Up to 20% off select tools
Google Pixel 4 Bottom Microphone Replacement
Views: 9.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
100
All Time:
9,232
Comments: 9
7 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace the bottom side’s microphone on your Google Pixel 4.
The microphone is sealed against the frame with an adhesive gasket. If you remove the microphone, the Pixel will no longer retain its water resistance.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
    1. Google Pixel 4 Bottom Microphone Replacement, Remove the SIM card tray: step 1, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement, Remove the SIM card tray: step 1, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement, Remove the SIM card tray: step 1, image 3 of 3
      • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
      • Press firmly to eject the tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. Google Pixel 4 Bottom Microphone Replacement, Heat the back panel glass: step 2, image 1 of 1
      • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Google Pixel 4 Bottom Microphone Replacement, Apply a suction cup: step 3, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement, Apply a suction cup: step 3, image 2 of 2
      • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
      • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
      Ask FixBot
    3. Google Pixel 4 Bottom Microphone Replacement, Insert an opening pick: step 4, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement, Insert an opening pick: step 4, image 2 of 2
      • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Ask FixBot
    4. Google Pixel 4 Bottom Microphone Replacement, Begin to slice the adhesive: step 5, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement, Begin to slice the adhesive: step 5, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement, Begin to slice the adhesive: step 5, image 3 of 3
      • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
      • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
      • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. Google Pixel 4 Bottom Microphone Replacement, Slice the lefthand-side adhesive: step 6, image 1 of 1
      • Prepare an iOpener and apply it on the left edge of the phone for one minute.
      Ask FixBot
    6. Google Pixel 4 Bottom Microphone Replacement: step 7, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 7, image 2 of 2
      • Insert a second opening pick underneath the back panel directly over the charge port.
      • Slide the opening pick to the bottom left corner of the phone.
      Ask FixBot
    7. Google Pixel 4 Bottom Microphone Replacement: step 8, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 8, image 2 of 2
      • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
      • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
      • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
      Ask FixBot
    8. Google Pixel 4 Bottom Microphone Replacement, Slice righthand-side adhesive: step 9, image 1 of 1
      • Prepare an iOpener and apply it on the right edge of the phone for one minute.
      Ask FixBot
    9. Google Pixel 4 Bottom Microphone Replacement: step 10, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement: step 10, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement: step 10, image 3 of 3
      • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
      • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
      • Stop when you reach the top right corner, and leave the pick inserted.
      Ask FixBot
    10. Google Pixel 4 Bottom Microphone Replacement, Slice the top-side adhesive: step 11, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement, Slice the top-side adhesive: step 11, image 2 of 2
      • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
      Ask FixBot
    11. Google Pixel 4 Bottom Microphone Replacement, Lift up the back panel: step 12, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement, Lift up the back panel: step 12, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement, Lift up the back panel: step 12, image 3 of 3
      • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
      • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
      Ask FixBot
    12. Google Pixel 4 Bottom Microphone Replacement: step 13, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 13, image 2 of 2
      • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
      • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
      Ask FixBot
    13. Google Pixel 4 Bottom Microphone Replacement, Disconnect the battery: step 14, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Remove the five T3 Torx screws securing the battery connector shield:
      • Four 4.0 mm screws
      • One 2.1 mm screw
      Ask FixBot
    14. Google Pixel 4 Bottom Microphone Replacement: step 15, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 15, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the battery connector shield.
      Ask FixBot
    15. Google Pixel 4 Bottom Microphone Replacement: step 16, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 16, image 2 of 2
      • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
      • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    16. Google Pixel 4 Bottom Microphone Replacement: step 17, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 17, image 2 of 2
      • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
      Ask FixBot
    17. Google Pixel 4 Bottom Microphone Replacement, Disconnect the back panel connector: step 18, image 1 of 1
      • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
      Ask FixBot
    18. Google Pixel 4 Bottom Microphone Replacement: step 19, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 19, image 2 of 2
      • Use a pair of tweezers to remove the back panel connector cover.
      Ask FixBot
    19. Google Pixel 4 Bottom Microphone Replacement: step 20, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 20, image 2 of 2
      • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
      Ask FixBot
    20. Google Pixel 4 Bottom Microphone Replacement, Remove the back panel: step 21, image 1 of 1
      • Remove the back panel.
      • During reassembly, follow this guide to install custom-cut adhesives for your device.
      • Follow this guide if you are using a pre-cut adhesive card.
      Ask FixBot
    1. Google Pixel 4 Bottom Microphone Replacement, Front Camera and Sensor Assembly: step 22, image 1 of 1
      • Use a T3 Torx driver to remove the four 4 mm screws securing the camera connector cover.
      Ask FixBot
    2. Google Pixel 4 Bottom Microphone Replacement: step 23, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement: step 23, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement: step 23, image 3 of 3
      Buy
      • Using a pair of tweezers, tilt the camera cover up and slide it out of the retaining slot on the upper right corner of the phone to remove.
