      Ask FixBot
    3. Google Pixel 7a Battery Replacement, Soften the battery adhesive: step 35, image 1 of 2 Google Pixel 7a Battery Replacement, Soften the battery adhesive: step 35, image 2 of 2
      • Two strips of adhesive secure the upper half of the battery. The battery jacket is just below these strips.
      • Flip the phone over and use a hair dryer, heat gun, or hot plate to evenly heat the screen until the entire frame is warm to the touch.
      • Be careful not to overheat the screen, as it's susceptible to heat damage. Don't concentrate the heat in any one spot.
      Ask FixBot
    4. Google Pixel 7a Battery Replacement, Slide the battery jacket: step 36, image 1 of 3 Google Pixel 7a Battery Replacement, Slide the battery jacket: step 36, image 2 of 3 Google Pixel 7a Battery Replacement, Slide the battery jacket: step 36, image 3 of 3
      • Firmly grip both sides of the battery jacket. Hold them at a low angle, but up high enough so they don't snag on any logic board components or the frame.
      • Slide each end of the jacket toward the top of the battery in a sawing motion to cut through the bottom portion of adhesive.
      • It might take a lot of back and forth sawing motions before the adhesive comes loose. If the jacket rips, skip down two steps for an alternate method.
      • Stop sawing when the jacket reaches halfway up the battery.
      • Take extra care to not cut the ribbon cable connecting the volume buttons pictured on the left, or the copper shield on the right.
      Ask FixBot
    5. Google Pixel 7a Battery Replacement, Lift the battery: step 37, image 1 of 2 Google Pixel 7a Battery Replacement, Lift the battery: step 37, image 2 of 2
      • Firmly pull up on each end of the battery jacket for one minute to slowly allow the adhesive to loosen.
      • If the battery still feels stuck, apply more heat or skip to the next step for an alternate method.
      Ask FixBot
    6. Google Pixel 7a Battery Replacement, Alternate method to remove the battery: step 38, image 1 of 2 Google Pixel 7a Battery Replacement, Alternate method to remove the battery: step 38, image 2 of 2
      • If you couldn't remove the battery using the jacket, follow the next three steps for an alternate method.
      • Fill a pipette or syringe with highly-concentrated isopropyl alcohol (over 90%).
      • Apply a few drops of isopropyl alcohol between the left edge of the battery and the frame.
      • Wait one minute for the adhesive to soften.
      Ask FixBot
    7. Google Pixel 7a Battery Replacement: step 39, image 1 of 3 Google Pixel 7a Battery Replacement: step 39, image 2 of 3 Google Pixel 7a Battery Replacement: step 39, image 3 of 3
      • Move the side button tab to the left, away from the battery.
      • Insert the flat end of an opening pick between the left edge of the battery and the frame.
      Ask FixBot
    8. Google Pixel 7a Battery Replacement: step 40, image 1 of 3 Google Pixel 7a Battery Replacement: step 40, image 2 of 3 Google Pixel 7a Battery Replacement: step 40, image 3 of 3
      • Take care not to deform or puncture the battery—a damaged battery is a potential safety hazard.
      • Firmly bend the opening pick away from the battery. Keep steady pressure on the pick for one minute.
      • Once the adhesive begins to separate, slide your pick deeper under the battery and continue prying it up.
      • If, after a minute, the adhesive doesn't loosen, apply a few more drops of isopropyl alcohol and try again.
      Ask FixBot
    9. Google Pixel 7a Battery Replacement, Remove the battery: step 41, image 1 of 2 Google Pixel 7a Battery Replacement, Remove the battery: step 41, image 2 of 2
      • Remove the battery.
      Ask FixBot
    10. Google Pixel 7a Battery Replacement, Prepare your frame for reassembly: step 42, image 1 of 3 Google Pixel 7a Battery Replacement, Prepare your frame for reassembly: step 42, image 2 of 3 Google Pixel 7a Battery Replacement, Prepare your frame for reassembly: step 42, image 3 of 3
      Buy
      • The next three steps show how to apply new adhesive and install a new battery.
      • Use the flat end of your spudger to scrape an edge of the old adhesive into a ball large enough to grip with a pair of tweezers.
      • Use tweezers or your fingers to peel and remove the old adhesive from the frame.
      • If any residue remains, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the frame and wipe it with a lint-free or microfiber cloth.
      Ask FixBot
    11. Google Pixel 7a Battery Replacement: step 43, image 1 of 3 Google Pixel 7a Battery Replacement: step 43, image 2 of 3 Google Pixel 7a Battery Replacement: step 43, image 3 of 3
      • If your battery comes with adhesive pre-installed, remove its adhesive liners and skip this step.
      • Peel the two strips of battery adhesive from their large liner.
      • Apply the short strip of adhesive to the right side of the battery recess, using the white lines on the frame to position it.
      • Apply the long strip of adhesive to the left side of the recess.
      • Remove the blue liners from the adhesive strips.
      Ask FixBot
    12. Google Pixel 7a Battery Replacement, Align and secure the battery: step 44, image 1 of 3 Google Pixel 7a Battery Replacement, Align and secure the battery: step 44, image 2 of 3 Google Pixel 7a Battery Replacement, Align and secure the battery: step 44, image 3 of 3
      • While holding the battery just above its recess in the frame, reconnect its cable.
      • Press the battery into place.
      • Disconnect the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, starting from this step.
Calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
151 other people completed this guide.
Author
with
Clay Eickemeyer
109,670 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
51 Guide Comments
I may have made a mistake in this process. I have a question for you. How can I chat with you?
先輩ゲーマー - Reply Share
Through here is just fine! If you have a more general question, I might recommend you ask in the answers forum.
Clay Eickemeyer - Reply Share
Which part did you lose?
Past 24 Hours: 204
Past 7 Days: 1,383
Past 30 Days: 6,889
All Time: 213,697
