Up to 20% off select tools
Google Pixel 2 Battery Replacement
Views: 152K
View statistics:
Past 24 Hours:
9
Past 7 Days:
82
Past 30 Days:
389
All Time:
152,058
Comments: 116
76 comments on steps, 40 guide comments.
Go to guide comments
Completed: 96
96 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the worn-out battery in your Google Pixel 2.
Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. If your battery is swollen, take appropriate precautions.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there is a good chance of accidentally damaging your display during this procedure. Unless you plan to replace your display in conjunction with this repair, work very carefully and be prepared to replace the display, should it not work upon reassembly. Follow the instructions carefully and observe all warnings to increase your odds of success.
The battery is held in place by very strong adhesive. You will need to use high concentration (over 90%) isopropyl alcohol in order to loosen the battery from the phone.
    1. Google Pixel 2 Battery Replacement, Opening Procedure: step 1, image 1 of 2 Google Pixel 2 Battery Replacement, Opening Procedure: step 1, image 2 of 2
      • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
      • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
      • The suction cup will not make a good seal on the curved portion of the glass.
      Ask FixBot
    2. Google Pixel 2 Battery Replacement: step 2, image 1 of 3 Google Pixel 2 Battery Replacement: step 2, image 2 of 3 Google Pixel 2 Battery Replacement: step 2, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
      • Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
      • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
      • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
      Ask FixBot
    3. Google Pixel 2 Battery Replacement: step 3, image 1 of 2 Google Pixel 2 Battery Replacement: step 3, image 2 of 2
      • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
      • Do not insert the pick more than 9 mm into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
      • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
      • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
      Ask FixBot
    4. Google Pixel 2 Battery Replacement: step 4, image 1 of 2 Google Pixel 2 Battery Replacement: step 4, image 2 of 2
      • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
      • Slide the opening pick up the right side of the phone to separate the display adhesive.
      • Take extra care with the side bezels, which are only 1.5 mm deep.
      Ask FixBot
    5. Google Pixel 2 Battery Replacement: step 5, image 1 of 3 Google Pixel 2 Battery Replacement: step 5, image 2 of 3 Google Pixel 2 Battery Replacement: step 5, image 3 of 3
      • Slide the opening pick around the upper-right corner and along the top edge of the phone.
      • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
      Ask FixBot
    6. Google Pixel 2 Battery Replacement: step 6, image 1 of 3 Google Pixel 2 Battery Replacement: step 6, image 2 of 3 Google Pixel 2 Battery Replacement: step 6, image 3 of 3
      • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
      Ask FixBot
    7. Google Pixel 2 Battery Replacement: step 7, image 1 of 3 Google Pixel 2 Battery Replacement: step 7, image 2 of 3 Google Pixel 2 Battery Replacement: step 7, image 3 of 3
      • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
      • Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
      Ask FixBot
    8. Google Pixel 2 Battery Replacement: step 8, image 1 of 2 Google Pixel 2 Battery Replacement: step 8, image 2 of 2
      • Reinsert the pick at the top edge of the phone and gently pry up the display.
      • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
      • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
      Ask FixBot
    9. Google Pixel 2 Battery Replacement: step 9, image 1 of 2 Google Pixel 2 Battery Replacement: step 9, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
      • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
      Ask FixBot
    10. Google Pixel 2 Battery Replacement: step 10, image 1 of 1
      • Remove the display cable bracket.
      Ask FixBot
    11. Google Pixel 2 Battery Replacement: step 11, image 1 of 2 Google Pixel 2 Battery Replacement: step 11, image 2 of 2
      • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
      • Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      • During reassembly, pause here and replace the adhesive around the edges of the display.
