Up to 20% off select tools
Google Pixel 2 Display Adhesive Replacement
Views: 8.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
92
All Time:
8,825
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Parts
Tools
  • Tweezers
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to apply replacement adhesive to your Pixel 2’s display.
Before you begin, you should already have removed the Pixel 2’s display. Detailed instructions for removing the display can be found here.
    1. Google Pixel 2 Display Adhesive Replacement, Display Adhesive: step 1, image 1 of 1
      • Remove any trace of the old adhesive from the Pixel 2's case.
      • If you're reinstalling your existing display, be sure to remove any remaining adhesive from the back of your display as well.
      • Take special care to remove any small glass fragments.
      • After removing all traces of glue and glass, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%). This will ensure a better seal for the display.
      • If your new display doesn't come with speaker grilles or a front-facing camera bracket, make sure to install those before applying display adhesive.
      Ask FixBot
    2. Google Pixel 2 Display Adhesive Replacement: step 2, image 1 of 1
      • Peel the clear backing off of the replacement adhesive.
      Ask FixBot
    3. Google Pixel 2 Display Adhesive Replacement: step 3, image 1 of 1
      • There are perforations along the inner and outer edges of the adhesive strip.
      • Carefully tear along the perforations to separate the outer portion of the adhesive backing from the adhesive strip.
      • Be very careful not to tear the adhesive, the white backing, or the blue backing underneath the adhesive. Only remove the blue plastic surrounding the outside edge of the adhesive strip.
      Ask FixBot
    4. Google Pixel 2 Display Adhesive Replacement: step 4, image 1 of 2 Google Pixel 2 Display Adhesive Replacement: step 4, image 2 of 2
      • Peel away the white backing, exposing one side of the adhesive strip.
      • Carefully place the adhesive strip on the phone case, with the exposed side down, and the blue backing up.
      • Start at the bottom of the case, lining up the contours along the bottom edge of the adhesive with those of the case. Then lay down the rest of the adhesive.
      Ask FixBot
    5. Google Pixel 2 Display Adhesive Replacement: step 5, image 1 of 2 Google Pixel 2 Display Adhesive Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • With the adhesive lined up with the edges of the case, use your finger or a spudger to press the adhesive strip down against the case.
      • Use a pair of tweezers to remove the inner portion of the blue backing. It may be necessary to hold the adhesive down with a spudger to avoid pulling up the adhesive strip.
      • Be very careful and avoid tearing or removing the adhesive.
      Ask FixBot
    6. Google Pixel 2 Display Adhesive Replacement: step 6, image 1 of 1
      • Use tweezers to peel away the blue backing over top of the adhesive without peeling the adhesive off of the case.
      • If the adhesive starts to come off of the case as you remove the backing, you may need to slide a spudger in between the adhesive and the backing to hold the adhesive down.
      Ask FixBot
18 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
1 Guide Comment
Adhesive tend to stick inside the bag, use extra caution to remove sheet from the package.
Do not touch adhesive at any point, you might mess up the forming of the adhesive.
U Hang Chiang - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 92
All Time: 8,825
