Google Pixel 3 XL Battery Replacement
    1. Google Pixel 3 XL Battery Replacement, Heat the edge of the back cover: step 1, image 1 of 3 Google Pixel 3 XL Battery Replacement, Heat the edge of the back cover: step 1, image 2 of 3 Google Pixel 3 XL Battery Replacement, Heat the edge of the back cover: step 1, image 3 of 3
      • Heat an iOpener and apply it to the right edge of the back cover for a minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      • While you wait, note the following areas on the back cover:
      • Strong adhesive—there are large patches of adhesive near the bottom of the phone.
      • Fingerprint sensor cable—be careful not to slice through the cable as you pry
      Ask FixBot
    2. Google Pixel 3 XL Battery Replacement, Create a gap under the back cover: step 2, image 1 of 3 Google Pixel 3 XL Battery Replacement, Create a gap under the back cover: step 2, image 2 of 3 Google Pixel 3 XL Battery Replacement, Create a gap under the back cover: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the back cover, as close to the edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Ask FixBot
    3. Google Pixel 3 XL Battery Replacement, Loosen the right edge adhesives: step 3, image 1 of 3 Google Pixel 3 XL Battery Replacement, Loosen the right edge adhesives: step 3, image 2 of 3 Google Pixel 3 XL Battery Replacement, Loosen the right edge adhesives: step 3, image 3 of 3
      • Slide the opening pick along the right edge to slice through the adhesive.
      • The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
      • Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Google Pixel 3 XL Battery Replacement, Heat the bottom edge of the back cover: step 4, image 1 of 1
      • Apply a heated iOpener to the bottom of the back cover for a minute.
      Ask FixBot
    5. Google Pixel 3 XL Battery Replacement, Slice through the bottom adhesives: step 5, image 1 of 3 Google Pixel 3 XL Battery Replacement, Slice through the bottom adhesives: step 5, image 2 of 3 Google Pixel 3 XL Battery Replacement, Slice through the bottom adhesives: step 5, image 3 of 3
      • Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
      • Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat.
      • Leave a pick in the edge to prevent the adhesive from re-sealing.
      Ask FixBot
    6. Google Pixel 3 XL Battery Replacement, Slice through the remaining edges: step 6, image 1 of 3 Google Pixel 3 XL Battery Replacement, Slice through the remaining edges: step 6, image 2 of 3 Google Pixel 3 XL Battery Replacement, Slice through the remaining edges: step 6, image 3 of 3
      • Continue heating and slicing the remaining edges of the phone.
      • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
      • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
      Ask FixBot
    7. Google Pixel 3 XL Battery Replacement, Slice through the leftover adhesive: step 7, image 1 of 1
      • Gently pry up the right edge of the back cover.
      • Use an opening pick to slice through any remaining adhesive along the edges.
      Ask FixBot
    8. Google Pixel 3 XL Battery Replacement, Swing open the back cover: step 8, image 1 of 3 Google Pixel 3 XL Battery Replacement, Swing open the back cover: step 8, image 2 of 3 Google Pixel 3 XL Battery Replacement, Swing open the back cover: step 8, image 3 of 3
      • Swing the right edge of the back cover upwards and rest the flipped panel along the left side of the phone.
      • Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched.
      • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • During reassembly, follow this guide to install custom-cut adhesives for your back cover.
      • If you replaced the fingerprint sensor, you'll need to use this software tool to make the phone recognize the new sensor.
      Ask FixBot
    9. Google Pixel 3 XL Battery Replacement, Remove the fingerprint sensor tape: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • User tweezers to carefully peel up the yellow tape over the fingerprint sensor connector.
      Ask FixBot
    10. Google Pixel 3 XL Battery Replacement, Disconnect the fingerprint sensor: step 10, image 1 of 3 Google Pixel 3 XL Battery Replacement, Disconnect the fingerprint sensor: step 10, image 2 of 3 Google Pixel 3 XL Battery Replacement, Disconnect the fingerprint sensor: step 10, image 3 of 3
      • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
      • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
      • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
      Ask FixBot
    11. Google Pixel 3 XL Battery Replacement, Remove the back cover: step 11, image 1 of 1
      • Remove the back cover.
