Google Pixel 10 Rear Cameras Replacement
    1. Google Pixel 10 Rear Cameras Replacement, Prepare your Pixel for disassembly: step 1, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Prepare your Pixel for disassembly: step 1, image 2 of 2
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your phone.
      Ask FixBot
    1. Google Pixel 10 Rear Cameras Replacement, Cracked glass preparation: step 2, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Cracked glass preparation: step 2, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Cracked glass preparation: step 2, image 3 of 3
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
      • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    2. Google Pixel 10 Rear Cameras Replacement, Heat the bottom edge: step 3, image 1 of 1
      • Adhesive secures the back glass to the frame. Heating the glass softens the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the back glass.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    3. Google Pixel 10 Rear Cameras Replacement, Apply a suction handle: step 4, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Apply a suction handle: step 4, image 2 of 2
      • Apply a suction handle to the center of the back glass's bottom edge, as close to the edge as possible.
      Ask FixBot
    4. Google Pixel 10 Rear Cameras Replacement, Insert an opening pick: step 5, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Insert an opening pick: step 5, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Insert an opening pick: step 5, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    5. Google Pixel 10 Rear Cameras Replacement, Back glass adhesive information: step 6, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Back glass adhesive information: step 6, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Back glass adhesive information: step 6, image 3 of 3
      • The back glass is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
      • A cable connects the back glass near the power button. Don't insert your pick here to avoid damaging the cable.
      Ask FixBot
    6. Google Pixel 10 Rear Cameras Replacement, Separate the bottom edge adhesive: step 7, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Separate the bottom edge adhesive: step 7, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Separate the bottom edge adhesive: step 7, image 3 of 3
      • If the back glass feels stuck at any point when separating the adhesive, apply heat to the area and try again.
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    7. Google Pixel 10 Rear Cameras Replacement, Separate the bottom left adhesive: step 8, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Separate the bottom left adhesive: step 8, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Separate the bottom left adhesive: step 8, image 3 of 3
      • Insert a second pick under the bottom left corner and slide it up the left edge, stopping at the power button.
      • Leave the pick inserted to prevent the adhesive from re‑sealing.
      Ask FixBot
    8. Google Pixel 10 Rear Cameras Replacement, Separate the right edge adhesive: step 9, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Separate the right edge adhesive: step 9, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Separate the right edge adhesive: step 9, image 3 of 3
      • Insert a third pick under the bottom right corner of the back glass and slide it up the right edge.
      • Leave the pick inserted under the top right corner.
      Ask FixBot
    9. Google Pixel 10 Rear Cameras Replacement, Separate the top edge adhesive: step 10, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Separate the top edge adhesive: step 10, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Separate the top edge adhesive: step 10, image 3 of 3
      • Insert a fourth pick under the top right corner.
      • Slide the pick along the top edge and slightly around the top left corner, stopping at the bottom of the camera bump.
      • Don't try to fully remove the back glass yet, as it's still connected by a ribbon cable.
      Ask FixBot
    10. Google Pixel 10 Rear Cameras Replacement, Prop up the back glass: step 11, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Prop up the back glass: step 11, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Prop up the back glass: step 11, image 3 of 3
      • Flip the back glass over the left side of the phone and use the suction handle (or a sturdy object) to prop it up.
      • If the back glass still feels stuck, go back around the perimeter with an opening pick and separate any remaining adhesive.
      Ask FixBot
    11. Google Pixel 10 Rear Cameras Replacement, Remove the bracket screws: step 12, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Remove the bracket screws: step 12, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the back glass connector bracket.
      Ask FixBot
    12. Google Pixel 10 Rear Cameras Replacement: step 13, image 1 of 3 Google Pixel 10 Rear Cameras Replacement: step 13, image 2 of 3 Google Pixel 10 Rear Cameras Replacement: step 13, image 3 of 3
      • Use tweezers or your fingers to remove the bracket.
      • Be careful not to scratch or smudge the rear cameras.
      Ask FixBot
    13. Google Pixel 10 Rear Cameras Replacement, Disconnect the back glass: step 14, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Disconnect the back glass: step 14, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the back glass press connector.
