Up to 20% off select tools
Google Pixel 2 Rear Camera Replacement
Views: 14K
View statistics:
Past 24 Hours:
5
Past 7 Days:
15
Past 30 Days:
85
All Time:
14,426
Comments: 78
61 comments on steps, 17 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Replacement guide for the rear camera on a Google Pixel 2 smartphone.
This repair is extensive and requires that the motherboard be completely removed.
Note: Some images in this guide show the battery removed from the phone. You do not need to remove the battery in order to replace the rear camera.
    1. Google Pixel 2 Rear Camera Replacement, Opening Procedure: step 1, image 1 of 2 Google Pixel 2 Rear Camera Replacement, Opening Procedure: step 1, image 2 of 2
      • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
      • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
      • The suction cup will not make a good seal on the curved portion of the glass.
      Ask FixBot
    2. Google Pixel 2 Rear Camera Replacement: step 2, image 1 of 3 Google Pixel 2 Rear Camera Replacement: step 2, image 2 of 3 Google Pixel 2 Rear Camera Replacement: step 2, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
      • Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
      • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
      • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
      Ask FixBot
    3. Google Pixel 2 Rear Camera Replacement: step 3, image 1 of 2 Google Pixel 2 Rear Camera Replacement: step 3, image 2 of 2
      • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
      • Do not insert the pick more than 9 mm into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
      • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
      • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
      Ask FixBot
    4. Google Pixel 2 Rear Camera Replacement: step 4, image 1 of 2 Google Pixel 2 Rear Camera Replacement: step 4, image 2 of 2
      • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
      • Slide the opening pick up the right side of the phone to separate the display adhesive.
      • Take extra care with the side bezels, which are only 1.5 mm deep.
      Ask FixBot
    5. Google Pixel 2 Rear Camera Replacement: step 5, image 1 of 3 Google Pixel 2 Rear Camera Replacement: step 5, image 2 of 3 Google Pixel 2 Rear Camera Replacement: step 5, image 3 of 3
      • Slide the opening pick around the upper-right corner and along the top edge of the phone.
      • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
      Ask FixBot
    6. Google Pixel 2 Rear Camera Replacement: step 6, image 1 of 3 Google Pixel 2 Rear Camera Replacement: step 6, image 2 of 3 Google Pixel 2 Rear Camera Replacement: step 6, image 3 of 3
      • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
      Ask FixBot
    7. Google Pixel 2 Rear Camera Replacement: step 7, image 1 of 3 Google Pixel 2 Rear Camera Replacement: step 7, image 2 of 3 Google Pixel 2 Rear Camera Replacement: step 7, image 3 of 3
      • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
      • Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
      Ask FixBot
    8. Google Pixel 2 Rear Camera Replacement: step 8, image 1 of 2 Google Pixel 2 Rear Camera Replacement: step 8, image 2 of 2
      • Reinsert the pick at the top edge of the phone and gently pry up the display.
      • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
      • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
      Ask FixBot
    9. Google Pixel 2 Rear Camera Replacement: step 9, image 1 of 2 Google Pixel 2 Rear Camera Replacement: step 9, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
      • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
      Ask FixBot
    10. Google Pixel 2 Rear Camera Replacement: step 10, image 1 of 1
      • Remove the display cable bracket.
      Ask FixBot
    11. Google Pixel 2 Rear Camera Replacement: step 11, image 1 of 2 Google Pixel 2 Rear Camera Replacement: step 11, image 2 of 2
      • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
      • Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      • During reassembly, pause here and replace the adhesive around the edges of the display.
      Ask FixBot
    1. Google Pixel 2 Rear Camera Replacement, Midframe: step 12, image 1 of 1
      • Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
      Ask FixBot
    2. Google Pixel 2 Rear Camera Replacement: step 13, image 1 of 2 Google Pixel 2 Rear Camera Replacement: step 13, image 2 of 2
      • Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
      • Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
      Ask FixBot
    3. Google Pixel 2 Rear Camera Replacement: step 14, image 1 of 1
      $16.96
      Buy
      • Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
      • Remove the following screws securing the midframe:
      • Eleven 3.7 mm Phillips screws
      • One 4 mm T5 Torx screw
      Ask FixBot
    4. Google Pixel 2 Rear Camera Replacement: step 15, image 1 of 2 Google Pixel 2 Rear Camera Replacement: step 15, image 2 of 2
      • Insert an opening tool into the notch in the midframe near the hold button.
      • Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
      Ask FixBot
    5. Google Pixel 2 Rear Camera Replacement: step 16, image 1 of 3 Google Pixel 2 Rear Camera Replacement: step 16, image 2 of 3 Google Pixel 2 Rear Camera Replacement: step 16, image 3 of 3
      • Lift the midframe up starting from the bottom edge.