      Ask FixBot
    1. Google Pixel 2 Battery Replacement, Midframe: step 12, image 1 of 1
      • Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
      Ask FixBot
    2. Google Pixel 2 Battery Replacement: step 13, image 1 of 2 Google Pixel 2 Battery Replacement: step 13, image 2 of 2
      • Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
      • Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
      Ask FixBot
    3. Google Pixel 2 Battery Replacement: step 14, image 1 of 1
      $16.96
      Buy
      • Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
      • Remove the following screws securing the midframe:
      • Eleven 3.7 mm Phillips screws
      • One 4 mm T5 Torx screw
      Ask FixBot
    4. Google Pixel 2 Battery Replacement: step 15, image 1 of 2 Google Pixel 2 Battery Replacement: step 15, image 2 of 2
      • Insert an opening tool into the notch in the midframe near the hold button.
      • Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
      Ask FixBot
    5. Google Pixel 2 Battery Replacement: step 16, image 1 of 3 Google Pixel 2 Battery Replacement: step 16, image 2 of 3 Google Pixel 2 Battery Replacement: step 16, image 3 of 3
      • Lift the midframe up starting from the bottom edge.
      • When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
      • As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
      Ask FixBot
    1. Google Pixel 2 Battery Replacement, Battery Connector: step 17, image 1 of 2 Google Pixel 2 Battery Replacement, Battery Connector: step 17, image 2 of 2
      • Use the flat end of a spudger to disconnect the battery connector.
      Ask FixBot
    1. Google Pixel 2 Battery Replacement, Battery: step 18, image 1 of 2 Google Pixel 2 Battery Replacement, Battery: step 18, image 2 of 2
      • Use the flat end of a spudger to disconnect the charging assembly connector.
      Ask FixBot
    2. Google Pixel 2 Battery Replacement: step 19, image 1 of 1
      • Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol under each corner of the battery. Give the alcohol a minute to weaken the battery adhesive.
      • Alternatively, apply a heated iOpener to the back of the phone over the battery for at least two minutes. Reheat and reapply the iOpener as needed until the battery adhesive is sufficiently weakened.
      Ask FixBot
    3. Google Pixel 2 Battery Replacement: step 20, image 1 of 2 Google Pixel 2 Battery Replacement: step 20, image 2 of 2
      • Hold the charging assembly cable out of the way and insert an opening pick along the bottom edge of the battery.
      • Apply steady, even pressure to slowly lever the battery up and out of the phone.
      • Only pry from the center of the battery to avoid damaging the delicate ribbon cables beneath either side of the battery.
      • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
      • If you are having trouble, apply some more alcohol under the battery and try again.
      Ask FixBot
    4. Google Pixel 2 Battery Replacement: step 21, image 1 of 2 Google Pixel 2 Battery Replacement: step 21, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the battery.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • To install a new battery:
      • Use a spudger to scrape away any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone, not directly onto the battery. The adhesive should not touch any of the cables under the battery.
      • Press the battery firmly into place for 20-30 seconds.
      Ask FixBot
After completing this guide, calibrate your newly-installed battery.
96 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
40 Guide Comments
The instructions say “No parts required” and yet I believe that for a battery replacement you might possibly require a new battery (and maybe a new screen in the case of a broken screen). Also you might suggest replacement adhesive and where to find that, too.
Leslie Gawne - Reply Share
Hey. So I bought a new housing and a new screen for my Pixel 2. And I have a problem with that. After moving the parts to the new housing my vibromotor stopped working and bottom of the screen easily comes off. What should I do?
Rauf Salikhov - Reply Share
Hi Rauf, it’s hard to say exactly what’s wrong, but as a start I would disconnect and reconnect the vibrator motor to make sure it’s connected correctly. As for the screen, make sure you carefully clean any old adhesive off the screen and case (use 90% or higher isopropyl alcohol for stubborn), and apply new adhesive to the screen before you replace it. That should help the display seat in the case and stay put.
Adam O'Camb - Reply Share
I have a quick question, if we were to replace the screen adhesive with the Tesa 61395 tape, would the phone still remain water resistant to IP67? I am only worried it would not hold it as strong as the original adhesive
Tony Goh - Reply Share
Hi Tony, Tesa tape creates a strong bond and should secure your screen just as well as the old adhesive. Unfortunately, the phone won’t be waterproof since you can’t create a continuous seal using the tape.
Past 24 Hours: 9
Past 7 Days: 82
Past 30 Days: 389
All Time: 152,058