      Ask FixBot
    14. Google Pixel 10 Rear Cameras Replacement, Remove the back glass: step 15, image 1 of 1
      • Remove the back glass.
      Ask FixBot
    1. Google Pixel 10 Rear Cameras Replacement, Remove the motherboard cover screws: step 16, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Remove the motherboard cover screws: step 16, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the motherboard cover.
      Ask FixBot
    2. Google Pixel 10 Rear Cameras Replacement, Reposition the motherboard cover: step 17, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Reposition the motherboard cover: step 17, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Reposition the motherboard cover: step 17, image 3 of 3
      • Use a spudger to lift the motherboard cover and gently flip it towards the bottom of the phone.
      • Be careful not to damage the delicate graphite sheet that connects the cover.
      Ask FixBot
    3. Google Pixel 10 Rear Cameras Replacement, Disconnect the battery: step 18, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Disconnect the battery: step 18, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    4. Google Pixel 10 Rear Cameras Replacement, Remove the front camera bracket: step 19, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Remove the front camera bracket: step 19, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the 5.0 mm‑long screw securing the front camera bracket.
      Ask FixBot
    5. Google Pixel 10 Rear Cameras Replacement, Remove the bracket: step 20, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Remove the bracket: step 20, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Remove the bracket: step 20, image 3 of 3
      • Use the point of a spudger to push the front camera bracket's clip in and up to release it.
      • Remove the bracket.
      Ask FixBot
    6. Google Pixel 10 Rear Cameras Replacement, Remove the mic cover: step 21, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Remove the mic cover: step 21, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the mic cover.
      Ask FixBot
    7. Google Pixel 10 Rear Cameras Replacement: step 22, image 1 of 2 Google Pixel 10 Rear Cameras Replacement: step 22, image 2 of 2
      • Remove the mic cover.
      Ask FixBot
    8. Google Pixel 10 Rear Cameras Replacement, Disconnect the rear cameras: step 23, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Disconnect the rear cameras: step 23, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Disconnect the rear cameras: step 23, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the three rear camera press connectors.
      Ask FixBot
    9. Google Pixel 10 Rear Cameras Replacement, Remove the rear cameras: step 24, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Remove the rear cameras: step 24, image 2 of 2
      • Remove the rear cameras.
      Ask FixBot
    1. Google Pixel 10 Rear Cameras Replacement, Disassembly complete: step 25, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
      Ask FixBot
    1. Google Pixel 10 Rear Cameras Replacement, Insert the rear cameras: step 26, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Insert the rear cameras: step 26, image 2 of 2
      • Place the rear cameras onto the motherboard.
      Ask FixBot
    2. Google Pixel 10 Rear Cameras Replacement, Connect the rear cameras: step 27, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Connect the rear cameras: step 27, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Connect the rear cameras: step 27, image 3 of 3
      • Use your finger to press down and connect the three rear camera press connectors.
      Ask FixBot
    3. Google Pixel 10 Rear Cameras Replacement, Install the mic cover: step 28, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Install the mic cover: step 28, image 2 of 2
      • Put the mic cover back in place near the top left corner.
      Ask FixBot
    4. Google Pixel 10 Rear Cameras Replacement: step 29, image 1 of 2 Google Pixel 10 Rear Cameras Replacement: step 29, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the mic cover.
      Ask FixBot
    5. Google Pixel 10 Rear Cameras Replacement, Install the front camera bracket: step 30, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Install the front camera bracket: step 30, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Install the front camera bracket: step 30, image 3 of 3
      • Slide the top corners of the front camera bracket under the lip in the frame and press the clip in to secure it.
      • Be careful not to touch the rear cameras.
      Ask FixBot
    6. Google Pixel 10 Rear Cameras Replacement, Check the thermal pad: step 31, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Check the thermal pad: step 31, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Check the thermal pad: step 31, image 3 of 3
      • Check the condition of the motherboard thermal pad—it'll either be on the bottom edge of the board or on the underside of the cover.
      • If the thermal pad is damaged, follow the next two steps to replace it. Otherwise, skip down two steps.
      • Be careful when working on the motherboard cover in the next two steps, as it's still connected by delicate graphite film. If you damage the film, you'll need to replace it with a new one.