      • When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
      • As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
      Ask FixBot
    1. Google Pixel 2 Rear Camera Replacement, Battery Connector: step 17, image 1 of 2 Google Pixel 2 Rear Camera Replacement, Battery Connector: step 17, image 2 of 2
      • Use the flat end of a spudger to disconnect the battery connector.
      Ask FixBot
    1. Google Pixel 2 Rear Camera Replacement, Motherboard: step 18, image 1 of 2 Google Pixel 2 Rear Camera Replacement, Motherboard: step 18, image 2 of 2
      • use the flat end of a spudger to disconnect the charging assembly connector from the motherboard.
      Ask FixBot
    2. Google Pixel 2 Rear Camera Replacement: step 19, image 1 of 3 Google Pixel 2 Rear Camera Replacement: step 19, image 2 of 3 Google Pixel 2 Rear Camera Replacement: step 19, image 3 of 3
      • Insert a paperclip or SIM eject tool into the small hole on the left side of the phone and push until the SIM card tray pops out.
      • Remove the SIM card tray.
      Ask FixBot
    3. Google Pixel 2 Rear Camera Replacement: step 20, image 1 of 1
      • Remove the two 2.5 mm PH00 screws.
      Ask FixBot
    4. Google Pixel 2 Rear Camera Replacement: step 21, image 1 of 3 Google Pixel 2 Rear Camera Replacement: step 21, image 2 of 3 Google Pixel 2 Rear Camera Replacement: step 21, image 3 of 3
      • Disconnect two connectors at the bottom edge of the motherboard.
      Ask FixBot
    5. Google Pixel 2 Rear Camera Replacement: step 22, image 1 of 2 Google Pixel 2 Rear Camera Replacement: step 22, image 2 of 2
      • Pry up the motherboard using a plastic opening tool.
      • Remove the motherboard.
      Ask FixBot
    6. Google Pixel 2 Rear Camera Replacement: step 23, image 1 of 3 Google Pixel 2 Rear Camera Replacement: step 23, image 2 of 3 Google Pixel 2 Rear Camera Replacement: step 23, image 3 of 3
      • Flip the motherboard over.
      • Disconnect the fingerprint sensor cable.
      • The motherboard is now completely detached from the phone.
      Ask FixBot
    1. Google Pixel 2 Rear Camera Replacement, Rear Camera: step 24, image 1 of 2 Google Pixel 2 Rear Camera Replacement, Rear Camera: step 24, image 2 of 2
      • Use the pointed end of a spudger to lift up and disconnect the rear camera press-fit connector.
      • Remove the rear camera from the motherboard.
      • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
      • Make sure the lens surface is smudge and dust free before you install the camera assembly.
      Ask FixBot
7 other people completed this guide.
Author
with
Blake Klein
75,591 Reputation
49 Guides authored
17 Guide Comments
Does anyone know if replacing the camera unit fixes the problem with the camera’s ‘fatal error’ issue? I’m trying to figure out if it’s just the camera unit that’s bad, or if there are other parts involved.
Sean McCay - Reply Share
I just replaced my rear camera on pixel 2 and I can confirm YES it does fix it!
John Feng - Reply Share
Well, I completed the repair on the camera but cannot confirm that it worked because I messed up my display which costs too much to replace :( That thing is super delicate I guess. I’m thoroughly upset.
Yes. This fixed my Pixel 2 camera crashing issue. My original symptom was that the autofocus stopped working properly. Then a month or so later the rear camera would crash 49 out of 50 times I opened it (completely unusable). Many people online swear this is a software issue caused by an android update but because I had that focus issue crop up first I suspected my issue was physical damage. I’m generally pretty careful with my phone, it lives in an official case. The only potentially damaging behaviour my phone is exposed to is my placing it in a windscreen mounted phone holder. Perhaps the repeated vibration can break something. Now my camera is fixed I will continue to place it in the phone holder and report back if it breaks again. For science. BE VERY CAREFUL REMOVING THE SCREEN. The guide is not being overly cautious about the screen removal. I broke my screen removing it and turned my $50 camera job into a $200 job with a new screen. Still worth it but I wish I’d heeded the warnings and cautions.
Alex Lawson - Reply Share
Alex, you may be onto something! There have been many reports of motorcycle riders breaking their smartphone cameras after they’ve mounted their smartphones for prolonged periods. The optical stabilization hardware on these camera modules is pretty fragile. I suspect repeated vibration can definitely result in breaking some very delicate wires in the OIS or flex cables.
Arthur Shi - Reply Share
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 85
All Time: 14,426
