Google Pixel 3 XL Back Cover Adhesive Installation
Views: 2.8K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
76
All Time:
2,829
Comments: 6
6 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to correctly apply replacement back cover adhesive to your Pixel 3 XL after a repair.
Before you begin, you should have already removed your Pixel’s back cover and set it aside. Detailed instructions for this can be found here.
Parts
Tools
    1. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: step 1, image 1 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: step 1, image 2 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: step 1, image 3 of 3
      • Pick and scrape away the old adhesive from the frame.
      • Use a spudger to scrape away any lingering adhesive.
      • Don't use metal tools to scrape away adhesive as this will damage the frame.
      • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
      Ask FixBot
    2. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: step 2, image 1 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: step 2, image 2 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: step 2, image 3 of 3
      • Repeat the previous step for the back cover adhesive.
      • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
      • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
      Ask FixBot
    3. Google Pixel 3 XL Back Cover Adhesive Installation, Prepare the replacement adhesive: step 3, image 1 of 1
      • Peel away the plastic lining to expose the frame side of the replacement adhesive.
      Ask FixBot
    4. Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: step 4, image 1 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: step 4, image 2 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: step 4, image 3 of 3
      • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
      • Lower the adhesive onto the frame.
      • Use the holes in the frame to properly align the adhesive.
      Ask FixBot
    5. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: step 5, image 1 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: step 5, image 2 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: step 5, image 3 of 3
      • Use the flat end of a spudger or your fingernail to press down on the adhesive.
      • Slide along the perimeter to secure the adhesive to the frame.
      Ask FixBot
    6. Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: step 6, image 1 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: step 6, image 2 of 3 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to guide the fingerprint sensor cable into its socket.
      • Press down on the latch to secure it.
      Ask FixBot
    7. Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: step 7, image 1 of 2 Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: step 7, image 2 of 2
      • Peel away the plastic lining to expose the back cover side of the adhesive.
      Ask FixBot
    8. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: step 8, image 1 of 2 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: step 8, image 2 of 2
      • Lower the back cover onto the frame.
      • Press down on all edges of the back cover to secure it to the frame.
      • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 XL Answers community for help.
5 other people completed this guide.
Chayton Ritter
27,797 Reputation
105 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 76
All Time: 2,829