      • Use the flat end of a spudger to gently scrape up and remove all the old thermal pad from the board and cover.
      • Use high‑concentration (>90%) isopropyl alcohol and a coffee filter (or lint‑free cloth) to clean up any thermal pad residue from the board and cover.
      • Allow the alcohol to dry completely before continuing.
      Ask FixBot
    7. Google Pixel 10 Rear Cameras Replacement, Replace the thermal pad: step 32, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Replace the thermal pad: step 32, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Replace the thermal pad: step 32, image 3 of 3
      • Remove the larger liner (without cutouts) from the thermal pad.
      • Lay the thermal pad in its square cutout on the underside of the motherboard cover.
      • Press down firmly on the entire surface of the pad with your finger or the flat end of a spudger.
      • Slowly peel up the remaining liner.
      • If the pad starts to peel up with the liner, press it back into place and try again.
      Ask FixBot
    8. Google Pixel 10 Rear Cameras Replacement, Connect the battery: step 33, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Connect the battery: step 33, image 2 of 2
      • Use your finger to press down and connect the battery press connector.
      Ask FixBot
    9. Google Pixel 10 Rear Cameras Replacement, Install the motherboard cover: step 34, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Install the motherboard cover: step 34, image 2 of 2
      • Gently flip the motherboard cover up and back into place.
      Ask FixBot
    10. Google Pixel 10 Rear Cameras Replacement: step 35, image 1 of 2 Google Pixel 10 Rear Cameras Replacement: step 35, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the motherboard cover.
      Ask FixBot
    1. Google Pixel 10 Rear Cameras Replacement, Remove the old back glass adhesive: step 36, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Remove the old back glass adhesive: step 36, image 2 of 2
      • Before installing new adhesive, all the old adhesive and its residue must be completely removed from the frame.
      • Take your time during the next two steps. A clean frame allows replacement adhesive to lay totally flat, ensuring a better seal for your back glass.
      Ask FixBot
    2. Google Pixel 10 Rear Cameras Replacement: step 37, image 1 of 3 Google Pixel 10 Rear Cameras Replacement: step 37, image 2 of 3 Google Pixel 10 Rear Cameras Replacement: step 37, image 3 of 3
      • Removing all the old adhesive can be very tricky and time‑consuming.
      • When removing the back glass adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
      • Use the point of a spudger to remove all the old screen adhesive from the frame. Try to "roll" the adhesive onto itself so it balls up, making it easier to remove.
      • If you're having trouble removing smaller chunks, apply a single drop of high‑concentration (>90%) isopropyl alcohol and scrape them up with your spudger.
      Ask FixBot
    3. Google Pixel 10 Rear Cameras Replacement: step 38, image 1 of 2 Google Pixel 10 Rear Cameras Replacement: step 38, image 2 of 2
      • Wrap a microfiber or lint‑free cloth around a spudger and apply a single drop of high‑concentration (>90%) isopropyl alcohol to the end.
      • Use the spudger to clean up all the remaining adhesive residue from the frame, applying more drops of alcohol as necessary.
      • Let the alcohol dry completely before continuing.
      Ask FixBot
    4. Google Pixel 10 Rear Cameras Replacement: step 39, image 1 of 2 Google Pixel 10 Rear Cameras Replacement: step 39, image 2 of 2
      • If you're reinstalling your original back glass, repeat the procedures in the previous two steps on the back glass to clean it.
      Ask FixBot
    5. Google Pixel 10 Rear Cameras Replacement, Orient the adhesive: step 40, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Orient the adhesive: step 40, image 2 of 2
      • Before applying the back glass adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
      • Hold the adhesive above the frame to find its orientation. Use the rear camera cutout in the liner to help visualize how it will lay in the frame.
      Ask FixBot
    6. Google Pixel 10 Rear Cameras Replacement: step 41, image 1 of 1
      • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
      Ask FixBot
    7. Google Pixel 10 Rear Cameras Replacement, Install the back glass adhesive: step 42, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Install the back glass adhesive: step 42, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Install the back glass adhesive: step 42, image 3 of 3
      • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
      • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
      • Use the lip of the frame to help align the adhesive.