      • Follow this guide to correctly apply new back cover adhesive.
      Ask FixBot
    1. Google Pixel 3 XL Battery Replacement, Remove the metal cover bracket screws: step 12, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the following four T3 screws securing the metal cover bracket:
      • Three 4 mm long screws
      • One 3 mm long screw
      Ask FixBot
    2. Google Pixel 3 XL Battery Replacement, Remove the metal cover bracket: step 13, image 1 of 2 Google Pixel 3 XL Battery Replacement, Remove the metal cover bracket: step 13, image 2 of 2
      • Insert the flat end of a spudger underneath the top right edge of the metal bracket and pry up to loosen it.
      • Remove the metal cover bracket.
      Ask FixBot
    3. Google Pixel 3 XL Battery Replacement, Disconnect the battery: step 14, image 1 of 3 Google Pixel 3 XL Battery Replacement, Disconnect the battery: step 14, image 2 of 3 Google Pixel 3 XL Battery Replacement, Disconnect the battery: step 14, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
      • Do not use metal tools to to disconnect the battery, or you will risk shorting the battery.
      • Bend the battery cable such that the connector will not accidentally touch the socket.
      Ask FixBot
    1. Google Pixel 3 XL Battery Replacement, Disconnect the charging coil: step 15, image 1 of 2 Google Pixel 3 XL Battery Replacement, Disconnect the charging coil: step 15, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the charging coil connector from motherboard near the right edge of the phone.
      Ask FixBot
    2. Google Pixel 3 XL Battery Replacement, Slice under the charging coil: step 16, image 1 of 3 Google Pixel 3 XL Battery Replacement, Slice under the charging coil: step 16, image 2 of 3 Google Pixel 3 XL Battery Replacement, Slice under the charging coil: step 16, image 3 of 3
      • Insert the point of an opening pick underneath one edge of the charging coil.
      • Slide the pick along the edge to loosen the adhesive.
      • Slice as deep as you can while taking care not to puncture the battery's surface.
      Ask FixBot
    3. Google Pixel 3 XL Battery Replacement, Apply adhesive remover under the coil: step 17, image 1 of 2 Google Pixel 3 XL Battery Replacement, Apply adhesive remover under the coil: step 17, image 2 of 2
      • Tilt the edge you have been slicing upwards.
      • While holding the phone in a tilted position, apply a few drops of adhesive remover or high concentration isopropyl alcohol along the edge.
      • Keep the phone in that position for a minute or two to allow the adhesive to soften.
      Ask FixBot
    4. Google Pixel 3 XL Battery Replacement, Slice through the coil adhesive: step 18, image 1 of 3 Google Pixel 3 XL Battery Replacement, Slice through the coil adhesive: step 18, image 2 of 3 Google Pixel 3 XL Battery Replacement, Slice through the coil adhesive: step 18, image 3 of 3
      • Insert the flat end of an opening pick underneath a corner of the charging coil.
      • Push the pick slowly and firmly under the coil to loosen the adhesive.
      • The adhesive is mostly around the perimeter of the wireless coil. Use the opening pick to slowly slice through the adhesive.
      • If the adhesive feels difficult to slice through, tilt the phone up and apply a few more drops of adhesive remover.
      Ask FixBot
    5. Google Pixel 3 XL Battery Replacement, Remove the charging coil: step 19, image 1 of 1
      • Remove the wireless charging coil.
      • To install a replacement coil:
      • Be sure to clean off the battery surface of any adhesive residue. Be very careful not to puncture the battery.
      • Connect the wireless coil connector to its motherboard socket. This ensures that the coil is properly aligned.
      • Peel off any adhesive backing on the replacement coil.
      • Lay the coil on top of the battery and firmly press it into position.
      Ask FixBot
    1. Google Pixel 3 XL Battery Replacement, Disconnect the button array connector: step 20, image 1 of 2 Google Pixel 3 XL Battery Replacement, Disconnect the button array connector: step 20, image 2 of 2
      • The next two steps show how to disconnect the button array connector so you won't accidentally damage it when you pry the battery out.
      • Remove the two 3 mm-long T3 screws securing the button array connector bracket.
      • Remove the button array connector bracket.