      Ask FixBot
    3. Google Pixel 4 Bottom Microphone Replacement, Disconnect the camera and sensor connectors: step 24, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement, Disconnect the camera and sensor connectors: step 24, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement, Disconnect the camera and sensor connectors: step 24, image 3 of 3
      • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
      Ask FixBot
    4. Google Pixel 4 Bottom Microphone Replacement: step 25, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 25, image 2 of 2
      • Disconnect the laser module connector.
      Ask FixBot
    5. Google Pixel 4 Bottom Microphone Replacement, Remove the front camera and sensor assembly: step 26, image 1 of 1
      • Use a T3 Torx driver to remove the two 2.4 mm screws securing the front camera and sensor assembly.
      Ask FixBot
    6. Google Pixel 4 Bottom Microphone Replacement: step 27, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement: step 27, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement: step 27, image 3 of 3
      • Use a pair of tweezers to remove the front camera and sensor assembly.
      Ask FixBot
    1. Google Pixel 4 Bottom Microphone Replacement, Motherboard: step 28, image 1 of 1
      • Remove the two T3 Torx screws securing the vibration motor shield:
      • One 4.2 mm screw
      • One 4.4 mm shouldered screw
      Ask FixBot
    2. Google Pixel 4 Bottom Microphone Replacement: step 29, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 29, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the vibration motor shield.
      Ask FixBot
    3. Google Pixel 4 Bottom Microphone Replacement, Disconnect the motherboard press connectors: step 30, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement, Disconnect the motherboard press connectors: step 30, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement, Disconnect the motherboard press connectors: step 30, image 3 of 3
      • Use the pointed end of a spudger to disconnect the two rear-facing camera connectors from the motherboard.
      Ask FixBot
    4. Google Pixel 4 Bottom Microphone Replacement: step 31, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement: step 31, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement: step 31, image 3 of 3
      • Disconnect the side buttons connector from the motherboard.
      • Disconnect the earpiece speaker connector from the motherboard.
      Ask FixBot
    5. Google Pixel 4 Bottom Microphone Replacement: step 32, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement: step 32, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement: step 32, image 3 of 3
      • Disconnect the left grip sensor connector from the motherboard.
      • Disconnect the charge port connector from the motherboard.
      Ask FixBot
    6. Google Pixel 4 Bottom Microphone Replacement: step 33, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement: step 33, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement: step 33, image 3 of 3
      • Disconnect the display connector from the motherboard.
      • Disconnect the right grip sensor connector from the motherboard.
      Ask FixBot
    7. Google Pixel 4 Bottom Microphone Replacement, Disconnect the antennas: step 34, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement, Disconnect the antennas: step 34, image 2 of 2
      • Use a pair of tweezers to grip the metal clip and pull the connector straight up off of the motherboard
      • You can also a spudger and pry up gently to unclip the bottom antenna connector from the motherboard.
      Ask FixBot
    8. Google Pixel 4 Bottom Microphone Replacement: step 35, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 35, image 2 of 2
      • Disconnect the bottom microphone connector from the motherboard.
      Ask FixBot
    9. Google Pixel 4 Bottom Microphone Replacement: step 36, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement: step 36, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement: step 36, image 3 of 3
      • Gently pry back—but don't remove—the two battery adhesive pull tabs lightly adhered to the motherboard.
      Ask FixBot
    10. Google Pixel 4 Bottom Microphone Replacement, Remove the motherboard: step 37, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement, Remove the motherboard: step 37, image 2 of 2
      • Using a spudger, pivot the top end of the motherboard up and out of the phone's frame.
      Ask FixBot
    11. Google Pixel 4 Bottom Microphone Replacement: step 38, image 1 of 3 Google Pixel 4 Bottom Microphone Replacement: step 38, image 2 of 3 Google Pixel 4 Bottom Microphone Replacement: step 38, image 3 of 3
      • Slowly lift out the motherboard, being careful not to snag any ribbon cable connectors.
      • The rear-facing camera module connectors loop around the motherboard, and the camera module is not secured to the phone, so it may lift out with the motherboard during this step.
      • Completely remove the motherboard.
      • When removing the motherboard, the small rubber bottom microphone cover may fall off. Don't lose it.
      • When reinstalling the motherboard, check that no ribbon cable connectors are caught underneath.
      Ask FixBot
    1. Google Pixel 4 Bottom Microphone Replacement, Remove the microphone: step 39, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement, Remove the microphone: step 39, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the small rubber microphone cover.
      Ask FixBot
    2. Google Pixel 4 Bottom Microphone Replacement: step 40, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 40, image 2 of 2
      • Use the pointed end of a spudger to peel the microphone away from the bottom edge of the phone's frame. It's secured with some light adhesive.
      Ask FixBot
    3. Google Pixel 4 Bottom Microphone Replacement: step 41, image 1 of 2 Google Pixel 4 Bottom Microphone Replacement: step 41, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Use a pair of tweezers to remove the microphone.
      • Before you install a replacement microphone, check the adhesive gasket:
      • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the hole.
      • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Author
with
Carsten Frauenheim
175,104 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
Is this mic also compatible with the 4 XL?
Oluwademilade Akintan - Reply Share
Does the Pixel 4 have the same bottom mic as the Pixel 4A 5G?
C Hoang - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 100
All Time: 9,232