      • Once the top edge is properly aligned, gently press down on the top corners to secure the adhesive.
      Ask FixBot
    8. Google Pixel 10 Rear Cameras Replacement: step 43, image 1 of 3 Google Pixel 10 Rear Cameras Replacement: step 43, image 2 of 3 Google Pixel 10 Rear Cameras Replacement: step 43, image 3 of 3
      • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
      Ask FixBot
    9. Google Pixel 10 Rear Cameras Replacement: step 44, image 1 of 3 Google Pixel 10 Rear Cameras Replacement: step 44, image 2 of 3 Google Pixel 10 Rear Cameras Replacement: step 44, image 3 of 3
      • Use a spudger to press down firmly on the adhesive to secure it to the frame.
      Ask FixBot
    10. Google Pixel 10 Rear Cameras Replacement, Remove the larger liner: step 45, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Remove the larger liner: step 45, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Remove the larger liner: step 45, image 3 of 3
      • Slowly peel up and remove the large colored liner, gripping it from the cutout near the top edge.
      • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
      Ask FixBot
    11. Google Pixel 10 Rear Cameras Replacement: step 46, image 1 of 3 Google Pixel 10 Rear Cameras Replacement: step 46, image 2 of 3 Google Pixel 10 Rear Cameras Replacement: step 46, image 3 of 3
      Ask FixBot
    12. Google Pixel 10 Rear Cameras Replacement, Remove any liners from the back glass: step 47, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Remove any liners from the back glass: step 47, image 2 of 2
      • If you're installing a new back glass, your replacement will have various protective liners and pieces of tape on the underside that must be removed. Your part may have different pieces in different locations, so make sure to check carefully!
      • Remove all liners from the underside of the back glass, paying special attention to the front camera cutouts and bottom edge.
      • Usually, you can identify the liners by their pull tabs.
      Ask FixBot
    13. Google Pixel 10 Rear Cameras Replacement, Prop up the back glass: step 48, image 1 of 1
      • Apply a suction handle to the back glass and prop it up on the left side of your phone, so the cable is near its connector.
      • Alternatively, you can use a sturdy object (such as a stack of books) to prop up the back glass.
      Ask FixBot
    14. Google Pixel 10 Rear Cameras Replacement, Connect the back glass cable: step 49, image 1 of 2 Google Pixel 10 Rear Cameras Replacement, Connect the back glass cable: step 49, image 2 of 2
      • Use the flat end of a spudger to connect the back glass press connector to its socket.
      • This can be tricky, as there's very little play in the cable. Move the back glass as necessary to help, and don't try to force the connector into place—reposition it and try again.
      Ask FixBot
    15. Google Pixel 10 Rear Cameras Replacement, Install the bracket: step 50, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Install the bracket: step 50, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Install the bracket: step 50, image 3 of 3
      • Put the cable's bracket back in place, making sure the tab on the right edge goes under its groove.
      Ask FixBot
    16. Google Pixel 10 Rear Cameras Replacement: step 51, image 1 of 2 Google Pixel 10 Rear Cameras Replacement: step 51, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the bracket.
      • This is a good point to power on your device and test all functions before sealing it up. If you have trouble, try some basic troubleshooting. Be sure to power back down completely before you continue working.
      Ask FixBot
    17. Google Pixel 10 Rear Cameras Replacement, Remove the remaining liners: step 52, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Remove the remaining liners: step 52, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Remove the remaining liners: step 52, image 3 of 3
      • Remove the remaining liners from the back glass adhesive.
      Ask FixBot
    18. Google Pixel 10 Rear Cameras Replacement, Install the back glass: step 53, image 1 of 3 Google Pixel 10 Rear Cameras Replacement, Install the back glass: step 53, image 2 of 3 Google Pixel 10 Rear Cameras Replacement, Install the back glass: step 53, image 3 of 3
      • Flip the back glass onto the frame and press it firmly into place.
      • Hold your phone up and squeeze firmly around the perimeter to strengthen the bond.
      • For an even stronger bond, you can stack books on the back glass or use screen vise clamps.
      Ask FixBot
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
206,465 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 55
Past 30 Days: 262
All Time: 2,148