      Ask FixBot
    2. Google Pixel 3 XL Battery Replacement: step 21, image 1 of 1
      • Use the point of a spudger to pry up and disconnect the button array connector from its motherboard socket.
      Ask FixBot
    3. Google Pixel 3 XL Battery Replacement, Loosen the insulating tape: step 22, image 1 of 3 Google Pixel 3 XL Battery Replacement, Loosen the insulating tape: step 22, image 2 of 3 Google Pixel 3 XL Battery Replacement, Loosen the insulating tape: step 22, image 3 of 3
      • Insert the point of a spudger into the gap along the top edge of the battery.
      • Slowly slide the point along the gap to lift up and detach the insulating tape from the battery.
      • Fold the tape away from the battery.
      Ask FixBot
    4. Google Pixel 3 XL Battery Replacement, Loosen the battery pull tabs: step 23, image 1 of 3 Google Pixel 3 XL Battery Replacement, Loosen the battery pull tabs: step 23, image 2 of 3 Google Pixel 3 XL Battery Replacement, Loosen the battery pull tabs: step 23, image 3 of 3
      • Carefully slide the point of a spudger underneath the yellow battery pull tabs folded along the top edge of the battery.
      • Separate the pull tabs from the battery.
      Ask FixBot
    5. Google Pixel 3 XL Battery Replacement, Insert a bracing pick: step 24, image 1 of 2 Google Pixel 3 XL Battery Replacement, Insert a bracing pick: step 24, image 2 of 2
      • There are steep, sharp edges near the top of the battery, that can easily break the adhesive strip as it's being pulled out.
      • Insert the flat end of an opening pick into the gap above the battery, behind a yellow pull tab.
      • Wedge the pick firmly underneath the battery. The pick will serve as a buffer for the adhesive strip as well as a prying point.
      Ask FixBot
    6. Google Pixel 3 XL Battery Replacement, Remove the battery adhesive strips: step 25, image 1 of 2 Google Pixel 3 XL Battery Replacement, Remove the battery adhesive strips: step 25, image 2 of 2
      • Pull on the yellow adhesive pull tab with slow steady force. Try your best to pull it as shallow of an angle (vs. straight up) as possible.
      • As you pull on the adhesive tab, maintain pressure on the opening pick to wedge it underneath the battery as much as possible.
      • If the adhesive feels stuck, you can apply a few drops of adhesive remover or high concentration isopropyl alcohol into the gap to help loosen the battery. Doing this will most likely loosen both strips at once.
      • Repeat the process with the second adhesive pull tab.
      Ask FixBot
    7. Google Pixel 3 XL Battery Replacement, Remove the battery: step 26, image 1 of 1
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the battery.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • To install a replacement battery:
      • Remove any remaining adhesive from the battery well.
      • Temporarily re-connect the battery connector to its motherboard socket. This ensures that the battery will be properly aligned.
      • Apply stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
      • Lay the battery in the phone and press it firmly in place.
      • Disconnect the battery connector from its motherboard socket and resume reassembly.
      Ask FixBot
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
99 other people completed this guide.
Arthur Shi
351,104 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,715 Guides authored
48 Guide Comments
Very helpful, thank you! I was able to replace my battery pretty easily thanks to this guide.
Gabriel Frederick - Reply Share
Hey. After installing ney battery and new usb port my Pixel 3 has problems with microphones. Its only works with phoning via speakers. can you help me ?
kevin reiter - Reply Share
Hi Kevin,
Assuming that you did not remove the motherboard (which houses a mic), it sounds like something may be off with the daughterboard, which surrounds the USB port and houses the other microphone. I would suggest carefully disconnecting and re-seating the daughterboard connectors, and making sure that the microphone is aligned to the port.
Arthur Shi - Reply Share
Thanks for these great instructions.
I followed them, and managed to replace my old Pixel 3 XL battery without any problems.
Luis Ibanez - Reply Share
What about re attaching the charging coil? The adhesive is now shot on the coil. What should you do to adhere the coil to the new battery?
Glendon sowder - Reply Share
Past 24 Hours: 9
Past 7 Days: 89
Past 30 Days: 336
All Time: 85,602
